5 speed without astro specific shifter
Postby Intenseman [OP] » June 4th 2016, 4:05am
Has anyone used a 5 speed without the astro specific shifter? I was wondering about a bending/welding a shifter to get the business end over to the driver. Has anyone done this install?
Thanks
'95 GMC Safari 2wd
Intenseman
Years of Membership: Intenseman has been a member for 9 full yearsIntenseman has been a member for 9 full yearsIntenseman has been a member for 9 full yearsIntenseman has been a member for 9 full yearsIntenseman has been a member for 9 full yearsIntenseman has been a member for 9 full yearsIntenseman has been a member for 9 full yearsIntenseman has been a member for 9 full yearsIntenseman has been a member for 9 full years
Re: 5 speed without astro specific shifter
Postby AstrofarianAstrofarian is online! » June 4th 2016, 7:15am
I'm thinking ANYTHING is possible; But I would think twice about "Bending up a shifter". I tried that in the 70's with one of those abysmally BAD 3-spd floor shift conversion kits in a pickup truck. The column shift was toast so I thought that this was going to be an "upgrade". These kits were infamous for having the shift feel of trying to row through a river of liquid pig manure using a paddle made out of wet noodles. And that was with the handle that came with the kit. Start "adapting" and altering things and it only gets worse. And flex only gets worse as the handle gets longer.
Try to find an original handle even if it's only on loan long enough to trace it as a template onto a piece of 1/2" thick steel. Just my humble opinion. Hope this works out for you; manual transmissions are awesome!
-Mike-
Cheer up....things could be worse! Look at me...I cheered up & SURE ENOUGH...things got worse! Bwahahahaha......ahem...sorry.....snicker
Firing on 8 Cylinders (L2)
Years of Membership: Astrofarian has been a member for 3 full yearsAstrofarian has been a member for 3 full yearsAstrofarian has been a member for 3 full years
Topics: 13
Alias (AKA): M!ke
Year: 1991
Extra Info: 700000 km plus
Postby WoodButcherWoodButcher is online! » June 4th 2016, 3:37pm
5 speed what? auto? manual?
4l60 or 700r are 4 speed auto that can be converted from rod linkage to cable, the manual trans has an offset shifter linkage that would be a biatch to fabricate but if you had one from another vehicle that had an offset that was of different dimensions it should still work but in a different location.
Firing on 7 Cylinders (L5)
Topics: 28
Images: 454
Alias (AKA): Bruce
Year: 1997
Extra Info: 4.3 RWD
Postby markmitch » June 4th 2016, 5:16pm
do an online junkyard search for the parts , I was interested in doing this about a year ago and found some parts online that way but decided not to go standard trans due to a bad right shoulder.
Firing on 3 Cylinders (L4)
Years of Membership: markmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full years
Topics: 440
Images: 5
Alias (AKA): Astro gearhead
Year: 1989
Extra Info: RS 350 TBI
Postby sixsix » June 4th 2016, 7:55pm
Astrofarian wrote: ... trying to row through a river of liquid pig manure using a paddle made out of wet noodles.
There is No Better Description for Anything. Period.
Mike
The Van's Build: viewtopic.php?f=127&t=59385
"Though the hippopotamus has no sting, the wise man would prefer to be sat upon by the bee."
- Banacek
Firing on 7 Cylinders (L2)
Years of Membership: sixsix has been a member for 3 full yearssixsix has been a member for 3 full yearssixsix has been a member for 3 full years
Topics: 21
Images: 880
Year: 1992
Extra Info: LT W-CPI Motor 200K
Postby icebrrg3rd » June 6th 2016, 8:26pm
Intenseman wrote:Has anyone used a 5 speed without the astro specific shifter? I was wondering about a bending/welding a shifter to get the business end over to the driver. Has anyone done this install?
Thanks
YES! I used the V-8 & 5-speed out of a Silverado. Both my vehicles were '91, and had no (major) problems with it.
PROS:
--Truck vs car trans (Camaro, Vette, etc) puts the shifter in a spot that is easily within reach of the driver
--Plenty available for cheap - buy a rusted out truck as a donor
--Use the brains from the truck
--Ok for stock V-8 engine, if it's a pre-NG3500 5-speed (mine) they aren't as hardy if you want to drag race (be gentle!)
--Get it with a V-8 and you'll have all the proper equipment to mount it
CONS:
--Using the Silverado instead of one from a S-10 means a shorter overall transmission = new driveshaft (S-10 I heard was same length as auto trans)
--Angle of the shifter is a little off, will try bending it slightly to get a better position, it is close to the driver's seat in 2nd gear
--Silverado has a lower 1st gear than the S-10, almost a granny gear
--I had to cut one of the braces for the van because of the shifter location
--I had to make a custom trans mount due to a different location (not sure if the S-10 one would be better)
I used the shifter arm from an Astro instead of the long one from the truck, just unscrewed the old one and put the new one on.
Here's some pics-
V-8 & trans:
Shifter placement (test location):
Shifter actual location:
Underside showing brace I had to cut:
If you want more pics or info, I have a bunch. Only problem is my van developed a rod knock, and is now located 2 hours north of me, so I don't have easy access to it right now.
-Andrew
81 Yamaha Maxim 650XJ 650cc 67k mi
83 Yamaha Venture 1300cc 92k mi
91 Chevy Astro 5.0L 5-speed, Ford 9" 250k mi
02 Chrysler Sebring Conv. 2.7L 5-speed 189k mi
10 Chrysler Town & Country 3.8L 134k mi
icebrrg3rd
Years of Membership: icebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full years
Topics: 43
Alias (AKA): Andrew
Year: 1991
Postby Intenseman [OP] » July 12th 2016, 5:01pm
Is there a difference in the Astro T5 trannys that were behind the V6 vs 4 cylinder?
Thanks
'95 GMC Safari 2wd
Intenseman
Postby Intenseman [OP] » July 15th 2016, 3:16pm
Bump
'95 GMC Safari 2wd
Intenseman
Postby markmitch » July 15th 2016, 4:18pm
the 4 cylinder trans has less strength even if you got it to bolt to a V8 it most likely would not last long. I have a 700R4 with a floor shift and I had to cut a window into the cross member otherwise the cable would bind due to the bend. But what I did was cut a 3 x 6 inch hole into the cross member then weld flat steel bar stock I bought from the local hardware store around both sides of the hole to make it strong again. If you need pictures just let me know.
Topics: 440
Images: 5
Year: 1989
Return to Manual
It is currently May 30th 2017, 12:17pm
Manual Forum
ManualGM Astro/Safari vans were produced with a 4-speed manual or a 5-speed manual transmission. Manual transmissions feature a driver-operated clutch and a movable gear stick which are commonly swapped with automatics in custom applications and transmission conversions.
Moderator: 1297chevastro
To create a new topic in Manual, click this button:
Attached by: icebrrg3rd
icebrrg3rd
in Manual
Date: Jun 06 '16
Time: 8:18pm
doyoulikeithere
in Manual
Date: Jan 22 '12
Time: 10:25pm
Casey
in Manual
Date: Nov 14 '09
Time: 9:32pm
Attached by: SS Astro
SS Astro
in Manual
Comments: 19
Date: Jul 21 '09
Time: 6:45am
SS Astro
in Manual
Comments: 19
Date: Jul 20 '09
Time: 12:48am
