how change the lever,cruise control and switch in astro 88
Postby hebert [OP] » July 10th 2009, 5:06am
how change the switch of cruise control, lever and intermitent lights....
Chevy Astro Van Cl 88
Punta Arenas
CHILE
hebert
Years of Membership: hebert has been a member for 8 full yearshebert has been a member for 8 full yearshebert has been a member for 8 full yearshebert has been a member for 8 full yearshebert has been a member for 8 full yearshebert has been a member for 8 full yearshebert has been a member for 8 full yearshebert has been a member for 8 full years
Topics: 61
Images: 36
Alias (AKA): Hebert
Extra Info: CL 4.3 V6
Re: how change the lever,cruise control and switch in astro 88
Postby guyonearth » July 11th 2009, 6:00pm
You're asking how to do it? First, I would suggest getting a manual. Second, you need to remove the steering wheel to get at the fasteners. The wires have to be fished up/down through the column. It helps to have a piece of wire to pull the connector with, it's a tight fit.
guyonearth
Years of Membership: guyonearth has been a member for 7 full yearsguyonearth has been a member for 7 full yearsguyonearth has been a member for 7 full yearsguyonearth has been a member for 7 full yearsguyonearth has been a member for 7 full yearsguyonearth has been a member for 7 full yearsguyonearth has been a member for 7 full years
Topics: 5
Alias (AKA): DeanC
Postby Big_kid » July 11th 2009, 9:02pm
In my 95 the turn signal lever popped right out. The cruise control switch just unplugged.
Firing on 5 Cylinders (L5)
Topics: 133
Images: 48
Extra Info: 2WD conversion
It is currently January 18th 2017, 11:06pm
Moderator: tedanderson
Attached by: chevymaher
Comments: 24
Date: Jan 14 '17
Time: 12:02am
Comments: 24
Date: Jan 13 '17
Time: 10:49pm
Attached by: astrotardis
astrotardis
Date: Jan 12 '17
Time: 9:01pm
astrotardis
Date: Jan 12 '17
Time: 2:46am
Comments: 27
Date: Jan 08 '17
Time: 3:07am
