Ign Wires
Ign Wires
Postby gmtofd [OP] » December 1st 2008, 7:21pm
About time for a set of ign wires for the 2000 Astro.
The rule-of-thumb is to replace with OEM, but was wondering if anyone tried a set of Car Quest Gold series 7673? Seen a set on Ebay going for about $30 cheaper than OEM.
Thanks for any response.
gmtofd
Years of Membership: gmtofd has been a member for 4 full yearsgmtofd has been a member for 4 full yearsgmtofd has been a member for 4 full yearsgmtofd has been a member for 4 full years
Topics: 12
  • dutch door wires
    by five10freak » February 9th 2013, 7:56am in Electrical
    Last post by Drummernaut View the latest post
    February 16th 2013, 8:49pm
    33
    May 21st 2013, 10:59am
Re: Ign Wires
Postby astro355 » December 1st 2008, 7:54pm
Not sure about the carquest ones, but don't you have a local parts store? It would probably be best to just buy it from there. It would be really crappy to buy maintenance parts online just to have a problem, if one arises.
astro355
Firing on 4 Cylinders (L6)
Years of Membership: astro355 has been a member for 4 full yearsastro355 has been a member for 4 full yearsastro355 has been a member for 4 full yearsastro355 has been a member for 4 full years
Year: 1989
Extra Info: 355 V8 700R4
Re: Ign Wires
Postby remark123 » December 2nd 2008, 12:23am
I wouldn't use anything but Delco (OEM)!!! this is one area of the van that I don't cut costs on. Too many times I have tried, and failed. Anybody else??? :swerve:
Mark, Simpsonville, KY
remark123
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: remark123 has been a member for 5 full yearsremark123 has been a member for 5 full yearsremark123 has been a member for 5 full yearsremark123 has been a member for 5 full yearsremark123 has been a member for 5 full years
Extra Info: Conversion Van
Re: Ign Wires
Postby Matrixx » December 2nd 2008, 12:54am
Hi gmtofd
remark123 is right, you can't go wrong with Delco parts for the ignition system and what I would suggest as well. To many problems with after market stuff when it comes to ignition. Hope this helps. :)
Matrixx
Years of Membership: Matrixx has been a member for 5 full yearsMatrixx has been a member for 5 full yearsMatrixx has been a member for 5 full yearsMatrixx has been a member for 5 full yearsMatrixx has been a member for 5 full years
Re: Ign Wires
Postby acreativename » December 7th 2008, 1:07am
I agree, go OEM if at all possible. The $30 you will save will end up costing you far more money and time when you have to replace them again. If you really don't want to spend the money, do not buy carquest wires. Every time we use a set of carquest wires at work I end up having to replace them.
acreativename
Years of Membership: acreativename has been a member for 4 full yearsacreativename has been a member for 4 full yearsacreativename has been a member for 4 full yearsacreativename has been a member for 4 full years
Re: Ign Wires
Postby gmtofd [OP] » December 19th 2008, 2:01pm
IMO, the wire material manufacturing quality control for the high line aftermarket wire sets is just as good as AC Delco, but where they fall short is that they are multi-application. That means the wires are longer than OEM which causes their early demise, when installed in Astros from rubbing against stuff, eventual cross arcing no manner how carefully installed.
Brought a set of AC Delco, # 9746KK, from Rockauto for about $60. There replacement wire set #, once 9746KK runs out of stock is 746KK at about $92. The order taker informed that there is absolutely no difference in these two wire sets, they are both exact fit. GM justs changes the part # and jacks up the price.
This is a '00 model year, and found that removing the wire seperator, held in place with two 3/8 head bolts provides better access to the separator clips on the left driver's side makes for an easier job. On the right side, the seperator stays in place, but by having the front of the van jacked up, it's easy to access the #2 and 4 plug wires.
gmtofd
Topics: 12
Re: Ign Wires
Postby astro355 » December 19th 2008, 5:50pm
Glad you stayed with the OEM wires in your van. I always love it when you need a hoist to change spark plugs.
astro355
Year: 1989
It is currently May 21st 2013, 10:59am
Moderator: tedanderson
akkid
Date: May 18 '13
Time: 9:30pm
Attached by: chevymaher
Date: May 17 '13
Time: 9:16pm
lightimages
Date: May 11 '13
Time: 10:23pm
steinec
Comments: 49
Date: May 11 '13
Time: 3:49pm
akkid
Date: May 09 '13
Time: 1:44am
