Headlights not coming on
Postby hamiltonfighter [OP] » August 4th 2013, 6:09am
Just bought the van yesterday. It's an '99 Astro.
With the van off, the parking lights come on when the selector is turn to the parking light position. Then when continueing to turn the selector the headlights don't turn on.
With the van on, the headlights come on when the selector is turned to the parking light position. The headlights go out when the selector is turned to the headlight selection.
The high beam is not working either.
The previous owner had new headlights put on because of them glazing. Could they have screwed something up then? Also, a remote start has been installed and I'm wondering if they screwed up wiring then.
Any ideas on what I should check first?
hamiltonfighter
Years of Membership: hamiltonfighter has been a member for 5 full yearshamiltonfighter has been a member for 5 full yearshamiltonfighter has been a member for 5 full yearshamiltonfighter has been a member for 5 full yearshamiltonfighter has been a member for 5 full years
Topics: 33
Images: 5
  • SES light not always coming on at start up
    by cavalier » January 18th 2017, 3:45pm in Electrical
    Last post by cavalier View the latest post
    January 19th 2017, 4:01pm
  • Headlights always ON-Help
    by MauiSafari » December 29th 2016, 1:52am in Electrical
    January 4th 2017, 4:12am
    46
    May 23rd 2017, 11:49am
Re: Headlights not coming on
Postby thegreenmachine » August 4th 2013, 4:50pm
Finally!!! Been waiting for your post announcing the purchase.
Check to make sure the fuses are good, an that the harness to the bulb is correctly installed. You could need a new switch though.
Happy trails.
Someone with more electrical experience will chime in soon.
Sent from AutoGuide.com App
"that looks legit"
95 AWD Safari money pit
thegreenmachine
Firing on 6 Cylinders (L2)
Years of Membership: thegreenmachine has been a member for 7 full yearsthegreenmachine has been a member for 7 full yearsthegreenmachine has been a member for 7 full yearsthegreenmachine has been a member for 7 full yearsthegreenmachine has been a member for 7 full yearsthegreenmachine has been a member for 7 full yearsthegreenmachine has been a member for 7 full years
Topics: 62
Alias (AKA): Shane a lane
Year: 2003
Postby smokinjoe » August 4th 2013, 7:10pm
Could be the switch on the dash, mine went & I just replaced it & all was fine
smokinjoe
Firing on 1 Cylinder (L2)
Years of Membership: smokinjoe has been a member for 8 full yearssmokinjoe has been a member for 8 full yearssmokinjoe has been a member for 8 full yearssmokinjoe has been a member for 8 full yearssmokinjoe has been a member for 8 full yearssmokinjoe has been a member for 8 full yearssmokinjoe has been a member for 8 full yearssmokinjoe has been a member for 8 full years
Topics: 185
Alias (AKA): smokinjoe
Year: 2002
Extra Info: RWD
Postby hamiltonfighter [OP] » August 4th 2013, 10:02pm
smokinjoe wrote:Could be the switch on the dash, mine went & I just replaced it & all was fine
Do think the lights not coming on would affect the high beam too?
hamiltonfighter
Topics: 33
Images: 5
Postby hamiltonfighter [OP] » September 5th 2013, 8:13am
I haven't looked to much into my issue yet, but it's there, waiting to be dealt with.
So, I don't use the parking break that often and did the other night. Found out the headlights go out when the parking break is engaged. I know the daytime running lights are supposed to do this, but not when the headlights are selected.
Also, is the headlight beam supposed to be brighter than the daytime running light beam?
I'm also having a flicker in all of the lights; interior and exterior.
Who should I take the van to? Auto shop, or a stereo installation shop? If it was the jack-ball's crazy wiring of the remote start, then I thought a specialty shop may be the way to go. Who's going to be cheaper?
hamiltonfighter
Topics: 33
Images: 5
Postby TaxiVan » September 5th 2013, 10:49am
Try watching the headlights from the front while you have someone else put it in gear. If they come on when the transmission is put in gear (will brighten from DRLs), then have them toggle the dimmer switch to see if it does its job. Sounds like your ride has automatic headlights, but the manual switch is likely bad.
'98 GMC Safari SLT AWD - BROKEN
Just published my first novel on Kindle - http://www.amazon.com/Lucky-Number-Thirteen-Colyer-Jameson-ebook/dp/B00OY0UCAU
Also a singer/rapper/songwriter - https://www.facebook.com/pages/Allergic-To-Air/209678145727598
TaxiVan
Firing on 7 Cylinders (L1)
Years of Membership: TaxiVan has been a member for 6 full yearsTaxiVan has been a member for 6 full yearsTaxiVan has been a member for 6 full yearsTaxiVan has been a member for 6 full yearsTaxiVan has been a member for 6 full yearsTaxiVan has been a member for 6 full years
Topics: 71
Alias (AKA): James
Year: 1998
Extra Info: SLT AWD 3.73 G80
It is currently May 23rd 2017, 11:49am
Moderator: tedanderson
Date: May 19 '17
Time: 7:12pm
Paddlejunkie
Date: May 12 '17
Time: 2:18am
Date: May 12 '17
Time: 1:53am
Date: May 11 '17
Time: 11:11pm
babblefish
Date: May 11 '17
Time: 9:48am
Users browsing this forum: Google Adsense [Bot] and 3 guests
