So far, I have only been able to check for the flasher when it's dusk or dark outside, and it's always been under noisy conditions. I live on fairly busy street, so activating the turn signal and listening to where the flasher's noise was coming from didn't work. I know it's under the dash, the lower portion, and seems to be either to the left or to the right of the steering column. Does anyone know if I will need to remove the plastic panel, or can I reach the get to the turn signal flasher by just reaching under?
Also, is there a separate flasher for the hazard lights? If so, should I replace that one with an electronic turn signal flasher as well? Thanks!
