Mystery leak??
Mystery leak??
Postby Ingmire [OP] » November 5th 2016, 11:45pm
I'm pretty certain my sliding door is leaking. But.. It seems odd the the 'holes' where the bench seats connect to the van are completely full of water. Any thoughts if that may be coming from a different source? There was just a big night of rain.
Ingmire
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: Ingmire has been a member for 1 full year
Year: 1994
Extra Info: XLT AWD
  • 2002 4.3 mystery coolant leak
    by Monk_Man » February 20th 2017, 7:50pm in Engines
    Last post by TurnNburn View the latest post
    February 20th 2017, 8:22pm
  • mystery line
    by phaetuszero » October 20th 2016, 11:33pm in Engines
    October 21st 2016, 8:19pm
    72
    February 22nd 2017, 11:54am
Re: Mystery leak??
Postby chevymaher » November 5th 2016, 11:54pm
Shouldn't be to hard to find. Sit in the van with a bucket and have someone spray a hose on it. By the time the bucket is full it should be apparent where it is coming from.
Topics: 81
Year: 1994
Re: Mystery leak??
Postby CoasterCoaster is online! » November 6th 2016, 12:35am
check the rear door where the license plate goes. mine leaks there really bad. rusted out the drivers rocker under the gas filler door. rotted out the previous owners plywood floor.
leaks like a sieve, runs in and towards the front of the van
Firing on 8 Cylinders (L1)
Years of Membership: Coaster has been a member for 4 full yearsCoaster has been a member for 4 full yearsCoaster has been a member for 4 full yearsCoaster has been a member for 4 full years
Topics: 100
Year: 1995
Extra Info: 4.3 cargo 2wd
Re: Mystery leak??
Postby Ingmire [OP] » November 28th 2016, 11:28pm
Leak fixed :) where the trunk trim meets the floor was practically wide open for rain to run down and enter underneath the plastic 'weather strip'. I used silicone and self tapping screws and fastened a piece of 1/4 inch rubber down the length of the gap. I then mounted the original plastic 'weather strip' over the top (there was room for it to live inside the weather strip). The siliconed and screwed the original weather strip down, lots of rain since. Carpet is still dry :)
Ingmire
Fueling (1/2 tank)
Fueling (1/2 tank)
Year: 1994
Extra Info: XLT AWD
Re: Mystery leak??
Postby sixsix » November 29th 2016, 2:44am
Ingmire wrote: ... where the trunk trim meets the floor was practically wide open ...
I was thinking you meant "Side Door" - where is this "trunk trim" of which you speak?
Filling up the seat mount pockets... golly.
Nice it's Fixed. :banana:
Mike
The Van's Build: viewtopic.php?f=127&t=59385
There are 3 types of people in this world - First, the type that can count
and Second, the type that can't.
Firing on 5 Cylinders (L2)
Years of Membership: sixsix has been a member for 2 full yearssixsix has been a member for 2 full years
Topics: 20
Images: 874
Year: 1992
Extra Info: LT W-CPI Motor 200K
Re: Mystery leak??
Postby Ingmire [OP] » February 10th 2017, 9:59pm
Trunk trim - where the rear hatch / barn doors (94 ext awd Safari) open, along the floor there is a piece of 'trim'. That allows all water to flow right into the van carpet.
Ingmire
Fueling (1/2 tank)
Fueling (1/2 tank)
Year: 1994
Extra Info: XLT AWD
Re: Mystery leak??
Postby sixsix » February 12th 2017, 1:05am
And to think ... I was sitting there all this time waiting for Just A Little Definition.
I quit holding my Breath back in December over the Christmas Holidays ... waiting... tap, tap, tap ...
LOL
Is this ( BLACK Arrow ) the "Trunk Trim" to which you referred?
The Bottom one is the one I refer to as a "Rear Sill Plate" - not sure of the Technical term ... LOL - Maybe it's called something ordinary like... uh... Trunk Trim... yeah, that's it!!
:rockon:
Mike
Topics: 20
Images: 874
Year: 1992
Re: Mystery leak??
Postby AstroWill » February 12th 2017, 3:27am
Something that makes it easy to find, like
PLATE,REAR FLOOR REAR TRIM(PEWTER) or PLATE, Door Sill and Rocker
Firing on 6 Cylinders (L5)
Years of Membership: AstroWill has been a member for 7 full yearsAstroWill has been a member for 7 full yearsAstroWill has been a member for 7 full yearsAstroWill has been a member for 7 full yearsAstroWill has been a member for 7 full yearsAstroWill has been a member for 7 full yearsAstroWill has been a member for 7 full years
Topics: 55
Images: 63
Alias (AKA): Richard C., Advocatus Diaboli
Year: 2003
Extra Info: 90TigerGTv8 03AWD
Return to Uncategorized
It is currently February 22nd 2017, 11:54am
Uncategorized Forum
UncategorizedAn all-purpose area for Astro/Safari van related discussion. These forums typically contain van-related but ill-assorted topics unfit for any other category. General questions and information relating to Astro & Safari Vans only.
Attached by: Meterpig
Meterpig
in Uncategorized
Comments: 13211
Date: Today
Time: 6:41am
Attached by: 97cargocrawler
97cargocrawler
in Uncategorized
Time: 7:11pm
in Uncategorized
Comments: 925
Time: 3:34am
Ksmith
in Uncategorized
Comments: 13211
Date: Feb 19 '17
Time: 8:14pm
in Uncategorized
Comments: 1818
Date: Feb 18 '17
Time: 9:44pm
Users browsing this forum: Google [Bot] and 2 guests
