94 Astro: Location of the fuseable link for the fuel pump?
Postby theegr1 [OP] » June 23rd 2010, 3:19am
After 190,000 km's and 16 years service, the fuel pump on my 94 astro (z engine; rwd) suddenly quit the other day. My Chilton guide helped me locate the fuel pump relay (which i replaced and it made no difference; still no noise from the pump, and no fuel pressure - even at the fuel filter). This Chilton guide also makes mention of a "fuseable link" protecting the fuel pump wiring. I want to check this link prior to replacing the fuel pump. Unfortanately this mediocre Chilton guide of mine merely mentions the fueable link for the fuel pump, but little else: All it notes is this: "Fuseable link C - black/silver, (to fuel pump circuit) located at battery connection block" ...No images, no pictures, no diagrams of any sort to help me locate and check it. Can anyone help point me to the exact location of the fuseable link for the fuel pump? I have been looking and looking (under the driver's dash as well as under the hood and I cannot find anything obvious. I would greatly appreciate the guidance in locating it. Thanks for taking the time to read this and thanks in advance to anyone who can help point me to it's location.
theegr1
Years of Membership: theegr1 has been a member for 6 full yearstheegr1 has been a member for 6 full yearstheegr1 has been a member for 6 full yearstheegr1 has been a member for 6 full yearstheegr1 has been a member for 6 full yearstheegr1 has been a member for 6 full years
Extra Info: 4.3 Z engine RWD
Re: 94 Astro: Location of the fuseable link for the fuel pum
Postby rev_les » June 23rd 2010, 3:25am
Chances are...it's the fuel pump itself, and it's located inside the fuel tank. Do a voltage check at the harness leading to the fuel tank, to be sure, but with that many km's, it's probably time for the original to go to that big trash can in the sky! :violin:
Welcome to the forum!
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby theegr1 [OP] » June 23rd 2010, 3:38am
Thanks for the welcome. I bought the new the new pump already. I have not changed it yet; I figured i better check the fuseable link as well; just in case the old pump took it out when the pump finally quit. If anyone knows where to find this "fuesable link", i would sure appreciate the knowledge. It is really annoying me that i cannot find it. My fear is that i will change the pump, and still have no current if that link is also out.
theegr1
Postby LEVE » June 23rd 2010, 3:55am
Dang all, bite the bullet and change the fuel pump. :banghead:
A Fuseable link is a shaved piece of wire that's about 1/2 to 1/3rd the size of the supply wire and acts as a fuse. It's usually buried in the wiring harness... and RARELY goes out. If it goes, you should have had a burned fuel pump relay, or a blown supply fuse. I just looked on my '93 FSM Electrical schematic and there's no Fuseable link shown; it should be the same for your '94.
Drop the tank and change the fuel pump. Don't center your focus on something that ain't gonna get you anywhere.
LEVE
Years of Membership: LEVE has been a member for 7 full yearsLEVE has been a member for 7 full yearsLEVE has been a member for 7 full yearsLEVE has been a member for 7 full yearsLEVE has been a member for 7 full yearsLEVE has been a member for 7 full yearsLEVE has been a member for 7 full years
Topics: 18
Extra Info: AWD 4.3L-W
Postby Mr_Bowtie » June 23rd 2010, 4:02am
I have no idea on the fuseable link stuff, but WELCOME TO THE FORUM!!!! Please take the time to introduce yourself in the "new members" section. :chevy:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Years of Membership: Mr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full years
Topics: 74
Images: 29
Year: 1985
Extra Info: 350 with 700r4
Postby theegr1 [OP] » June 23rd 2010, 4:22am
Yeah ok! I'll do that then! LOL! If your 93 does not have such a thing, then my 94 probably doesn't either; explains why I cannot locate it. That's one problem with these Chilton guides...This book covers all model years from 85 to 96. And of course, it doesn't always mention what applies to which years. I just figured i better do my research on the topic anyways. I'm thinking I should probably check ebay for a shop manual instead of using a Chilton guide.
theegr1
Postby LEVE » June 23rd 2010, 4:28am
There's FOUR FSM manuals for the Astro; each manual covers a different section, fuel, emissions, electrical, mechanical, etc.. I got my set off Ebay and haven't regretted it.
LEVE
Topics: 18
Postby rev_les » June 23rd 2010, 4:39am
LEVE wrote:There's FOUR FSM manuals for the Astro; each manual covers a different section, fuel, emissions, electrical, mechanical, etc.. I got my set off Ebay and haven't regretted it.
my '99 has 2, but one of them is a tome with several major sections combined into one huge book... anyway, I'd highly recommend buying the factory manual for your particular year, it's indispensable. ( I have the Haynes, Chilton, and the FSM for my '95, and my '99..... I've been using the '99 FSM for my '01 Safari, but it's a recent addition to the fleet, and so far,the same.
BTW...shop around on E-Bay.......the prices on these swing from really reasonable, to ridiculous...
NRA Lifetime Member
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Topics: 39
Alias (AKA): Les
It is currently April 24th 2017, 2:29am
Moderator: tedanderson
Leeann_93Leeann_93 is online!
Date: Apr 16 '17
Time: 2:56pm
AK1
Date: Apr 16 '17
Time: 1:39am
Comments: 26
Date: Apr 08 '17
Time: 3:28pm
Comments: 26
Date: Apr 08 '17
Time: 3:11pm
bowtie262
Date: Mar 29 '17
Time: 5:04pm
