wipers not working
wipers not working
Postby DaveAstro [OP] » April 1st 2011, 7:02pm
ok, on the 93, the wipers don't work.
I followed the diagnostics in the shop manual, testing the switch, and wiring, etc. and it told me to replace the wiper pulse module, so I swapped it with the 90.
both modules work im the 90, neither works in the 93
if I ground out the wiper motor to the chasis, the wipers work on low, constantly as long as the key is on.. doesn't matter what position the switch is in.
anyone have this problem before?
Dave ASTRO, WebMaster - Vannin.Com
90 Astro,"the grey ghost", Haulin A$$, Not kids.
93 Safari, "Lunavan"
E-Z Vanners of Mass, Maine, NY, NJ, England and Finland!!
DaveAstro
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: DaveAstro has been a member for 2 full yearsDaveAstro has been a member for 2 full years
Alias (AKA): Dave ASTRO
Re: wipers not working
Postby oldtymehockey » April 1st 2011, 7:23pm
Take the cover off the wiper motor and look at the board. The traces on the board get broke or interrupted.
I ran a strand of wire to recreate a trace on mine and solved the same issue you are having. Honestly the strand of wire is a bandaid fix and I don't expect it to last too long. When it fails agian I will just replace the enitre wiper motor.
1998 Astro AWD close to 300k
oldtymehockey
Years of Membership: oldtymehockey has been a member for 2 full yearsoldtymehockey has been a member for 2 full years
Alias (AKA): Ekim
Extra Info: AWD BASE
Postby DaveAstro [OP] » April 1st 2011, 7:26pm
oldtymehockey wrote:Take the cover off the wiper motor and look at the board. The traces on the board get broke or interrupted.
that board would be the wiper pulse module, that I said I swapped out between vans.
both boards work fine in my 90, neither works in the 93
DaveAstro
Fueling (3/4 tank)
Fueling (3/4 tank)
Postby crashcx » April 1st 2011, 7:33pm
This may sound a little crazy but give this a shot.
1. Crank the van
2. Turn wiper switch to high
3. Give the circuit board a good whack with a rubber mallat.
1994 astro ext rwd 4.3 t.b.I.
crashcx
Years of Membership: crashcx has been a member for 2 full yearscrashcx has been a member for 2 full years
Extra Info: ext 4.3 rwd
Postby DaveAstro [OP] » April 1st 2011, 7:38pm
crashcx wrote:This may sound a little crazy but give this a shot.
1. Crank the van
your right! that does sound a little crazy, lol
I'm thinking there may be a short in the motor itself, going to get into it more tomorrow when I can work on it inside, away from the damn snow.
DaveAstro
Fueling (3/4 tank)
Fueling (3/4 tank)
Postby fast68 » April 2nd 2011, 7:33pm
have hot wire at the motor?
have ground in black wire there too?
if so then probably dead motor or fried board
not uncommon
make sure a connector pin isnt melted burnt also
it happens........ especially on high current draw connectors like the heater contorl panel fan speed switch in these and full size trucks and s10 trucks
common problem issue,,,,
1992 Astro EXT parting out! many new parts! new regulators, heater core, ECM, etc. text me 217 671 7792 parting: '91 S-10 2wd pickup , '70's chevy trucks, '54 ford truck dually, '69 fairlane, '80s toyota trucks,
fast68
Years of Membership: fast68 has been a member for 4 full yearsfast68 has been a member for 4 full yearsfast68 has been a member for 4 full yearsfast68 has been a member for 4 full years
Topics: 12
Alias (AKA): fast
Extra Info: 4.3L Z EXT RWD
Postby DaveAstro [OP] » April 4th 2011, 1:07pm
fast68 wrote:if so then probably dead motor or fried board
as I have said, it isn't the board.. I have two vans, both boards (wiper pulse modules) work in my other van, neither in the 93
no matter what board I put in, if I ground out the motor case the chassis, the wipers kick in regardless of what position the dash switch is, as long as the key is on.
following the diagnostics, the switch tested fine and the wiring between the switch and the motor seems ok. I am thinking there may be an internal short in the motor.
as soon as I get a warm dry day I will get into it further with the multi-meter and see what I can find out.
DaveAstro
Fueling (3/4 tank)
Fueling (3/4 tank)
Postby DaveAstro [OP] » April 10th 2011, 1:13pm
so, I fixed the wipers.
before my friend passed away, he was trying to say something about wires and colors.
apparently he either took the jack apart or it fell apart that goes into the wiper pulse module, the wires were all backwards.
fixed that, wipers are working!
DaveAstro
Fueling (3/4 tank)
Fueling (3/4 tank)
Postby Leeann_93 » April 10th 2011, 3:40pm
Good find and fix!
'02 Astro SL AWD vin X
Image Image
Years of Membership: Leeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full years
Topics: 17
Images: 3
Year: 2002
Extra Info: SL 4.3L AWD
It is currently June 19th 2013, 2:59pm
Moderator: tedanderson
BigAl58
Date: Today
Time: 2:29am
Drummernaut
Comments: 13
Date: Jun 02 '13
Time: 7:52pm
_brad_
Date: May 27 '13
Time: 5:55pm
akkid
Date: May 26 '13
Time: 1:27am
TaxiVan
Comments: 13
Date: May 21 '13
Time: 7:19pm
