Overhead Console wiring
Postby Black89cs [OP] » March 13th 2011, 7:42pm
So I finally picked up the wiring harness for the overhead console that I'm going to (eventually) put in the 97. The blue connector has two yellow and and one black wire that ran to a different connector by the drivers side kick panel. I'm assuming there's two power and one ground, but I'm not sure if they're always on or key on (or both, one is key the other is always on). Any ideas? Would anyone care to check the connector on their with a multimeter to see what happens?
Black89cs
Firing on 8 Cylinders (L1)
Years of Membership: Black89cs has been a member for 8 full yearsBlack89cs has been a member for 8 full yearsBlack89cs has been a member for 8 full yearsBlack89cs has been a member for 8 full yearsBlack89cs has been a member for 8 full yearsBlack89cs has been a member for 8 full yearsBlack89cs has been a member for 8 full yearsBlack89cs has been a member for 8 full years
Topics: 81
Alias (AKA): Matt
Year: 1997
  • Wiring harness issue
    by skip bevins » August 29th 2016, 11:36pm in Electrical
    Last post by skip bevins View the latest post
    August 30th 2016, 1:06am
  • Reverse light wiring
    by Astrobozz » September 21st 2016, 8:31am in Electrical
    Last post by Astrobozz View the latest post
    September 28th 2016, 3:36pm
    54
    February 24th 2017, 4:38am
Re: Overhead Console wiring
Postby chevy57bert » March 13th 2011, 7:57pm
This the only Diagram I have with the Yellow wires in it....
Overhead Console Wiring
chevy57bert
Section Moderator
Section Moderator
Firing on 7 Cylinders (L3)
Topics: 67
Images: 33
Alias (AKA): Bertjuh
Year: 1992
Extra Info: Ext 4.3L rwd
Postby Black89cs [OP] » March 13th 2011, 8:23pm
Thanks Bert. The van I pulled my harness out of was a 2000 or newer (5 lug but had tow/haul mode on the shifter lever), so one of those yellow lines may be extra. That may be the MPG wire that's on the newer consoles but since Mine's a 97 it'll likely just have the temp without the compass. I'll have to give it a shot and see what happens.
Black89cs
Topics: 81
Alias (AKA): Matt
Year: 1997
It is currently February 24th 2017, 4:38am
Moderator: tedanderson
Attached by: markmitch
Date: Feb 18 '17
Time: 1:11am
One-Eye
Comments: 21
Date: Feb 17 '17
Time: 4:58am
One-Eye
Date: Feb 17 '17
Time: 1:58am
kristuphir
Date: Jan 21 '17
Time: 8:46am
mweir
Comments: 75
Date: Jan 20 '17
Time: 1:34am
