96 astro awd compatible with 1995 4wd Blazer?
Postby darwindustbin [OP] » September 5th 2010, 5:58pm
Hi,
Im in the uk and have lost 2nd gear on my box - i still have 1st, 3rd and 4th. :screaming:
A rebuild is going to be about £1500 so looking for a second hand box but few and far between in the UK.
I have found a 4wd Blazer 1995/6 - will this box go in?
Also it seems i can lay hands on numerous 4l80e's - would these be any use to me?
Thanks in advance
Paul
(or any easy fixes why i dont have 2nd would be good!)
Cheers
Paul
Chevy Astro 1996 Tiara Royal Star Day van - Japanese import. 4.3L AWD, A/c
darwindustbin
Years of Membership: darwindustbin has been a member for 2 full yearsdarwindustbin has been a member for 2 full years
Alias (AKA): paul
Extra Info: 4.3 V6 AWD Tiara
Re: 96 astro awd compatible with 1995 4wd Blazer?
Postby Leeann_93 » September 6th 2010, 1:55am
darwindustbin wrote:Hi,
Thanks in advance
Paul
If the donor tranny has PWM stamped on it, you should be able to make it work (pulse width modulated) since it's from a 4x4 and you have AWD. If it doesn't say PWM, it will not work.
Do you still have reverse or is that gone, too? Generally, you're looking at a destroyed sun shell if 2nd and reverse are gone, which essentially requires a rebuild.
One rebuild here:
http://www.gmhightechperformance.com/tech/0905gmhtp_century_stage_iii_4l60e_automatic_transmission_rebuild/photo_01.html
And a more in-depth rebuild here:
http://www.wwdsltd.com/4L60/4L60ERepairs.html
'02 Astro SL AWD vin X
Years of Membership: Leeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full years
Topics: 17
Images: 3
Year: 2002
Extra Info: SL 4.3L AWD
Postby darwindustbin [OP] » September 6th 2010, 9:56am
Thanks for the reply - i do still have reverse.
When it tries to change into 2nd it seems to rev as if in neutral. I have had no horrible noises and it started after being sat in 4th towing for about an hour.
Ay other ideas?
Thanks
Paul
Cheers
Paul
darwindustbin
Alias (AKA): paul
Postby Leeann_93 » September 6th 2010, 2:41pm
Then I'd check your 1-2 shift solenoid. Sounds like it might be stuck/failing. You'll have to drop the pan, so it's a good time to replace the filter. The solenoids are cheap, so I'd say change 'em all (they all will fail eventually).
Topics: 17
Images: 3
Year: 2002
Postby cowboydan » September 17th 2010, 2:25am
Leeann_93 wrote:Then I'd check your 1-2 shift solenoid. Sounds like it might be stuck/failing. You'll have to drop the pan, so it's a good time to replace the filter. The solenoids are cheap, so I'd say change 'em all (they all will fail eventually).
most people believe that when anything goes wrong with the tranny it's toast.... nice :banana:
2006 sebring 2.7 touring: DD
1980 buick regal sport coupe? ??
cowboydan
Firing on 7 Cylinders (L2)
Years of Membership: cowboydan has been a member for 2 full yearscowboydan has been a member for 2 full years
Topics: 64
Alias (AKA): cbd
Year: 1997
Extra Info: 4.3w CL AWD
Postby Leeann_93 » September 17th 2010, 2:33am
^ The bf's dad was an auto tranny specialist way back when they were voodoo boxes (for Nash, Chevy & Pontiac before opening his own shop) - I have but learned a very, very little (they're still voodoo boxes to me). His uncle also was a GM Goodwrench mechanic who was THE goodwrench for at least the Eastern US and possibly the whole US.
Topics: 17
Images: 3
Year: 2002
Return to Automatic
It is currently May 22nd 2013, 9:35pm
Automatic Forum
Moderator: 1297chevastro
Attached by: Jasen
in Automatic
Date: May 05 '13
Time: 4:27pm
gollihughj
in Automatic
Date: May 02 '13
Time: 12:21am
gollihughj
in Automatic
Date: Apr 13 '13
Time: 3:22am
Drummernaut
in Automatic
Date: Apr 02 '13
Time: 8:45pm
pcengine92
in Automatic
Date: Mar 18 '13
Time: 10:59pm
