Remote Keyless Entry Fob Reprogramming?
Postby Casey [OP] » March 26th 2009, 2:09am
I didn't see this already asked, so I'lll ask here. How do I reprogram the remote keyless entry (RKE) fob for my '95 Astro? I had the battery disconnected to re-set a SES code and now none of the three RKE functions work . :(
Casey
Years of Membership: Casey has been a member for 7 full yearsCasey has been a member for 7 full yearsCasey has been a member for 7 full yearsCasey has been a member for 7 full yearsCasey has been a member for 7 full yearsCasey has been a member for 7 full yearsCasey has been a member for 7 full years
Topics: 24
Year: 1995
Extra Info: 4.3L LT 5-speed
Re: Remote Keyless Entry Fob Reprogramming?
Postby Matrixx » March 26th 2009, 3:06am
If it's an OEM RKE here are the instructions:
1- Ground pin G in the Data Link Connector (DLC).
-Receiver will respond by locking and unlocking all doors.
2- Press any button on the first transmitter to be programmed.
3- The control module will respond by locking/unlocking all doors
and activating the liftgate release (If equipped).
4- If you have a second remote, follow step 2 and at this time.
5- Remove the ground from pin G of the DLC.
6- Transmitter operation is verified by locking and unlocking the doors and automatically activating the rear window release (If equipped).
Hope this helps.:)
Data Link Connector-1995
Data Link Connector-1995.jpg (41.88 KiB) Viewed 620 times
Matrixx
Years of Membership: Matrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full years
Postby Casey [OP] » March 26th 2009, 3:38am
Done. Thanks. :banana: :bow:
Casey
Topics: 24
Year: 1995
Postby Matrixx » March 26th 2009, 3:40am
Matrixx
It is currently January 23rd 2017, 9:35am
Moderator: tedanderson
kristuphir
Date: Jan 21 '17
Time: 8:46am
mweir
Comments: 75
Date: Jan 20 '17
Time: 1:34am
Attached by: 95AstroLT
95AstroLT
Comments: 75
Date: Jan 19 '17
Time: 2:12am
Attached by: chevymaher
Comments: 24
Date: Jan 14 '17
Time: 12:02am
Comments: 24
Date: Jan 13 '17
Time: 10:49pm
Users browsing this forum: Google Adsense [Bot] and 3 guests
cron
