What is the difference between the 2057 and 1157 bulb
Postby 94 Van Guy [OP] » February 12th 2011, 11:17pm
In the owners manual it calls for a 2057 Park, Signal Lamp. When I do a search for a 2057 bulb most all of the adds say there is no difference. I have spent some time doing a search here and have not found an answer. :mrgreen:
Does someone know if a 1157 bulb will work as a turn signal lamp in my 1994 Safari van?
Any help or experience with this is most welcome.
Thanks for your time,
Keith
'91 Chevy G30 Bus 39.3K Miles
Retired
Safari
87 Safari, 91 Astro
86 Astro, 85 Astro
88 Astro, 92 Astro
89 Astro, 88 Astro
94 Van Guy
Firing on 5 Cylinders (L3)
Years of Membership: 94 Van Guy has been a member for 6 full years94 Van Guy has been a member for 6 full years94 Van Guy has been a member for 6 full years94 Van Guy has been a member for 6 full years94 Van Guy has been a member for 6 full years94 Van Guy has been a member for 6 full years
Topics: 71
Images: 44
Alias (AKA): Keith
Year: 1991
Extra Info: G30 Bus
Re: What is the difference between the 2057 and 1157 bulb
Postby chevymaher » February 13th 2011, 12:00am
I just went down and looked.Sylvania 2057 what I using I still got the package.Got them at Wal mart.I dont have 1157 but I do have 1156 bulbs in my junk in the trunk section downstairs.I used to do this junk at work.I dont have catalog but usually they follow suit.Physically it will fit.But the 20 sieries bulbs have two filiments and 2 contacts on bottom.The 11 sieries only has one filament and one center contact on bottom.My fog lamps on my van are a completely different number than what it calls for so it still possible.Take your old bulb and size it up against one you looking at.Two pins on side of bulb at different heights must match and have 2 contacts on bottom 2 filaments.Sorry I did not have that bulb to be sure.
Topics: 79
Year: 1994
Postby Phantom » February 13th 2011, 12:44am
1156 has only 1 filament usually used for back up lights , 1157 has 2 contacts and 2 filaments one for stop/hazard and one for tail/park/running lamps . The 2057 are a newer version of the 1157 that burn brighter but are used for the same purpose as the 1157
Phantom
Firing on 7 Cylinders (L4)
Postby chevymaher » February 13th 2011, 1:11am
Phantom wrote:1156 has only 1 filament usually used for back up lights , 1157 has 2 contacts and 2 filaments one for stop/hazard and one for tail/park/running lamps . The 2057 are a newer version of the 1157 that burn brighter but are used for the same purpose as the 1157
And thats why you da man
Topics: 79
Year: 1994
Postby 94 Van Guy [OP] » February 13th 2011, 9:58pm
Thanks guys, I guess the email notification isn't working. I will see if they are bright enough.
Keith
Retired
Safari
87 Safari, 91 Astro
86 Astro, 85 Astro
88 Astro, 92 Astro
89 Astro, 88 Astro
94 Van Guy
Topics: 71
Images: 44
Alias (AKA): Keith
Year: 1991
Extra Info: G30 Bus
Postby maximus7001 » February 17th 2011, 6:54am
Beware when trying to use a 2057 in a car that is suposed to use an 1157. The lense might melt. Had this happen once in my first car, the shop put one in and did not tell me and in short order there was a melted spot where the bulb gets close.
97 Safari SLT AWD
68 AMC Javelin SST
85 AMC Eagle wagon 4x4
97 Ford Contour
maximus7001
Years of Membership: maximus7001 has been a member for 8 full yearsmaximus7001 has been a member for 8 full yearsmaximus7001 has been a member for 8 full yearsmaximus7001 has been a member for 8 full yearsmaximus7001 has been a member for 8 full yearsmaximus7001 has been a member for 8 full yearsmaximus7001 has been a member for 8 full yearsmaximus7001 has been a member for 8 full years
Topics: 9
Year: 1997
Extra Info: AWD 380000km
Postby RECox286 » February 17th 2011, 1:20pm
:goodpost:
Thx for the headsup.
Bob
RECox286
Topics: 37
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [325K mi]
It is currently January 18th 2017, 11:11pm
Moderator: tedanderson
Attached by: chevymaher
Comments: 24
Date: Jan 14 '17
Time: 12:02am
Comments: 24
Date: Jan 13 '17
Time: 10:49pm
Attached by: astrotardis
astrotardis
Date: Jan 12 '17
Time: 9:01pm
astrotardis
Date: Jan 12 '17
Time: 2:46am
Comments: 27
Date: Jan 08 '17
Time: 3:07am
