Just a quick question before I return to the boneyard tomorrow. I pulled the overhead console with the display in it (yes, grabbed the brackets too!), installing it in a 2000 Astro cargo model. Haven't opened the headliner yet to look but should I grab the wiring harness too from the donor van? :banana:
Any other items I should grab while I'm there? :dunce:
It will run from the O/H Console to the drivers door pillar, to the floor, to the front/behind under the emergency brake mechanism, to the convienence panel (nex to the fuse panel) where several plugs are attached. I believe that it is a 9 pin connector.
It's a little bit of work but definitely worth the trouble.
Thanks! That's the kind of advice I'm looking for since I don't know the van well yet. And I'm going to snatch the headliner (hole pattern) and lighted four way vanity visors.. Anything else of use I should pull out? :feedback:
Does your cargo have a tilt steering column? They are easy to change out, even the ignition key assembly.
You can add the cruise module later, or grab it from the donor.
Also the drawer under the passenger seat?
Any other cosmetics, carpet, door panels, remote mirrors, etc.?
I already grabbed the tilt column with the tow/haul switch (which mine had) and the cruise button (which it didn't) and had a locksmith pop the old lock for me. I also grabbed the cruise module off the donor and four others (just in case since Murphy likes to cause me grief). The drawer I wasn't aware of but I am now, thanks!
I have a set of power mirrors snagged on a previous visit and a power seat base for the driver's seat. A bit down the road will be power windows and locks (factory) which I have no doubt will be great fun as I seem to recall the parts being riveted in?
Okay, grabbed the full side harness out of the donor, I'll cut it down and extract the harness I need. Got a pair of the underseat drawers, a factory rear mat for the cargo box and the full harness for the vanity mirrors. Thanks for the advice! :ty:
Actually I'm going to snag one more now and use them in the back under the parts bin for storage. I hadn't considered the airbag controller on the driver's seat though. Darn.
23.2K members
