03 astro awd door locks
Postby a7tl46 [OP] » June 28th 2012, 1:51am
did'n't find much searching... Picked up a really nice 03 awd today to replace my aging 94awd.
Problem with the driver/passenger power door/remote locking unlocking. If both are in the unlock position and I hit the power lock, I can hear the clicking trying to lock, but do not.
I manually locked them both and then tried to power unlock. No good , only this time I didn't hear the clicking from either door. Ideas?
BTW the sliding door and the rear door lock-unlock fine,
a7tl46
Years of Membership: a7tl46 has been a member for 5 full yearsa7tl46 has been a member for 5 full yearsa7tl46 has been a member for 5 full yearsa7tl46 has been a member for 5 full yearsa7tl46 has been a member for 5 full years
Topics: 26
  • Power Door Locks....HELP !
    by Concealed45 » March 16th 2013, 2:21am in Electrical
    Last post by benjaminwilles View the latest post
    March 29th 2013, 9:00am
  • power door locks
    by edlps » April 9th 2013, 11:50pm in Electrical
    Last post by Drummernaut View the latest post
    April 10th 2013, 6:30am
    22
    May 18th 2013, 10:29pm
Re: 03 astro awd door locks
Postby Leeann_93 » June 28th 2012, 1:52am
Test the driver's side switch. This happens often on my Bravada and it's the driver's switch hanging up. I need to take it apart and see why...
'02 Astro SL AWD vin X
Years of Membership: Leeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full years
Topics: 17
Images: 3
Year: 2002
Extra Info: SL 4.3L AWD
Postby TDMobile » June 28th 2012, 2:03am
Leeann_93 wrote:Test the driver's side switch. This happens often on my Bravada and it's the driver's switch hanging up. I need to take it apart and see why...
Every time I've run in to that issue on any GM, I end up replacing the driver's switch. I don't believe the part is very expensive, even at the LAPS.
TDMobile
Years of Membership: TDMobile has been a member for 1 full year
Topics: 12
Images: 5
Year: 2005
Extra Info: AWD Cargo 300K
Postby a7tl46 [OP] » June 28th 2012, 3:17am
thanks guys sounds like an easy enough fix. Let you kmnow how it goes.
a7tl46
Topics: 26
Postby draganjr » November 4th 2012, 5:46pm
You fix it?
draganjr
Topics: 7
Alias (AKA): draganjr
Year: 2005
It is currently May 18th 2013, 10:29pm
Moderator: tedanderson
akkid
Date: 59 minutes ago
Time: 9:30pm
Attached by: chevymaher
Time: 9:16pm
lightimages
Date: May 11 '13
Time: 10:23pm
steinec
Comments: 49
Date: May 11 '13
Time: 3:49pm
akkid
Date: May 09 '13
Time: 1:44am
Users browsing this forum: Bing [Bot], detailer4udetailer4u is online! and 5 guests
