First assumption was fuel pump it was only providing 8.5 volts at orange wire connection in wire harness when key turned on by a helper. We did have 65 psi initially when jumper wire to 12 volts in fuse block, but after continuous testing probably burnt the pump out, it was only putting out@ 35-40 psi at pressure gauge. Checked wire harness for continuity all is fine. Checked and replaced Fuel Pump Relay. Went into tank pulled pump for the third time to check for breaks in wires to sending unit, all are like new. Replaced pump due to low pressure. Still have 8.5 volts on orange fuel pump wire and 35-40 psi when key turns On.
When buddy was troubleshooting fuse block to dash instrumentation wire harness he found AC/Heater circuit was a dead short. My recent discovery of a poorly repaired fusible link circuit showed evidence of a melted connector behind Battery below rear of fuse block. Hopefully this was caused by AC/heater circuit mentioned. Didn't take the time to follow the wires but the fuse link circuit diagram does include that circuit from one fuse link line being used.
So all this being mentioned and virtually every wire in obvious circuits that would cause a "No Start" reviewed, we decided to try the ECM from another wreck assuring the part numbers matched of course with results of nothing changed. Still have NO Start, low volts and pressure from new pump, with all instrument bulbs lighting up “Except the Service Engine Soon light”.
Heater blower, all headlights, tail and brake lights all work, but it just won’t start!
Really took a gamble buying this van at an auction for $450 bucks but it has low miles at 205k, pretty sweet shape inside and out with every part on drive train visually looking tight, plus they did drive it into the yard with a jumper wire from the fuel pump to the fuse block to get it running but the pump ran continuously killing it.
Sure would be great if someone could maybe point out a few more trouble shooting tech support idea’s for this before I start thinking of parting out to my older faithful 1990 Safari AWD. Anyone know how compatible these 2 models are for swapping from 95 over to a 90? Kinda going backwards but the 90 is pushing 450K with a fresh tight motor, it’s a “has been AWD from buggered viscous clutch taking out front differential”. Running for 30k on stub axles eventually wears out the wheel hub bearings. LOL!
