side terminal extension
Postby safariking [OP] » December 25th 2013, 10:27am
I need a little help here I'm looking to add some power accessories but it would make it a lot easier to hook up if I could get hold of a couple of these side post battery extensions. I checked on line at different places the price is ok its the shipping that's to much I'm in Ontario Canada and can't find anyone close by that carries these anyone use these or know where I can get some even if they were used on any factory vehicles so I know what to look for at wreckers. any info would be greatly appreciated. this is what I'm looking for or any other things you know of.thanks
side terminal.jpg (20.42 KiB) Viewed 758 times
safariking
Years of Membership: safariking has been a member for 3 full yearssafariking has been a member for 3 full yearssafariking has been a member for 3 full years
Topics: 19
Images: 9
Year: 1999
Extra Info: SLE 4.3
Re: side terminal extension
Postby snapper388 » December 25th 2013, 4:28pm
that looks like the extensions used for sub amps. check your local stereo store.
snapper388
Years of Membership: snapper388 has been a member for 3 full yearssnapper388 has been a member for 3 full yearssnapper388 has been a member for 3 full years
Images: 2
Year: 1995
Extra Info: 4.3 Mark III 2wd
Postby markmitch » December 25th 2013, 5:16pm
autozone carries the positive one. but not sure about the negative. let me know if you can't find them and maybe I can see how much for me to pick them up and ship them from California.
Firing on 2 Cylinders (L4)
Years of Membership: markmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full years
Topics: 433
Images: 5
Alias (AKA): Mitch
Year: 1989
Extra Info: RS 350 TBI
Postby WoodButcher » December 25th 2013, 6:38pm
Make one, threaded rod w/ 2 nuts locked together in the right location. Steel is fine but if your really particular go into the plumbing aisle and find brass bolts, cut the heads off.
WoodButcher
Firing on 6 Cylinders (L5)
Topics: 28
Images: 452
Alias (AKA): Bruce
Year: 1997
Extra Info: 4.3 RWD
Postby Jasen » December 25th 2013, 8:29pm
I picked some up at the stereo shop and I've seen them at the LAP.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Year: 1997
Postby RECox286 » December 25th 2013, 8:39pm
If they are not a "stock" item, ask if the store would special order you some.
I would just make my own from 3/8 course nuts and bolts, which I have done
in the past and had no problems regarding serviceability.
Uncle Bob
RECox286
Topics: 38
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [325K mi]
Postby sfeaver » December 26th 2013, 5:08am
Where in Ontario are you?
sfeaver
Firing on 7 Cylinders (L1)
Years of Membership: sfeaver has been a member for 7 full yearssfeaver has been a member for 7 full yearssfeaver has been a member for 7 full yearssfeaver has been a member for 7 full yearssfeaver has been a member for 7 full yearssfeaver has been a member for 7 full yearssfeaver has been a member for 7 full years
Topics: 24
Year: 1997
Extra Info: LT RWD 350ci V8
Postby tedanderson » December 26th 2013, 5:59am
If it's time for a new battery you might want to look at getting something that has both side post and top post terminals.
tedanderson
Firing on 8 Cylinders (L3)
Years of Membership: tedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full years
Topics: 74
Alias (AKA): 2Big4aMiniVan
Postby safariking [OP] » December 26th 2013, 6:17am
no battery is like new to sfeaver I'm in Hamilton Ontario :lol:
safariking
Topics: 19
Images: 9
Year: 1999
Extra Info: SLE 4.3
Postby redfury » December 26th 2013, 7:01am
can't pull enough power off of the accessory lugs on the fuse box?
redfury
Topics: 53
Images: 13
Year: 1998
Extra Info: LT 5.7L 4wd
Postby Big_kid » December 26th 2013, 3:26pm
X2 on LAPS or car stereo shop. (even Best Buy might have them, might have to talk to an installer though)
Topics: 138
Images: 67
Extra Info: 2WD conversion
Postby sfeaver » December 26th 2013, 4:02pm
Im in Hamilton too.. I have looked for one of those once when I needed one in a hurry for my dads Express van that has a wheelchair lift. I couldn't find one anywhere. I ended up ordering off ebay. I have a spot to ship to in NY so I you want, ship them there and on my next trip over I'll bring them back.
Scott
sfeaver
Topics: 24
Year: 1997
It is currently March 30th 2017, 3:39pm
Moderator: tedanderson
bowtie262
Time: 5:04pm
astronot
Date: Mar 28 '17
Time: 4:58pm
hotpsca
Comments: 14
Date: Mar 25 '17
Time: 4:47pm
Attached by: chevy57bert
chevy57bert
Comments: 14
Date: Mar 24 '17
Time: 12:04am
Attached by: markmitch
Date: Mar 09 '17
Time: 6:33pm
