Clutch Pedal Wanted
Clutch Pedal Wanted
Postby Yellow-Checkers [OP] » February 28th 2015, 5:59am
Does anyone have or know of where i can get an OEM clutch pedal, I have a Low 11 second BB 427 87 cargo with a powerglide, and have thought about putting a Tremec TKO 600 in it. I can fab a nice one using a partial brake pedal so they match but OEM would be much easier. I do have a picture of an OEM but thats all i can find.
Yellow-Checkers
Years of Membership: Yellow-Checkers has been a member for 2 full yearsYellow-Checkers has been a member for 2 full years
Year: 1987
Extra Info: BB 427 Tubbed
Re: Clutch Pedal Wanted
Postby Roger Ramjet » February 28th 2015, 9:59pm
Would a pick up truck one work ?? I don't have one but I think it would be an easier find
1997 Astro Van
Roger Ramjet
Years of Membership: Roger Ramjet has been a member for 3 full yearsRoger Ramjet has been a member for 3 full yearsRoger Ramjet has been a member for 3 full years
Topics: 9
Images: 11
Alias (AKA): Roger Ramjet
Year: 1997
Extra Info: 2WD 4.3
Postby markmitch » February 28th 2015, 10:30pm
try searching the online salvage parts sites I looked into this idea myself and found a few parts through the online used parts sites. Good luck
Firing on 2 Cylinders (L4)
Years of Membership: markmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full years
Topics: 436
Images: 5
Alias (AKA): Astro gearhead
Year: 1989
Extra Info: RS 350 TBI
Postby Roger Ramjet » February 28th 2015, 10:48pm
www.car-part.com .. that site will allow you to search pretty well all wrecking yards in North America .
1997 Astro Van
Roger Ramjet
Topics: 9
Images: 11
Year: 1997
Extra Info: 2WD 4.3
Postby icebrrg3rd » March 2nd 2015, 4:24pm
Every now and then you see a craigslist ad for a stick shift Astro, but they're kinda rare, and being that they stopped making them with stick over 25 years ago, a lot have most likely gone to the boneyard in the sky. It is just pure luck to stumble across one.
For the record, a full-size p/u clutch pedal is about 2" longer than an Astro one, haven't checked out the S-10 ones.
Since you've actually modded (Low 11 second BB 427 87 cargo with a powerglide, and have thought about putting a Tremec TKO 600 in it) I say look into tinworm's build, he put an aftermarket clutch pedal in, might be a viable option for you.
-Andrew
81 Yamaha Maxim 650XJ 650cc 67k mi
83 Yamaha Venture 1300cc 92k mi
91 Chevy Astro 5.0L 5-speed, Ford 9" 250k mi
02 Chrysler Sebring Conv. 2.7L 5-speed 189k mi
10 Chrysler Town & Country 3.8L 134k mi
icebrrg3rd
Firing on 8 Cylinders (L2)
Years of Membership: icebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full years
Topics: 43
Alias (AKA): Andrew
Year: 1991
Postby Roger Ramjet » March 2nd 2015, 8:44pm
I was thing S-!0 as well after I posted my comment about pick up trucks .
Andrew .... good to see another vintage Yamaha owner . I have 1982 XV 920 J Virago
1997 Astro Van
Roger Ramjet
Topics: 9
Images: 11
Year: 1997
Extra Info: 2WD 4.3
Clutch Pedal Wanted
Postby Alexander_Rychok » March 20th 2015, 9:11am
Im having trouble finding a clutch pedal that will work for a cable clutch, all I can find are ones that only work with hydraulic clutches and have a master cylinder on them. Any ideas?
Alexander_Rychok
Years of Membership: Alexander_Rychok has been a member for 2 full yearsAlexander_Rychok has been a member for 2 full years
Postby chevymaher » March 20th 2015, 1:22pm
Alexander_Rychok wrote:Im having trouble finding a clutch pedal that will work for a cable clutch, all I can find are ones that only work with hydraulic clutches and have a master cylinder on them. Any ideas?
I can understand having trouble finding a cable clutch system. What used them? Use what you can find or make your own.
Topics: 82
Year: 1994
Postby bubbalowe » March 20th 2015, 1:34pm
I'm would like to see a clutch set up in an Astro van because that would really put some fun back into driving + better mileage. I'm not sure if I could operate it with triple EEE boots though and the wheel hump.
bubbalowe
Years of Membership: bubbalowe has been a member for 4 full yearsbubbalowe has been a member for 4 full yearsbubbalowe has been a member for 4 full yearsbubbalowe has been a member for 4 full years
Topics: 13
Alias (AKA): Bubba
Year: 1997
Extra Info: AWD CONVERSION 5.7 V
Postby markmitch » April 25th 2015, 4:37pm
I would like to see either some mechanical drawings of the clutch pedal or some pictures myself if anyone has any for the Astro/Safari?
Topics: 436
Images: 5
Year: 1989
Postby markmitch » April 25th 2015, 5:44pm
see the next post-I screwed this one up
Topics: 436
Images: 5
Year: 1989
Postby markmitch » April 25th 2015, 5:45pm
check this post yellow-checkers, you can probably get all the stuff you need from him, I am sticking with my auto trans
viewtopic.php?f=68&t=75433
Topics: 436
Images: 5
Year: 1989
Postby Yellow-Checkers [OP] » November 30th 2015, 10:28pm
Just to update, found a complete 1986 4.3 5spd van in decent shape for $200. I don't think the seller realized how rare the manual trans is. Cant wait to do a TKO 600 conversion.
Yellow-Checkers
Year: 1987
Postby chevymaher » November 30th 2015, 10:54pm
Good deal.
Topics: 82
Year: 1994
Postby AstroWill » November 30th 2015, 11:33pm
Awesome deal!
Where is your build thread?
Firing on 1 Cylinder (L6)
Topics: 63
Images: 111
Extra Info: 90TigerGTv8 03AWD
Return to Manual
It is currently April 26th 2017, 2:49pm
Manual Forum
ManualGM Astro/Safari vans were produced with a 4-speed manual or a 5-speed manual transmission. Manual transmissions feature a driver-operated clutch and a movable gear stick which are commonly swapped with automatics in custom applications and transmission conversions.
Moderator: 1297chevastro
To create a new topic in Manual, click this button:
Attached by: icebrrg3rd
icebrrg3rd
in Manual
Date: Jun 06 '16
Time: 8:18pm
doyoulikeithere
in Manual
Date: Jan 22 '12
Time: 10:25pm
Casey
in Manual
Date: Nov 14 '09
Time: 9:32pm
Attached by: SS Astro
SS Astro
in Manual
Comments: 19
Date: Jul 21 '09
Time: 6:45am
SS Astro
in Manual
Comments: 19
Date: Jul 20 '09
Time: 12:48am
