Hard shift into reverse sometimes
Postby imavanner [OP] » October 12th 2014, 6:50pm
Sometimes I get a hard shift ito reverse like a grind
Would that be related to the clutch cylinders
my van is an 88 safari sle 5speed manual
imavanner
Years of Membership: imavanner has been a member for 2 full yearsimavanner has been a member for 2 full years
Topics: 9
Alias (AKA): fungalixie
Year: 1988
Extra Info: SLE 5-Speed Manual
Re: Hard shift into reverse sometimes
Postby zzimmer3 » October 12th 2014, 9:04pm
I'm no expert, but I've found in my manual s10s that if I go into 5th, then drop it into reverse it won't grind. I've heard people speak of synchronizers before being an issue, but I'm not sure. Someone with more knowledge will chime in im sure.
2001 GMC Safari AWD (not driving yet)
1994 Astro sold with over 200,000miles, feared MIA
zzimmer3
Years of Membership: zzimmer3 has been a member for 3 full yearszzimmer3 has been a member for 3 full yearszzimmer3 has been a member for 3 full years
Topics: 41
Images: 25
Alias (AKA): teddybear
Year: 2000
Extra Info: LT AWD
Postby chevymaher » October 12th 2014, 9:14pm
Yes if the clutch needs bled and isn't disengaging correctly. That will make it grind.
As posted above it is a synchronization issue. Reverse has no synchro's. Put it in first before going for reverse. That stops the rotating parts in the trans so when you shift into reverse they are stationary.
Topics: 78
Year: 1994
Postby imavanner [OP] » October 12th 2014, 11:17pm
Doesn't always happen I don't think
I have done the first gear as.you mentioned and it helped
When I put a big load on 5th feels like there may be some vibration from flywheel. Could that be from the flywheel as it was resurfaced rather than being replaced
Guy I got from had someone look at.it and said needs a clutch slave cylinder and a tps sensor
imavanner
Topics: 9
Year: 1988
Return to Manual
It is currently January 16th 2017, 11:46am
Manual Forum
ManualGM Astro/Safari vans were produced with a 4-speed manual or a 5-speed manual transmission. Manual transmissions feature a driver-operated clutch and a movable gear stick which are commonly swapped with automatics in custom applications and transmission conversions.
Moderator: 1297chevastro
To create a new topic in Manual, click this button:
Attached by: icebrrg3rd
icebrrg3rd
in Manual
Date: Jun 06 '16
Time: 8:18pm
doyoulikeithere
in Manual
Date: Jan 22 '12
Time: 10:25pm
Casey
in Manual
Date: Nov 14 '09
Time: 9:32pm
Attached by: SS Astro
SS Astro
in Manual
Comments: 19
Date: Jul 21 '09
Time: 6:45am
SS Astro
in Manual
Comments: 19
Date: Jul 20 '09
Time: 12:48am
