Intermittent Start Problem
Postby RootsMan [OP] » June 16th 2013, 4:48pm
Greetings,
I have an intermittent start problem with my 2003 Chevy Astro AWD.
Sometimes when I turn the key to ignition, all the lights on the dish turn off, and the starter does not crank. Just silence. And the dash lights stay off while the key is held in the ignition position.
This has happened when the engine is cold or hot.
Same problem when the transmission indicator is in neutral.
After a couple of tries, without changing gears, it'll start. Moving the gear leaver to neutral then back to park doesn't always work.
I noticed that when I insert the key into the ignition, and before turning it, the dash lights flash, and the fuel gauge drops to empty.
Could this be a short in the ignition switch?
Thanks in advance for your input.
RootsMan
Years of Membership: RootsMan has been a member for 9 full yearsRootsMan has been a member for 9 full yearsRootsMan has been a member for 9 full yearsRootsMan has been a member for 9 full yearsRootsMan has been a member for 9 full yearsRootsMan has been a member for 9 full yearsRootsMan has been a member for 9 full yearsRootsMan has been a member for 9 full yearsRootsMan has been a member for 9 full years
  • Intermittent Dutch Doors
    by gimixman » November 26th 2016, 10:46pm in Electrical
    November 29th 2016, 5:35am
  • Does this sound like a ground problem to you?
    by racerman67 » February 27th 2017, 5:56am in Electrical
    February 28th 2017, 7:26am
    83
    March 28th 2017, 9:06am
Re: Intermittent Start Problem
Postby thedark3rd » June 16th 2013, 5:28pm
Does the time on your radio reset, or is it still the same?
thedark3rd
Years of Membership: thedark3rd has been a member for 7 full yearsthedark3rd has been a member for 7 full yearsthedark3rd has been a member for 7 full yearsthedark3rd has been a member for 7 full yearsthedark3rd has been a member for 7 full yearsthedark3rd has been a member for 7 full yearsthedark3rd has been a member for 7 full years
Alias (AKA): TheDark3rd
Year: 1998
Postby AstroWill » June 16th 2013, 10:45pm
I would suspect the switch.
Topics: 60
Images: 87
Extra Info: 90TigerGTv8 03AWD
Postby RootsMan [OP] » June 17th 2013, 12:00am
thedark3rd wrote:Does the time on your radio reset, or is it still the same?
The time on the radio does not reset.
RootsMan
Postby RootsMan [OP] » June 23rd 2013, 8:37pm
Resolution:
My mechanic determined it was the starter. The starter was replaced and the van now starts reliably.
The dash lights still flash, and the fuel gauge drops to below empty when the key is inserted into the ignition, and before turning it. I don't recall if this was happening before the intermittent start issue.
RootsMan
Postby RECox286 » June 23rd 2013, 9:37pm
(???) :confused: (???)
To my way of thinking...
Since the key mechanism is connected to the start switch by a push rod, it is not reasonable for the system
to exhibit the flashing lights by merely inserting the key, w/o actually twisting it. But, OTOH, what do I know ?
Uncle Bob
RECox286
Topics: 38
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [325K mi]
Postby miketoybox » July 8th 2013, 3:39pm
I had the same issue on my 02' AWD, it turned out to be the small wire running to the starter. I just replaced 2' of the wire and the conector.
Mine issue always happened after the starter became wet, after good hard wiggle on the wire the starter worked.
miketoybox
Years of Membership: miketoybox has been a member for 5 full yearsmiketoybox has been a member for 5 full yearsmiketoybox has been a member for 5 full yearsmiketoybox has been a member for 5 full yearsmiketoybox has been a member for 5 full years
Alias (AKA): Mike829
It is currently March 28th 2017, 9:06am
Moderator: tedanderson
hotpsca
Comments: 14
Date: Mar 25 '17
Time: 4:47pm
Attached by: chevy57bert
chevy57bert
Comments: 14
Date: Mar 24 '17
Time: 12:04am
Attached by: markmitch
Date: Mar 09 '17
Time: 6:33pm
theFlyingDutchman
Date: Mar 02 '17
Time: 2:46am
Date: Feb 18 '17
Time: 1:11am
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 3 guests
