No power at ECMB on fuse panel
Postby Chevyguy713 [OP] » September 16th 2012, 6:31pm
1994 Astro EXT 4.3L TBI (Z engine) So got a real jerker of a fuel/electrical problem here... no power to ECMB at fuse panel... fusable link gone at fire wall? Van has been sitting for a few months. Dropped tank replaced fuel pump, fuel filter, fuel relay (firewall). Check all electrical connections? Oil pressure sensor is the only thing not replaced, but no power at the fuse panel? My understanding was the ECMB power at the fuse panel came straight from the battery. Suggestions to prevent insanity? :banghead:
Chevyguy713
Years of Membership: Chevyguy713 has been a member for 4 full yearsChevyguy713 has been a member for 4 full yearsChevyguy713 has been a member for 4 full yearsChevyguy713 has been a member for 4 full years
Year: 1994
Extra Info: EXT 4.3L TBI RWD
  • Interior Fuse Panel ACC Fuse Hookup question
    by drogers98 » September 19th 2016, 2:24pm in Electrical
    October 10th 2016, 1:06am
  • 99 so what does that second big 30 amp fuse power
    by Nomad » September 19th 2016, 4:47am in Electrical
    Last post by Nomad View the latest post
    October 25th 2016, 6:24am
    February 23rd 2017, 9:43pm
Re: No power at ECMB on fuse panel
Postby RECox286 » September 16th 2012, 8:24pm
??? Fusible link gone at firewall ??? What do you actually mean ? Is the link fried, MIA, or what. Have you checked for voltage thru the
f/l ? and down stream of them (the red wires that continue the circuit. Open up the large wire loom in back of the battery, and see if
one of the power wires broken open due to corrosion (battery acid related). I had this happen two times. Looked like a gnarled discolored
nodule on the red wire. Cut out the bad boy, and repaired with solder and shrink wrap.
Uncle Bob
RECox286
Topics: 38
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [325K mi]
Postby Chevyguy713 [OP] » September 16th 2012, 8:36pm
Yeah it appears the fusible links have all been snipped out and shrink wrapped. Going to check that thanks, I am correct to say power at ECMB at panel all the time? Thank you I'll get back to you. :bouncy:
Amazing!!! Bad wire in the feed at the firewall didn't see it until I almost gave up... soft browned orange wire... cut it shrink wrapped the sucker and boom! there we have pump power. Spent tons of cash, tons of time, hours of blogging, THANK YOU, good for another 450k!!!!!!!!!!! These vans do rule after the bs gets worked out! :bow: :banana: :sleep: :ty:
Chevyguy713
Year: 1994
Postby RECox286 » September 17th 2012, 3:57am
Huzzah ! Good to know you got to the bottom of things and it is running again. Amazing that something I said actually
helped !
Keep truck'n
Uncle Bob
RECox286
Topics: 38
Year: 1993
It is currently February 23rd 2017, 9:43pm
Moderator: tedanderson
Attached by: markmitch
Date: Feb 18 '17
Time: 1:11am
One-Eye
Comments: 21
Date: Feb 17 '17
Time: 4:58am
One-Eye
Date: Feb 17 '17
Time: 1:58am
kristuphir
Date: Jan 21 '17
Time: 8:46am
mweir
Comments: 75
Date: Jan 20 '17
Time: 1:34am
