turn signal/ back up fuse blows
Postby daedaestoy [OP] » November 7th 2011, 4:20am
i am having a problem with every time i plug my turn signal switch up my fuse blows immediately!! if i unplug the switch the fuse is fine and my back up lights work completely fine... obviously it seems my turn signal switch is bad but my question is is there away to take it apart and possibly fix it because it is to expensive for my to jus spend $185 on a van that i only paid $500 for to start with.... is there anything i can do besides buy a new switch? oh! and btw i have a 1997 astro 2wd extended
daedaestoy
Years of Membership: daedaestoy has been a member for 2 full yearsdaedaestoy has been a member for 2 full years
Alias (AKA): daedaestoy
Extra Info: 4.3l v6 RWD
  • ECMB fuse blows...
    by DCMoose48 » March 25th 2013, 3:38pm in Electrical
    Last post by DCMoose48 View the latest post
    May 13th 2013, 4:42pm
  • Pinout for turn signal switch connector
    by dadofanna » January 22nd 2013, 3:14am in Electrical
    Last post by dadofanna View the latest post
    May 19th 2013, 4:29pm
Re: turn signal/ back up fuse blows
Postby Phantom » November 7th 2011, 2:22pm
There is a dead short in that circuit , in either the switch or the chassis circuit , you need a VOM/continuity tester to test the circuit to pinpoint where the short is, It is possible you can change the switch and still have the same problem if the short is in the chassis side of circuit , unplug the switch and test for continuity in the switch alone through the connector , if it is bad you see it it , if it is good you will need to test each bulb socket with meter . In rare cases the turn flasher relay could have blown in a way that still passes voltage internally being the short , You can get a switch from a salvage yard for cheap,,and depending on exactly has caused the short it might be possible to fix the existing switch in the case that maybe a spring or metal tab has fallen onto other contacts.
Phantom
Firing on 7 Cylinders (L4)
Years of Membership: Phantom has been a member for 2 full yearsPhantom has been a member for 2 full years
Postby RECox286 » November 7th 2011, 2:35pm
It would seem that you have three choices: A) put up the cash to have it repaired. B) Rather than spend $185, you have the opportunity to chase down the culprit
and fix it yourself, OR, C) you could roll the window down and signal manually when anticipating making a turn.
If you picked "B" you are on your way to becoming more self reliant, AND, Phantom has laid out the way to start your new lifestyle.
Bob
RECox286
Green Status (L4)
Green Status (L4)
Years of Membership: RECox286 has been a member for 2 full yearsRECox286 has been a member for 2 full years
Topics: 28
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [323K mi]
Postby daedaestoy [OP] » November 7th 2011, 3:41pm
has anyone experienced this type of problem? is it common? or is this jus a freak occurrence?
daedaestoy
Postby Phantom » November 7th 2011, 3:51pm
It may have happened to someone but no it is not common , you will need to pinpoint exactly where the short is , it may or may not be the switch , those switches on any vehicle are kinda fragile , sometimes they can break if mishandled .Turn signal switches can wear out because they are used frequently .
Phantom
Postby RECox286 » November 8th 2011, 2:20am
It seems that it would be easy enough to find out where the problem is. Replace the fuse that blows with a lightbulb and then do a L&R indicator and see if the bulb lights up in the fuse panel.
Start jiggling wires until the bulb goes out, and you will bein the vicinity of the "short to ground" problem child.
All you will need is a high wattage lightbulb, like an 1156, a socket that will accept the bulb and a couple of solderless connectors (male spade tips) red would be the proper size. Voila.
Good hunting
One thing has me stumped, are there two separate problems, or do the backup lights run thru the T/S switch ? (Sorry, I'm having a bad hair day today.)
Bob
RECox286
Green Status (L4)
Green Status (L4)
Topics: 28
Year: 1993
Postby sasktrini » November 8th 2011, 4:08am
Mine has that problem intermittently... I've replaced that fuse twice in the last year. Yeah, Bob, it seems to be the same circuit. Don't know where in the circuit my problem is though. Sorry I can't be more helpful than "Yeah, it doesn't just happen to me."
1989 LT
sasktrini, Saskatoon, SK, Canada
sasktrini
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: sasktrini has been a member for 2 full yearssasktrini has been a member for 2 full years
Extra Info: LT 4.3L RWD 3.42
Postby daedaestoy [OP] » November 8th 2011, 5:34pm
RECox286 wrote:It seems that it would be easy enough to find out where the problem is. Replace the fuse that blows with a lightbulb and then do a L&R indicator and see if the bulb lights up in the fuse panel.
Good hunting
Bob
that a cool idea thanks for the help im goin to try this as soon as i get a few extra minutes
daedaestoy
It is currently May 19th 2013, 4:29pm
Moderator: tedanderson
akkid
Time: 9:30pm
Attached by: chevymaher
Date: May 17 '13
Time: 9:16pm
lightimages
Date: May 11 '13
Time: 10:23pm
steinec
Comments: 49
Date: May 11 '13
Time: 3:49pm
akkid
Date: May 09 '13
Time: 1:44am
Users browsing this forum: Sogou [Spider] and 4 guests
