Daytime Running Lights // 2005 Astro
Postby eustisgoober [OP] » April 23rd 2009, 12:52am
Daytime running lights (DRL)on 2005 Astro with autolight feature.
Is anyone aware of a process that would disconnect the DRL full time. Owners manual states to turn key to run position and depress the "domelight override" button 4 times. This does work however on the next key cycle the DRL are on again :( . Wifey doesn't like this feature.
Thanks! Eustisgoober
96 Astro RWD 4.3 V6 w/105,000
97 Astro LT RWD 4.3 V6 w/187,000
05 Astro LS RWD 4.3 V6 w/ 52,000 (wifes ride)
eustisgoober
Years of Membership: eustisgoober has been a member for 7 full yearseustisgoober has been a member for 7 full yearseustisgoober has been a member for 7 full yearseustisgoober has been a member for 7 full yearseustisgoober has been a member for 7 full yearseustisgoober has been a member for 7 full yearseustisgoober has been a member for 7 full years
Alias (AKA): Chip
Re: Daytime Running Lights // 2005 Astro
Postby ihatemybike » April 23rd 2009, 1:13am
Hmmm, they remained off when I did that in my 2000.
In Grumpy I pulled the DRL fuse in the fuse box by the drivers feet.
Aaron
Prev Astros:99,97,00,94,87,86
ihatemybike
Firing on 6 Cylinders (L2)
Years of Membership: ihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full years
Topics: 67
Postby vanfan2 » May 14th 2009, 2:01am
Hi, I have troubles with my Astro built in 2000. With the fuse #15 in place it sucks 0.8 amps out of the battery. The #15 is marked as "TBC". Is that the same like the "DRL". What is the max. amps you would allow to loose if the car just sits??? Where is the DRL- box, how does it look like?
Thanks for help, Vanfan.
vanfan2
Years of Membership: vanfan2 has been a member for 7 full yearsvanfan2 has been a member for 7 full yearsvanfan2 has been a member for 7 full yearsvanfan2 has been a member for 7 full yearsvanfan2 has been a member for 7 full yearsvanfan2 has been a member for 7 full yearsvanfan2 has been a member for 7 full years
Postby Matrixx » May 14th 2009, 7:03am
Hi vanfan2
Hmm, TBC or BCM? Fuse block #15 for your year (2000 Astro) from what I'm seeing, is Body Control Module (BCM). It's normal if it is the BCM, no worries.
It's not the same as DRL.:)
Matrixx
Years of Membership: Matrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full years
Postby adibv5 » May 24th 2009, 2:58am
did anyone find the fuse afther all? i puled all of them my light still come on :(
adibv5
Years of Membership: adibv5 has been a member for 7 full yearsadibv5 has been a member for 7 full yearsadibv5 has been a member for 7 full yearsadibv5 has been a member for 7 full yearsadibv5 has been a member for 7 full yearsadibv5 has been a member for 7 full yearsadibv5 has been a member for 7 full years
Postby cosway » May 24th 2009, 11:32am
where do you live? wont the cops give her a ticket?
we have to have our lights on here.
cosway
Years of Membership: cosway has been a member for 7 full yearscosway has been a member for 7 full yearscosway has been a member for 7 full yearscosway has been a member for 7 full yearscosway has been a member for 7 full yearscosway has been a member for 7 full yearscosway has been a member for 7 full years
Postby ihatemybike » May 24th 2009, 3:34pm
cosway wrote:where do you live? wont the cops give her a ticket?
What do you live? They give tickets to cars that were made pre DRL?
Aaron
ihatemybike
Topics: 67
It is currently January 23rd 2017, 3:50pm
Moderator: tedanderson
kristuphir
Date: Jan 21 '17
Time: 8:46am
mweir
Comments: 75
Date: Jan 20 '17
Time: 1:34am
Attached by: 95AstroLT
95AstroLT
Comments: 75
Date: Jan 19 '17
Time: 2:12am
Attached by: chevymaher
Comments: 24
Date: Jan 14 '17
Time: 12:02am
Comments: 24
Date: Jan 13 '17
Time: 10:49pm
