The truck was cruising about 65 ( going downhill not under a load) when i felt a noticeable down shift. I exited the highway and it started to grind and could smell burning clutches. I stalled the truck after rolling for a short time. ( torque converter must have been still engaged ) . I restarted the truck and tried it in reverse, it went with a grind. I put back in low 1 and as long as i kept the speed below 5 mph it went without much noise. I drove it home about 3 miles. After about 1 mile I was able to increase the speed to 30 mpg without noise or any clutch burning. As I closer to home I got it up to 45 mph.
The noise came from the front wheels not the transfer case. Any Ideas? front axle, case?
Mark
