seen today in pnp yard 4cyl/5speed
Postby markmitch [OP] » November 26th 2016, 4:44am
Today I went to pick n pull and after I got my parts I walked around a bit to look at other astro/safari's and came upon a 1987 Astro with all original 4 cylinder/5 speed trans combo. If anyone is close enough to stockton Ca its there now for the pickin. I would offer to get the parts but its the end of the month and I do not get paid again till the first. I looked into the set up for the clutch pedal and it appears to have sheet metal parts welded into the inside of the firewall to hold the pedal assembly so bring your battery operated sawzall.
Firing on 2 Cylinders (L4)
Years of Membership: markmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full years
Topics: 433
Images: 5
Alias (AKA): Mitch
Year: 1989
Extra Info: RS 350 TBI
Re: seen today in pnp yard 4cyl/5speed
Postby srdragonusa » November 26th 2016, 5:38pm
Nice find. I've been to Stockton it's a haul for me. Good luck to those that want it.
P@ul AKA SR Dragon
2003 AWD Astro
1995 Toyota Tacoma 4x4
2012 Nissan Xterra Pro4X (wife's)
srdragonusa
Images: 88
Alias (AKA): Paul
Year: 2003
Postby sixsix » November 26th 2016, 10:19pm
Wasn't the Manual trans offered in the Astro originally a 4 speed ?
Sounds like the 5 speed was "jury-welded" in later in life.
Mike
The Van's Build: viewtopic.php?f=127&t=59385
There are 3 types of people in this world - First, the type that can count
and Second, the type that can't.
Firing on 6 Cylinders (L2)
Years of Membership: sixsix has been a member for 2 full yearssixsix has been a member for 2 full years
Topics: 21
Images: 874
Year: 1992
Extra Info: LT W-CPI Motor 200K
Postby AstroWill » November 26th 2016, 11:54pm
The 5-speed manual was always available, through 89, but a 4 speed manual was available for the first couple/few years. All that I have seen are the 5 speed, so not sure on production numbers for the 4 speed manual.
Topics: 60
Images: 87
Extra Info: 90TigerGTv8 03AWD
Postby markmitch [OP] » November 27th 2016, 5:41am
I guess its possible for it to be a 4 speed I just assumed it to be a 5 speed because I never seen a 4 speed in an Astro. I just posted it cause many folks in this club looking for the parts to swap to a standard trans. Today it rained all day but tomorrow will be sunny in the 60's so its 50% off this weekend if anyone is close by its possibly one of the last of these standard trans equipped Astro/Safari vans left to get the clutch pedal assembly from.
Topics: 433
Images: 5
Alias (AKA): Mitch
Year: 1989
Postby IronDookie » January 11th 2017, 12:10am
sixsix wrote:Wasn't the Manual trans offered in the Astro originally a 4 speed ?
Mike
As discussed in my other thread, I have a 4cyl 4spd and the guy I bought if from showed it to some GM rep that worked on the M van project and knew the production numbers (or rather guesstimated off the top of his head) that there were very few 4cyl 5 speeds ordered, 200 or so. It would be interesting to confirm this.
The only reason I could think of for such low numbers is that the option was unnecessary compared to the adequate "standard" 4 speed and buyers looking for a 4cyl and manual trans were cheap skates... I.e. business fleets that were ordering multiple units.
(Don't quote me on that number because I don't now if it was for 1985 only, or the whole first gen production run.)
IronDookie
Year: 1985
Extra Info: 151 T4 RWD
Postby markmitch [OP] » January 11th 2017, 12:58am
They stopped after 89/90 putting any standard transmissions The year they stopped I am not sure of but the only other one I seen was at a car show in Maine and I believe it was an 89. The owner used it to drive to car shows in the New England areas. He said it was great on gas and fun to drive. But his was a 4.3 with standard and I do not know if it was a 4 or 5 speed.
Topics: 433
Images: 5
Alias (AKA): Mitch
Year: 1989
Postby IronDookie » January 11th 2017, 2:45am
markmitch wrote: his was a 4.3 with standard and I do not know if it was a 4 or 5 speed.
I can almost guarantee it was a 5 speed with the VSS tailhouse (which was only available for 1989). There was also a very rare manual transmission digital dash.
BTW I'm not referring to all T5 Astro's.... just the 4 cylinder T5's. There was no doubt, many more v6's produced with the 5 speed
IronDookie
Year: 1985
Return to Manual
It is currently March 28th 2017, 9:10am
Manual Forum
ManualGM Astro/Safari vans were produced with a 4-speed manual or a 5-speed manual transmission. Manual transmissions feature a driver-operated clutch and a movable gear stick which are commonly swapped with automatics in custom applications and transmission conversions.
Moderator: 1297chevastro
To create a new topic in Manual, click this button:
Attached by: icebrrg3rd
icebrrg3rd
in Manual
Date: Jun 06 '16
Time: 8:18pm
doyoulikeithere
in Manual
Date: Jan 22 '12
Time: 10:25pm
Casey
in Manual
Date: Nov 14 '09
Time: 9:32pm
Attached by: SS Astro
SS Astro
in Manual
Comments: 19
Date: Jul 21 '09
Time: 6:45am
SS Astro
in Manual
Comments: 19
Date: Jul 20 '09
Time: 12:48am
