Alternator direct to battery
Postby monstersafari [OP] » February 4th 2013, 5:12pm
It seems alot of people have gone through the same steps as i have with no avail.....and their solution was a wire direct from alternator to battery. This seems like something i could do easily and quickly. I would just like some others input first before i jump into it. What Ga. wire should i use? Should i put an inline fuse on that?
Thank You
TRUE FACT: 100% of people who drink water, die.
monstersafari
Years of Membership: monstersafari has been a member for 4 full yearsmonstersafari has been a member for 4 full yearsmonstersafari has been a member for 4 full yearsmonstersafari has been a member for 4 full years
Topics: 5
Alias (AKA): monster
Year: 1995
Extra Info: 4.3l v6 awd-rwd
Re: Alternator direct to battery
Postby astroracer » February 4th 2013, 6:08pm
The best advice I can give you is to go here:
http://madelectrical.com/electrical-tech.shtml
Very informative site and you will not believe how much you don't know about wiring. I thought I was knowledgable until I read through it.
You will want at least an 8ga wire running to the battery (depends on length) and yes, please put a fuse or circuit breaker in the line. Closer to the alternator the better.
Mark
2004 Astro
2001 Astro (the wifes)
2000 Monte Carlo SS
2000 Astro Conversion Van
1994 Formula V8 Firebird
1956 Chevy Station Wagon
astroracer
Years of Membership: astroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full years
Alias (AKA): astroracer
Year: 1988
Extra Info: Major renovation
Postby JaxSPL » February 4th 2013, 9:29pm
What exactly are you trying to accomplish? Or did I miss something, somewhere?
"Installer's Nightmare" has officially come to life. Only 1 sub, but loud and clear.
Subwoofer enclosure designer. PM For More Info
JaxSPL
Section Moderator
Section Moderator
Firing on 8 Cylinders (L1)
Years of Membership: JaxSPL has been a member for 7 full yearsJaxSPL has been a member for 7 full yearsJaxSPL has been a member for 7 full yearsJaxSPL has been a member for 7 full yearsJaxSPL has been a member for 7 full yearsJaxSPL has been a member for 7 full yearsJaxSPL has been a member for 7 full years
Topics: 46
Images: 9
Extra Info: 4.3L V6 SPL
Postby monstersafari [OP] » February 5th 2013, 7:41pm
Im having an issue where my voltage fluctuates randomly, i have installed a new alternator, new battery, new starter....got a new idler pulley put on because i was losing tension on my belt....all of that and im back to my original problem
monstersafari
Topics: 5
Year: 1995
Postby thor124 » February 5th 2013, 7:53pm
monstersafari wrote:Im having an issue where my voltage fluctuates randomly, i have installed a new alternator, new battery, new starter....got a new idler pulley put on because i was losing tension on my belt....all of that and im back to my original problem
I wouldn't put any trust in the dash gauge reading... if your using that to determine that your voltage is fluctuating, you may be trying to fix something that aint broken. Get a analog volt meter, see if it's needle bounces around in time w/the one of the dash. The response time on digital meters(particularly cheap ones) is often to slow for this type of thing.
thor124
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: thor124 has been a member for 6 full yearsthor124 has been a member for 6 full yearsthor124 has been a member for 6 full yearsthor124 has been a member for 6 full yearsthor124 has been a member for 6 full yearsthor124 has been a member for 6 full years
Topics: 9
Postby Pantaz » February 11th 2013, 7:29pm
As thor124 mentioned, number one thing is to use a good quality analog voltage meter (or a high-end DMM) to verify what you're seeing with the in-dash meter.
Verify all wire terminals and connections are tight and free of corrosion. Double-check any wires that have been repaired with solderless crimp connectors. I've seen way too many wires pull out of crimped terminals with very little force. I crimp and solder every connector I install.
Another thing to check is the charge wire from the alternator. If it's original, it has a fusable link than can deteriorate over time. If you can't find a replacement locally, MadElectrical has them for $3 to $4 (just the fusable link section, not the complete cable.)
http://madelectrical.com/catalog/fusible-link.shtml
If it does turn out to be the in-dash meter, check the wiring before assuming the meter itself is faulty. When I first got my van, corrosion on the instrument panel connectors was causing problems with the fuel gauge. A little Scotchbrite, contact cleaner, and dielectric grease fixed things up. (Well, the fuel gauge still sucks, but at least it doesn't randomly stop functioning.)
Pantaz
Years of Membership: Pantaz has been a member for 6 full yearsPantaz has been a member for 6 full yearsPantaz has been a member for 6 full yearsPantaz has been a member for 6 full yearsPantaz has been a member for 6 full yearsPantaz has been a member for 6 full years
Year: 1985
Extra Info: Stretched 34 in.
Postby JaxSPL » February 11th 2013, 10:46pm
Look for the "Big 3" upgrade thread. That little modification will help you out a lot.
Well, I'll put the basics here for you.
Using a minimum of 4gauge wire.
A wire from the Alternator + to the Battery +
A wire from the Alternator case to the chassis of van (someplace a good ground can be had, preferably like the frame or something).
A wire from the Battery - to the chassis of the van.
You do not replace any factory wiring. You only need to add these three wires.
I do this on any vehicle I get, first thing. The main reason, for me, is due to high powered stereo systems I install. I also recommend anybody to do it. It will enhance the electrical system, allow things to charge better, and faster.
JaxSPL
Section Moderator
Section Moderator
Topics: 46
Images: 9
Postby plymouthcranbrook » May 8th 2013, 6:11am
I was wondering what size fuse to place between the alternator and the battery on the replacement wire? I have occasional bouts of no charge ranging from a couple of seconds to 5 minutes or so. This is always followed by a long period of good charge. Alternator is new, wires have good continuity from hot lead on back of alternator to battery and no connection to ground from the alternator. All connections are clean and tight. Battery is 1 year old. I know it is not the gauge as my ScanGuage also drops in voltage to match the dash gauge. Wiggling the wires by the link while the mtoor runs does not change charge amount. Any other ideas? Thanks
plymouthcranbrook
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: plymouthcranbrook has been a member for 7 full yearsplymouthcranbrook has been a member for 7 full yearsplymouthcranbrook has been a member for 7 full yearsplymouthcranbrook has been a member for 7 full yearsplymouthcranbrook has been a member for 7 full yearsplymouthcranbrook has been a member for 7 full yearsplymouthcranbrook has been a member for 7 full years
Topics: 10
Extra Info: allwheel drive
Postby MadMaxiVan » May 8th 2013, 12:58pm
yeah had same problem, also ran a wire from alt to battery first but that didnt fix it.
try installing a new ground from the Starter CASE to ground/firewall.
this cleared up a slow crank and crappy charging gremlin i had.
:banana:
MadMaxiVan
Years of Membership: MadMaxiVan has been a member for 5 full yearsMadMaxiVan has been a member for 5 full yearsMadMaxiVan has been a member for 5 full yearsMadMaxiVan has been a member for 5 full yearsMadMaxiVan has been a member for 5 full years
Topics: 20
Images: 4
Year: 1998
Extra Info: 4.3 auto 2wd
It is currently April 28th 2017, 11:15am
Moderator: tedanderson
caddy62
Date: Apr 25 '17
Time: 4:34pm
noahsaark
Date: Apr 25 '17
Time: 4:02pm
Date: Apr 16 '17
Time: 2:56pm
AK1
Date: Apr 16 '17
Time: 1:39am
Comments: 26
Date: Apr 08 '17
Time: 3:28pm
