My 97 astro blew an ign 40a fuse last night when I turned the key to start it. It did that three times only when turning all the way to the start position. I put a jumper in because I was out of fuses to steal from other locations.
After I put the jumper in, I laid under the van and jumped the starter solenoid with a screw driver and the van started up and I was able to get home.
Can someone help with known problems on this issue before I start diagnosing it tonight?
Thanks in advance for any help.
Sean
Sean
