mechanical to VSS
mechanical to VSS
Postby Intenseman [OP] » September 22nd 2016, 4:08am
Hello. I'm working on a T5 swap. I believe I have an '88 Astro specific T5. It has the cable driven speedo. I need to upgrade to VSS. I did a similar thing on my '77 IH Scout to run a digital speedo. I saw a bunch of options on jagsthatrun.com. However, they are recommending the 40 tooth differential mounted reluctor ring. I'd much rather prefer use something that goes in the hole that drives the cable speedo. Any ideas?
Thanks,
Michael
'95 GMC Safari 2wd
Intenseman
Years of Membership: Intenseman has been a member for 9 full yearsIntenseman has been a member for 9 full yearsIntenseman has been a member for 9 full yearsIntenseman has been a member for 9 full yearsIntenseman has been a member for 9 full yearsIntenseman has been a member for 9 full yearsIntenseman has been a member for 9 full yearsIntenseman has been a member for 9 full yearsIntenseman has been a member for 9 full years
Re: mechanical to VSS
Postby AstroWill » January 1st 2017, 7:53am
Swap the tailshaft to one that uses a VSS?
Topics: 62
Images: 108
Extra Info: 90TigerGTv8 03AWD
Postby chevymaherchevymaher is online! » January 1st 2017, 4:44pm
There is something on the output shaft. A magnet that needs to go on the part that stays with the trans. Needs to look into that. It is pressed on.
Topics: 82
Year: 1994
Postby IronDookie » January 10th 2017, 4:27am
Possibly the easiest way (other than finding an 89 astro T5 tailhouse)
Is to modify a rear shift Camaro vss tailhouse into a mid (Astro) shift. This is done by cutting away a section of the Camaro tailhouse and installing an aluminum box that will align with the stock Astro shifter position. The Camaro rear detents in the rear tailshift box are retained, but the mod in essence, uses the the new (mid) shift box for purpose of grabbing hold of the shift rails....I know old truck guys do this mod to put the shifter in front of the bench style seats when they can't find the now rare (and expensive) S-10 cable driven (front Shift) tailhouses. they do it to use cable speedo, you'd do it to use VSS T5. Same procedure but in reverse.
IronDookie
Year: 1985
Extra Info: 151 T4 RWD
Return to Manual
It is currently March 30th 2017, 3:38pm
Manual Forum
ManualGM Astro/Safari vans were produced with a 4-speed manual or a 5-speed manual transmission. Manual transmissions feature a driver-operated clutch and a movable gear stick which are commonly swapped with automatics in custom applications and transmission conversions.
Moderator: 1297chevastro
To create a new topic in Manual, click this button:
Attached by: icebrrg3rd
icebrrg3rd
in Manual
Date: Jun 06 '16
Time: 8:18pm
doyoulikeithere
in Manual
Date: Jan 22 '12
Time: 10:25pm
Casey
in Manual
Date: Nov 14 '09
Time: 9:32pm
Attached by: SS Astro
SS Astro
in Manual
Comments: 19
Date: Jul 21 '09
Time: 6:45am
SS Astro
in Manual
Comments: 19
Date: Jul 20 '09
Time: 12:48am
