INVERTER SETUP
INVERTER SETUP
Postby AstroJ [OP] » May 3rd 2010, 10:13pm
Hey guys I am needing to run an Inverter into the van and I am looking for an easy way to put the wires thru firewall anybody got ideas?
____________________________________________________________________
I AM the king... of what is the mystery
AstroJ
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: AstroJ has been a member for 6 full yearsAstroJ has been a member for 6 full yearsAstroJ has been a member for 6 full yearsAstroJ has been a member for 6 full yearsAstroJ has been a member for 6 full yearsAstroJ has been a member for 6 full years
Extra Info: Work Van
Re: INVERTER SETUP
Postby highwayman » May 3rd 2010, 10:23pm
I am also looking for this same info, for a 2000 astro. I poked around with a wire hanger for quite some time but couldn't find a passage from the interior to the engine.
I'm not nearly knowledgeable enough to start drilling holes...I'm certain I'd hit something.
highwayman
Years of Membership: highwayman has been a member for 6 full yearshighwayman has been a member for 6 full yearshighwayman has been a member for 6 full yearshighwayman has been a member for 6 full yearshighwayman has been a member for 6 full yearshighwayman has been a member for 6 full years
Extra Info: Band Tour Van
Re: INVERTER SETUP
Postby webcat » May 3rd 2010, 11:42pm
I drilled a hole right above my battery (little to the right ) of the battery.
I put E6000 glue in the hole to keep the wire from bouncing around , its like a homemade grommet
webcat
Section Moderator
Section Moderator
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
Re: INVERTER SETUP
Postby astroturf » May 3rd 2010, 11:44pm
webcat wrote:I drilled a hole right above my battery (little to the right ) of the battery
Goy any pix Web? I'm thinking of doing the same thing. Thanks, Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Re: INVERTER SETUP
Postby webcat » May 4th 2010, 12:22am
i'll try to get some pictures tonight
webcat
Section Moderator
Section Moderator
Topics: 253
Re: INVERTER SETUP
Postby webcat » May 4th 2010, 12:30am
mines a 2002 astro
webcat
Section Moderator
Section Moderator
Topics: 253
Re: INVERTER SETUP
Postby astroturf » May 4th 2010, 12:43am
webcat wrote:mines a 2002 astro
Man That was fast Webcat. Thanks, Jim
astroturf
Topics: 112
Re: INVERTER SETUP
Postby Jasen » May 4th 2010, 12:48am
He probably just had to put down one of his beers so he'd have a free hand for the camera :mrgreen:
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Images: 101
Year: 1997
Re: INVERTER SETUP
Postby astroturf » May 4th 2010, 12:57am
Or, I could just lend him my... Helmet Cam...
astroturf
Topics: 112
Re: INVERTER SETUP
Postby AstroJ [OP] » May 4th 2010, 2:02am
Thanks for the pic I'll have to look into mine and see if I could do the same.
AstroJ
Fueling (5/8 tank)
Fueling (5/8 tank)
Re: INVERTER SETUP
Postby tedanderson » May 4th 2010, 5:41am
If you are ever in doubt as to where the drill bit will come out on the other side of the sheet metal, get a hammer and a nail-set or big giant nail and a hammer and make an indentation.
tedanderson
Firing on 8 Cylinders (L3)
Years of Membership: tedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full years
Topics: 74
Alias (AKA): 2Big4aMiniVan
Re: INVERTER SETUP
Postby Big_kid » May 4th 2010, 7:32pm
On my Express work van I ran them through the passenger fender (battery side) & down behind the kick panel, then under/behind the foot well. I mounted the inverter on the front of the cargo divider behind the seat. Is there room for a similar run in an Astro?
Firing on 5 Cylinders (L5)
Topics: 133
Images: 48
Extra Info: 2WD conversion
Re: INVERTER SETUP
Postby timelessbeing » May 5th 2010, 1:14am
I'm using up to 1750W so I needed much heavier gauge wires.
Photos of my wiring: viewtopic.php?f=76&t=6318&start=10#p62691
2000 Astro AWD Passenger
4.3L CSFI V6 • 3.73 G80 • 4" OV lift • 30" AT tires
timelessbeing
Years of Membership: timelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full years
Topics: 38
Extra Info: Lifted AWD 4.3
Re: INVERTER SETUP
Postby ShAgSTRO » May 5th 2010, 2:29am
Thats good to know! I know yours is newer but I'll test it out and see where it leads me! (for amp) :chevy:
1986 Astro...I like my EFI carb ;)
ShAgSTRO
Years of Membership: ShAgSTRO has been a member for 6 full yearsShAgSTRO has been a member for 6 full yearsShAgSTRO has been a member for 6 full yearsShAgSTRO has been a member for 6 full yearsShAgSTRO has been a member for 6 full yearsShAgSTRO has been a member for 6 full years
Topics: 16
Extra Info: 4.3L
Re: INVERTER SETUP
Postby AstroJ [OP] » May 9th 2010, 9:05pm
Shag, any progress on the inverter? I'm about to start mine.
AstroJ
Fueling (5/8 tank)
Fueling (5/8 tank)
It is currently January 18th 2017, 11:09pm
Moderator: tedanderson
Attached by: chevymaher
Comments: 24
Date: Jan 14 '17
Time: 12:02am
Comments: 24
Date: Jan 13 '17
Time: 10:49pm
Attached by: astrotardis
astrotardis
Date: Jan 12 '17
Time: 9:01pm
astrotardis
Date: Jan 12 '17
Time: 2:46am
Comments: 27
Date: Jan 08 '17
Time: 3:07am
