Hello, I am new here I'm from Poland and I have problem with my Astro (1991 4.3 v6 4x4). The engine don't start and don't get the fuel, fuel pump was checked and it's in good condition, but I don't have voltage on relay socket and I can't find the fuse( I think the fuse i before the relay socket) Is this car has an immobilizer ? Because I have a strange keys. Do you know the solution of my problem ? Maybe there's something wrong with ECU ?
Greetings
Dan
hello. power at the pump is found (plug from the pump in the fuel tank, disconnected). but during the repair of the pump power, the second mechanic stripped distribitor. how to connect the cables, plugs and how to set the ignition.
hello. cable wiring scheme already found. I set a first piston engine compression (I set a mark on the pulley) but the distributor is not set on the number one cable only on number 3
managed to start the engine! was set wrong distributor. I have one last question to you. as well adjust the angle of ignition (in some European cars to set the angle meters ignition to turn off the ECU - or a Chevy?)
23.2K members
