99 astro wont start
99 astro wont start
Postby girlscoutmom227 [OP] » December 15th 2008, 5:35pm
My 99 Astro suddenly won't start . I just drove it from Cleveland to Columbus Ohio last night . I shut it off and a few minutes later went out to go to the store and all I get is a click. Have recently replaced the alternator and the water pump. Could this problem be the starter?
girlscoutmom227
Years of Membership: girlscoutmom227 has been a member for 8 full yearsgirlscoutmom227 has been a member for 8 full yearsgirlscoutmom227 has been a member for 8 full yearsgirlscoutmom227 has been a member for 8 full yearsgirlscoutmom227 has been a member for 8 full yearsgirlscoutmom227 has been a member for 8 full yearsgirlscoutmom227 has been a member for 8 full yearsgirlscoutmom227 has been a member for 8 full years
Topics: 10
Alias (AKA): girlscoutmom
Re: 99 astro wont start
Postby astro355 » December 15th 2008, 8:01pm
What is the history of the battery?
astro355
Firing on 4 Cylinders (L6)
Year: 1989
Extra Info: 355 V8 700R4
Postby girlscoutmom227 [OP] » December 15th 2008, 8:15pm
The battery is the one that came with the van when we bought it 2 years ago. But the voltage guage isnt showing a low charge, and all the lights work. All I get is a click when I turn the key
girlscoutmom227
Topics: 10
Postby Leeann_93 » December 15th 2008, 8:20pm
Hmm. Sounds like the starter solenoid (astro335 - do the newer ones have a separate solenoid that sits on top like the old ones?) might be bad.
A very LIGHT tap on the solenoid, if yours has one, on top of the starter motor might get you going again. And if it does, that tells you it needs to be replaced.
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 26
Year: 2002
Extra Info: LS 4.3L AWD
Postby astro355 » December 15th 2008, 9:25pm
Leeann_93 wrote:Hmm. Sounds like the starter solenoid (astro335 - do the newer ones have a separate solenoid that sits on top like the old ones?) might be bad.
Yes, it will have a solenoid on top of the starter. A lit tap will get it working if that is the problem (I can't think of how many of my own cars I have done that to :banana: ). But one thing to remember, just because your lights come on does not mean there is enough voltage to turn the starter over. Have the battery checked to be safe. It would be something as annoying as corrosion on the cables that attach to the starter. My van did that last year. Suddenly one day, it started turning over funny and didn't seem to charge the battery as well as it used to. I cleaned the connectors at the battery and the starter and everything was fine.
And why was the alternator changed?
astro355
Year: 1989
Postby girlscoutmom227 [OP] » December 16th 2008, 3:09am
Replaced it because it no longer charged the battery. My voltage guage was always on the low side and suddenly one day my battery light came on and I drove it till it died. After we changed the alternator and charged up the battery it has run just fine .
girlscoutmom227
Topics: 10
Postby astro355 » December 16th 2008, 10:57am
girlscoutmom227 wrote:Replaced it because it no longer charged the battery. My voltage guage was always on the low side and suddenly one day my battery light came on and I drove it till it died. After we changed the alternator and charged up the battery it has run just fine .
Cool, thanks. That's why I always ask a million questions, its hard to give helpful suggestions without having a feel for your van. First, I would still have the battery tested. Anyone of the parts places (autozone, advanced, o'reilly's, etc) should be able to test your battery for free. Now if the battery comes up fine, like leeann_93 already suggested, I would look at the starter.
astro355
Year: 1989
It is currently January 18th 2017, 11:09pm
Moderator: tedanderson
Attached by: chevymaher
Comments: 24
Date: Jan 14 '17
Time: 12:02am
Comments: 24
Date: Jan 13 '17
Time: 10:49pm
Attached by: astrotardis
astrotardis
Date: Jan 12 '17
Time: 9:01pm
astrotardis
Date: Jan 12 '17
Time: 2:46am
Comments: 27
Date: Jan 08 '17
Time: 3:07am
