Transmission Fluid ??
Postby daisykleen [OP] » February 5th 2010, 2:19am
I'm going to change my Transmission Fluid on my 99 astro shortly and would like everyone's choice
on witch fluid is the best Synthetic, Mobil Dexron-VI ATF,Castrol Dexron V Napa brand :confused: :?: :?:
Thank's for the input
daisykleen
Years of Membership: daisykleen has been a member for 8 full yearsdaisykleen has been a member for 8 full yearsdaisykleen has been a member for 8 full yearsdaisykleen has been a member for 8 full yearsdaisykleen has been a member for 8 full yearsdaisykleen has been a member for 8 full yearsdaisykleen has been a member for 8 full yearsdaisykleen has been a member for 8 full years
Topics: 9
Re: Transmission Fluid ??
Postby ihatemybike » February 5th 2010, 3:40am
With Green's fresh trans rebuild I'll only be using Mobile 1 or Amsoil.
Aaron
Prev Astros:99,97,00,94,87,86
ihatemybike
Firing on 6 Cylinders (L2)
Years of Membership: ihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full years
Topics: 67
Postby 01safari » February 6th 2010, 5:23am
I just use whatever name brand Dex III the parts store has. You may want to think about adding a drain plug in the pan. It will make it soo much easier next time. :banana:
01safari
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: 01safari has been a member for 7 full years01safari has been a member for 7 full years01safari has been a member for 7 full years01safari has been a member for 7 full years01safari has been a member for 7 full years01safari has been a member for 7 full years01safari has been a member for 7 full years
Topics: 12
Extra Info: RWD
Postby astroturf » February 6th 2010, 5:32am
My vote is for Amsoil. Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby Astroboy303 » February 6th 2010, 5:35am
i am an amsoil dealer so AMSOIL all the way
thanks munken for the awsome avatar Image
Astroboy303
Years of Membership: Astroboy303 has been a member for 6 full yearsAstroboy303 has been a member for 6 full yearsAstroboy303 has been a member for 6 full yearsAstroboy303 has been a member for 6 full yearsAstroboy303 has been a member for 6 full yearsAstroboy303 has been a member for 6 full years
Extra Info: ZZ4.CE
Postby astro355 » February 6th 2010, 2:59pm
01safari wrote:I just use whatever name brand Dex III the parts store has. You may want to think about adding a drain plug in the pan. It will make it soo much easier next time. :banana:
I agree with this.
Are you talking about changing the filter and topping off the fluid or a complete flush? If you are just replacing the filter and topping off, don't waste the money and just whatever brand your local store sells seeing how you replace 3 quarts or so and not the entire 12 quarts or so that the trans holds.
Also, on a side not, how many miles does the trans have on it? If synthetic was not used in it before, I would not require adding synthetic to it now. Seeing how the trans operates good (assuming that since you aren't talking about any problems), I would not change what type of fluid is already in it. Unless, of course, if you are going to say that it already has synthetic in it.
:think:
astro355
Firing on 4 Cylinders (L6)
Year: 1989
Extra Info: 355 V8 700R4
Postby gtkane » February 7th 2010, 2:42am
What he said...
User album #4...check it out!
gtkane
Years of Membership: gtkane has been a member for 8 full yearsgtkane has been a member for 8 full yearsgtkane has been a member for 8 full yearsgtkane has been a member for 8 full yearsgtkane has been a member for 8 full yearsgtkane has been a member for 8 full yearsgtkane has been a member for 8 full yearsgtkane has been a member for 8 full years
Alias (AKA): Astruck
Extra Info: nasty 4.3
Postby daisykleen [OP] » February 9th 2010, 1:39am
Just seeing what people like :D
daisykleen
Topics: 9
Postby astro355 » February 9th 2010, 1:40am
daisykleen wrote:Just seeing what people like :D
There's just no need to spend more money when you don't have to.
astro355
Year: 1989
Return to Automatic
It is currently January 24th 2017, 2:14pm
Automatic Forum
Moderator: 1297chevastro
Attached by: 00awd
00awd
in Automatic
Comments: 20
Date: Jan 11 '17
Time: 9:13pm
Voltsmith
in Automatic
Date: Dec 26 '16
Time: 4:24am
in Automatic
Comments: 20
Date: Dec 09 '16
Time: 4:54pm
Attached by: markmitch
in Automatic
Comments: 189
Date: Dec 01 '16
Time: 12:51am
theFlyingDutchman
in Automatic
Date: Nov 20 '16
Time: 5:10am
Users browsing this forum: Google Adsense [Bot], MSNbot Media and 2 guests
