Propeller shaft / Drive shaft
Postby olalof [OP] » December 7th 2009, 6:26pm
Is that the same thing on a 94 AWD Astro?
Thanks.
/Ola
olalof
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: olalof has been a member for 7 full yearsolalof has been a member for 7 full yearsolalof has been a member for 7 full yearsolalof has been a member for 7 full yearsolalof has been a member for 7 full yearsolalof has been a member for 7 full yearsolalof has been a member for 7 full years
Topics: 18
Alias (AKA): Ola Löfgren
Extra Info: LT 4.3L V6 AWD
  • Drive shaft vibration?
    by Ingmire » October 16th 2016, 10:08pm in Automatic
    Last post by MmusicmanMmusicman is online! View the latest post
    October 31st 2016, 11:54pm
    100
    January 23rd 2017, 3:50pm
Re: Propeller shaft / Drive shaft
Postby timelessbeing » December 7th 2009, 6:59pm
Prop shaft goes to the front. Just like on an airplane!
2000 Astro AWD Passenger
4.3L CSFI V6 • 3.73 G80 • 4" OV lift • 30" AT tires
timelessbeing
Years of Membership: timelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full years
Topics: 38
Extra Info: Lifted AWD 4.3
Postby olalof [OP] » December 7th 2009, 7:38pm
And the drive shaft?
The mecanic said prop shaft.
I have to replace it, but can't find it online. only drive shaft which looks the same.
/Ola
olalof
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 18
Postby olalof [OP] » December 7th 2009, 9:20pm
My question is:
Is drive shaft and propeller shaft the same thing?
Or two different shafts?
Sorry if that was'nt clear.
/Ola
olalof
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 18
Postby doyoulikeithere » December 7th 2009, 9:30pm
Well, my best guess is that, since an astrovan actually does not have a propeller, he is talking about a driveshaft and using terminology that is uncommon to most of us.
However, if you van has one or more Propellers mounted on it, a propeller shaft may be what he is referring too.
Would it be cool to swap a Pratt & Whitney PT6A-67B or Rolls Royce 250C28 engine into your astro instead of the more common SBC swap? lol
:twisted:
doyoulikeithere
Firing on 7 Cylinders (L1)
Years of Membership: doyoulikeithere has been a member for 8 full yearsdoyoulikeithere has been a member for 8 full yearsdoyoulikeithere has been a member for 8 full yearsdoyoulikeithere has been a member for 8 full yearsdoyoulikeithere has been a member for 8 full yearsdoyoulikeithere has been a member for 8 full yearsdoyoulikeithere has been a member for 8 full yearsdoyoulikeithere has been a member for 8 full years
Topics: 26
Images: 11
Postby offroad safari » December 7th 2009, 9:51pm
the prop / propeller shaft comes off the front of the transfer case and goes to the front differential. The drive shaft comes out of the back of the transfer case goes to the rear differential on an AWD van
'90 AWD Shorty Safari
4" Overland Lift + countless mods
"It's a Safari thing.... Jeep people couldn't understand"
offroad safari
Years of Membership: offroad safari has been a member for 7 full yearsoffroad safari has been a member for 7 full yearsoffroad safari has been a member for 7 full yearsoffroad safari has been a member for 7 full yearsoffroad safari has been a member for 7 full yearsoffroad safari has been a member for 7 full yearsoffroad safari has been a member for 7 full years
Topics: 17
Alias (AKA): Witman40
Extra Info: AWD Shorty
Postby guyonearth » December 7th 2009, 10:29pm
Let's end the confusion. "Propeller shaft" and "drive shaft" are interchangeable terms. A propeller shaft is referred to as such because it propels the vehicle. AWD Astros have a front and rear driveshaft, and that is how they should be referred to on AWD models to avoid confusion.
guyonearth
Years of Membership: guyonearth has been a member for 7 full yearsguyonearth has been a member for 7 full yearsguyonearth has been a member for 7 full yearsguyonearth has been a member for 7 full yearsguyonearth has been a member for 7 full yearsguyonearth has been a member for 7 full yearsguyonearth has been a member for 7 full years
Topics: 5
Alias (AKA): DeanC
Postby astroturf » December 8th 2009, 12:56am
guyonearth wrote:Let's end the confusion. "Propeller shaft" and "drive shaft" are interchangeable terms. A propeller shaft is referred to as such because it propels the vehicle. AWD Astros have a front and rear driveshaft, and that is how they should be referred to on AWD models to avoid confusion.
Not quite that easy. It could be the shaft that propels the front tire, right or left. Heck, I'd just call the guy up and ask. Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby olalof [OP] » December 8th 2009, 4:44pm
I'm still a bit confused.
Here's a picture of it.
Its 80 cm (31.5 inches) long
olalof
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 18
Postby astroturf » December 8th 2009, 4:50pm
olalof wrote:I'm still a bit confused.
Hey who woulda thunk that a picture could clear this mess up.
That's a draft snake that you would use to keep the draft out. It goes under your front door, NOT.
Olalof, That is in fact your front drive shaft. Jim
astroturf
Topics: 112
Postby olalof [OP] » December 8th 2009, 4:59pm
Thanks!
So would this be the part to buy?
http://cpwstore.carpartswholesale.com/c ... tion=Front
/Ola
olalof
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 18
Postby astroturf » December 8th 2009, 5:03pm
Ola, That looks very expensive. Is there a way to rebuild the one you have? Jim
astroturf
Topics: 112
Postby olalof [OP] » December 8th 2009, 5:06pm
I looked into that (but in sweden everything related to american cars is expensive) and it would cost equivalent of around $600
/Ola
olalof
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 18
Postby offroad safari » December 8th 2009, 5:10pm
RockAuto.com has it for $186.79 + $53.90 for a total of $240.69.... I can't believe how that went up in price. i swore i bought one from here 2 years ago for half that price, but i have been wrong before.
offroad safari
Topics: 17
Postby astroturf » December 8th 2009, 5:11pm
Ola, That is the correct part. Maybe someone will have a suggestion as to how you could do it cheaper though. Jim
astroturf
Topics: 112
Postby $uperJoe » December 8th 2009, 8:04pm
there are different names due to many different things. where people were taught, who taught them, and components involved. your particular shaft has two different joint combinations on it. on the left you will see two u-joints in a h-yoke. this is a double cardigan joint. it has been mislabeled for years among almost all different types of mechanics from 8th grade auto to ase pros as a cv joint. this was never a problem untill an actual cv joint appeared on a drive line as shown on your right. they are great for eliminating very small vibrations in a drive line that are not exactly balanced. unfortunately in comparison to a u-joint there are 6 times more moving parts so they cost more and also are weaker than standard u-joints. some feel that with different terms such as propeller shaft since in fact the drive shaft in the front of the van is a hybrid with multiple joint types they will sound more educated and also with that demand a higher premium for parts and labor on such a part.
a few other things that have different terms
the center differential on an axle is common to be called the pumpkin by older mechanics.
a windshield is known as a wind screen in other parts of the world and on motorcycles.
at that i can make up names for things too. like i could call an air filter an element elimination module. its still the same thing on the car.
Check out my Van build
$uperJoe
Section Moderator
Section Moderator
Firing on 4 Cylinders (L2)
Years of Membership: $uperJoe has been a member for 7 full years$uperJoe has been a member for 7 full years$uperJoe has been a member for 7 full years$uperJoe has been a member for 7 full years$uperJoe has been a member for 7 full years$uperJoe has been a member for 7 full years$uperJoe has been a member for 7 full years
Topics: 59
Postby olalof [OP] » December 8th 2009, 9:39pm
Thanks a lot for all the help!
Would'nt know what do to without this site.
:ty:
Will order the part from rockauto.com
The total is $337 (2400 SEK) with shipping.
The price in sweden was $770 (5500 SEK) so it's a pretty sweet deal.
/Ola
olalof
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 18
Postby astroturf » December 8th 2009, 10:48pm
olalof wrote:Thanks a lot for all the help!
:ty:
/Ola
Good deal Ola, Keep on Vannin. Jim
astroturf
Topics: 112
Return to Automatic
It is currently January 23rd 2017, 3:50pm
Automatic Forum
Moderator: 1297chevastro
Attached by: 00awd
00awd
in Automatic
Comments: 20
Date: Jan 11 '17
Time: 9:13pm
Voltsmith
in Automatic
Date: Dec 26 '16
Time: 4:24am
in Automatic
Comments: 20
Date: Dec 09 '16
Time: 4:54pm
Attached by: markmitch
in Automatic
Comments: 189
Date: Dec 01 '16
Time: 12:51am
theFlyingDutchman
in Automatic
Date: Nov 20 '16
Time: 5:10am
