Astro van is it the igniton switch or a relay
Postby unclemaui [OP] » July 22nd 2013, 6:29am
94 Chevy astrovan all at once no speedometer. stays in low gear, windows, front and rear fans stop working a/c compressor does not start heater does not start.
I cannot find anywhere online about a relay or if it is the ignition switch that shuts off the accessories until the engine starts. (thinking short circuit)
For grins and $47.00 I tried the speed sensor. still stays in low gear.
unclemaui
Years of Membership: unclemaui has been a member for 3 full yearsunclemaui has been a member for 3 full yearsunclemaui has been a member for 3 full years
Year: 1994
  • power window failure NOT the switch nor relay.
    by AstroNuts » October 22nd 2016, 8:21pm in Electrical
    October 29th 2016, 12:01am
  • 1995 astro horn relay
    by kenward » February 15th 2017, 7:58pm in Electrical
    Last post by TurnNburn View the latest post
    February 15th 2017, 8:53pm
    27
    March 28th 2017, 8:33pm
Re: Astro van is it the igniton switch or a relay
Postby chevymaherchevymaher is online! » July 22nd 2013, 9:30am
It is the ignition switch that does that. And it does sound like it is losing power to things. Next time it does it I would check power @ the fuses for those areas. There is a spade connector marked IGN test there.
It seems like the hot in run @ the computer is going out or out depending on how you look at it from the diagram. Computer not getting juice there affects your speedo and shifting. And powering the other items, A/C clutch and blower motor. Same power feed in other parts of the wiring harness.
Sounds like a bad connection in the starter switch. I never messed with it yet on mine. So I don't know if it is in the switch itself. Or the rod type where a rod from the switch runs to a electical switch farther down on the steering column. Like older stuff had.
Topics: 82
Year: 1994
Postby WoodButcher » July 22nd 2013, 11:37am
Don't forget the fusible links behind the battery!
WoodButcher
Firing on 6 Cylinders (L5)
Topics: 28
Images: 450
Alias (AKA): Bruce
Year: 1997
Extra Info: 4.3 RWD
Postby unclemaui [OP] » July 23rd 2013, 2:41am
WoodButcher wrote:Don't forget the fusible links behind the battery!
Are those the four individual wires that are shrink wrapped in the middle and go into the cab via the fire wall?
thank you very much for responding
unclemaui
Year: 1994
Postby unclemaui [OP] » July 23rd 2013, 2:44am
chevymaher wrote:It is the ignition switch that does that. And it does sound like it is losing power to things. Next time it does it I would check power @ the fuses for those areas. There is a spade connector marked IGN test there.
So I test using the IGN is it suppose to be hot all the time or when the key is turned to on?
unclemaui
Year: 1994
Postby chevymaherchevymaher is online! » July 23rd 2013, 4:58am
Yes when the key is in run position.
Topics: 82
Year: 1994
Postby WoodButcher » July 23rd 2013, 11:36pm
And yes, those are the fusible links.
WoodButcher
Topics: 28
Images: 450
Alias (AKA): Bruce
Year: 1997
Extra Info: 4.3 RWD
Postby unclemaui [OP] » August 4th 2013, 5:29am
Thank you all for the replies, I have been unable to look at the van. Tomorrow 08-04-13 I will proceed with the instructions given and report back.
I really appreciate the time you have all taken.
unclemaui
Year: 1994
Postby unclemaui [OP] » August 13th 2013, 3:05am
Well I checked the fuseible links. they are fine however I cannot find that lug marked ING. :banghead:
Looking at the elect you attached. is that lug on a white device lower on the steering column? there are two lugs a small one and a large one side by side. :?:
Starting to think I need to call a mobile tech. I hate paying people to work on my stuff. that is why I bought tools
unclemaui
Year: 1994
It is currently March 28th 2017, 8:33pm
Moderator: tedanderson
astronot
Date: Today
Time: 4:58pm
hotpsca
Comments: 14
Date: Mar 25 '17
Time: 4:47pm
Attached by: chevy57bert
chevy57bert
Comments: 14
Date: Mar 24 '17
Time: 12:04am
Attached by: markmitch
Date: Mar 09 '17
Time: 6:33pm
theFlyingDutchman
Date: Mar 02 '17
Time: 2:46am
Users browsing this forum: Baiduspider [Spider] and 2 guests
