Won't shift unless I let off the accelerator
Postby fowler [OP] » March 15th 2010, 8:36pm
Hi, I have a 2000 Astro, V6 RWD with 126,000 miles on it. Since last May, my transmission won't shift from 2-3 without either revving very high or me letting my foot off the gas. When I do let my foot off the gas, it shifts fine. I've replaced the TPS sensor and a solenoid. I've seen this same exact issue described on this forum in the past, but I've never found a solution for it. Does anyone know of a solution? Or is my best bet to get it replaced?
fowler
Years of Membership: fowler has been a member for 7 full yearsfowler has been a member for 7 full yearsfowler has been a member for 7 full yearsfowler has been a member for 7 full yearsfowler has been a member for 7 full yearsfowler has been a member for 7 full yearsfowler has been a member for 7 full years
Alias (AKA): fowler
Extra Info: LS 4.3L V6 RWD
  • van won't reverse
    by Astrodawn » May 25th 2017, 3:32pm in Automatic
    Last post by keith92ext View the latest post
    May 31st 2017, 11:24pm
    75
    June 25th 2017, 11:31am
Re: Won't shift unless I let off the accelerator
Postby fowler [OP] » March 15th 2010, 9:13pm
Well actually it's the 1-2 shift and I just found this too: http://www.gmtruckhq.com/?q=node/93
2. 1-2 shift does not happen at WOT until you let off the gas: Best case: try replacing the TPS. Middle case: leak in the 2nd gear apply circuit (servo assembly or 1-2 accumulator). Doublecheck by using the pressure gauge and watch for a big drop when the PCM commands 2nd gear. Worst case: poor line pressure rise (see below).
I've already tried the TPS, so I guess I'll have to test the pressure next.
fowler
Alias (AKA): fowler
Postby astro355 » March 15th 2010, 9:16pm
So that trans doesn't shift at all during WOT or mild acceleration? I just want to make sure because the 1-2 shift is the first shift and the 2-3 shift is the second one.
astro355
Firing on 4 Cylinders (L6)
Years of Membership: astro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full years
Year: 1989
Extra Info: 355 V8 700R4
Postby fowler [OP] » March 15th 2010, 9:23pm
It's the first shift. Sometimes in the morning it will shift if I'm driving slowly in the neighborhood, but once it starts to warm up, it will only shift if I let off the gas. It will shift at a high RPM, which I'm not really comfortable with, so I let off the gas to make it shift around 25mph usually.
fowler
Alias (AKA): fowler
Postby Soontobeavanowner » March 23rd 2013, 2:18am
Mine is doing the exact same thing.. ever find a solution?
Soontobeavanowner
Years of Membership: Soontobeavanowner has been a member for 4 full yearsSoontobeavanowner has been a member for 4 full yearsSoontobeavanowner has been a member for 4 full yearsSoontobeavanowner has been a member for 4 full years
Topics: 5
Return to Automatic
It is currently June 25th 2017, 11:31am
Automatic Forum
Moderator: 1297chevastro
in Automatic
Comments: 37
Date: May 26 '17
Time: 2:16pm
Attached by: markmitch
in Automatic
Comments: 194
Date: May 24 '17
Time: 7:43pm
in Automatic
Comments: 13
Date: May 18 '17
Time: 7:33pm
Attached by: 97cargocrawler
97cargocrawler
in Automatic
Comments: 13
Date: May 18 '17
Time: 5:33pm
Attached by: 95AstroLT
95AstroLT
in Automatic
Date: May 03 '17
Time: 11:32pm
Users browsing this forum: Google [Bot] and 3 guests
