How to read codes off check engine light
Postby ccookie66 [OP] » March 4th 2012, 2:18am
Ok, so I noticed the check engine light is on. I know there is a way to read the trouble codes, with a paper clip? Can anyone tell me how to do this? My van is a 93 Chevy Astro. Thanks.
The Astro is always a turn key away from adventure.
ccookie66
Firing on 5 Cylinders (L2)
Years of Membership: ccookie66 has been a member for 4 full yearsccookie66 has been a member for 4 full yearsccookie66 has been a member for 4 full yearsccookie66 has been a member for 4 full years
Topics: 133
Images: 41
Alias (AKA): Cameron
Year: 1992
Extra Info: 4.3L V6 TBI Shorty
  • One brake light always on
    by shashabooey » September 25th 2016, 2:35am in Electrical
    Last post by shashabooey View the latest post
    September 30th 2016, 2:47am
  • Reverse light wiring
    by Astrobozz » September 21st 2016, 8:31am in Electrical
    Last post by Astrobozz View the latest post
    September 28th 2016, 3:36pm
    32
    February 23rd 2017, 9:44pm
Re: How to read codes off check engine light
Postby paintdrying » March 4th 2012, 2:22am
Ylas also will give you a small key to read them. Basically stick a paper clip in the wire bulkhead and join two wires then count the blinks. i think code 12 will flash three times then the codes. Someone with an older van we chime in soon
paintdrying
Topics: 94
Extra Info: 108 000
Postby chevymaher » March 4th 2012, 2:25am
How to read the codes
Ground terminals A and B (see diagram below) with the ignition "ON" and engine not running. The system will enter the diagnostic mode. In this mode, the computer will display a Code 12, three consecutive times, by flashing the "CHECK ENGINE", "SERVICE ENGINE SOON" or "MALFUNCTION INDICATOR LAMP" or light. A Code 12 consists of one flash, a short pause, then two flashes in rapid succession.
After Code 12 is displayed, any stored trouble codes will be displayed by flashing the "CHECK ENGINE", "SERVICE ENGINE SOON" or "MALFUNCTION INDICATOR LAMP" light. All codes are displayed 3 times each then a code 12 will repeat. In the diagnostic mode, the computer will also energize all computer controlled relays and solenoids.
obd1 terminal.jpg (54.23 KiB) Viewed 19470 times
Topics: 81
Year: 1994
Postby ccookie66 [OP] » March 4th 2012, 3:52pm
chevymaher wrote:How to read the codes
Where is this located? Up under the dash on the drivers side, with the fuses?
ccookie66
Topics: 133
Images: 41
Year: 1992
Postby chevymaher » March 4th 2012, 5:56pm
Should be right at the bottom edge of the dash near your left leg when your sitting.Even with a brite light it rough to see with the black interior.But it circled in red.
Topics: 81
Year: 1994
Postby ccookie66 [OP] » March 5th 2012, 1:34am
chevymaher wrote:Should be right at the bottom edge of the dash near your left leg when your sitting.Even with a brite light it rough to see with the black interior.But it circled in red.
Thank you! I found out it was code 43. After a little work, it was all set and the service engine soon light was out! :dance:
ccookie66
Topics: 133
Images: 41
Year: 1992
Postby adopted » July 26th 2012, 11:41pm
can you use this method (paper clip) with a OBD-2 (1997 chevy astro), or is this only for the older OBD-1 systems?
adopted
Years of Membership: adopted has been a member for 4 full yearsadopted has been a member for 4 full yearsadopted has been a member for 4 full yearsadopted has been a member for 4 full years
Alias (AKA): Paul
Year: 1997
Postby ccookie66 [OP] » July 27th 2012, 2:32pm
adopted wrote:can you use this method (paper clip) with a OBD-2 (1997 chevy astro), or is this only for the older OBD-1 systems?
I'm pretty sure it will only work for the older OBD-1 systems. I tried it on the windstar, and it didn't work. I think you need a code reader for the OBD-2 systems.
ccookie66
Topics: 133
Images: 41
Year: 1992
Postby adopted » July 28th 2012, 2:07pm
ccookie66 wrote:I'm pretty sure it will only work for the older OBD-1 systems. I tried it on the windstar, and it didn't work. I think you need a code reader for the OBD-2 systems.
Thanks for your reply, ccookie66.
adopted
Alias (AKA): Paul
Year: 1997
Postby cdlenfert » July 14th 2015, 6:54pm
So if my error code were 43, I could expect to see it flash like this. 1flash pause 2flash (12code happens 3 times) then 4flash pause 3flash (43 code happens 3 times), then back to 1flash pause 2flash (12code)
89 Astro Provan Tiger, 91K
cdlenfert
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: cdlenfert has been a member for 3 full yearscdlenfert has been a member for 3 full yearscdlenfert has been a member for 3 full years
Year: 1989
Extra Info: Provan Tiger GT
Postby Leeann_93 » July 15th 2015, 12:25am
Yes.
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 27
Year: 2002
Extra Info: LS 4.3L AWD
It is currently February 23rd 2017, 9:44pm
Moderator: tedanderson
Attached by: markmitch
Date: Feb 18 '17
Time: 1:11am
One-Eye
Comments: 21
Date: Feb 17 '17
Time: 4:58am
One-Eye
Date: Feb 17 '17
Time: 1:58am
kristuphir
Date: Jan 21 '17
Time: 8:46am
mweir
Comments: 75
Date: Jan 20 '17
Time: 1:34am
