found a parts vehicle
Postby markmitch [OP] » February 13th 2017, 5:03pm
I was talking to someone on facebook and found a 89 GMC truck I can take parts from. The truck was running and driving and the transfer went bad so her husband took the transfer out to rebuild it and he passed away before it got finished. I have no info on the truck yet but should no more by tomorrow afternoon. I will take pictures when I get to the truck. I am hoping its a V8 so I can get the Y pipe.
Firing on 1 Cylinder (L4)
Years of Membership: markmitch has been a member for 8 full yearsmarkmitch has been a member for 8 full yearsmarkmitch has been a member for 8 full yearsmarkmitch has been a member for 8 full yearsmarkmitch has been a member for 8 full yearsmarkmitch has been a member for 8 full yearsmarkmitch has been a member for 8 full yearsmarkmitch has been a member for 8 full years
Topics: 430
Images: 5
Alias (AKA): Mitch
Year: 1989
Extra Info: RS 350 TBI
  • Compatible Vehicle rims
    by Sjones28 » October 16th 2016, 6:00pm in Wheels/Tires
    Last post by icebrrg3rd View the latest post
    October 17th 2016, 5:29pm
  • 4L60E into earlier vehicle
    by markmitch » December 16th 2016, 5:57pm in Automatic
    9
    34
    February 28th 2017, 6:47am
Re: found a parts vehicle
Postby markmitch [OP] » February 14th 2017, 2:34am
OK so here are the pictures of the truck I can scavenge for free. It is a 1989 GMC 2500 4x4 truck with a 350 TBI engine 700R4 trans. The truck has tilt steering which is great cause mine is messed up so I will take the truck column and pull the parts to repair mine. The truck has 200+ thousand miles so if the engine turns over by hand I will eventually rebuild it with vortec heads and drop her in my van then sell the stock 350 from my van. I will start with the Y pipe and the steering column then work on the engine prep to pull.
Topics: 430
Images: 5
Alias (AKA): Mitch
Year: 1989
Postby MI_Ghost » February 14th 2017, 7:47am
Mark
Can you get a measurement of the steering knuckle for me. Top to bottom ball joint. Outside to outside.
~Ghost
Ast' Cargo: 2001 Astro Cargo
MI_Ghost
Years of Membership: MI_Ghost has been a member for 1 full year
Images: 46
Alias (AKA): Ghost
Year: 2001
Extra Info: Big White RWD Box
Postby 97cargocrawler » February 14th 2017, 5:33pm
You may want to grab the rear axle.
Actually I'd take the entire front drive assembly too for anyone who wanted to do a serious upgrade to their AWD system.
97cargocrawler
Firing on 8 Cylinders (L4)
Years of Membership: 97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years
Topics: 42
Alias (AKA): CC, CARGO, CRAWLER, ASSHOLE
Year: 1997
Postby markmitch [OP] » February 14th 2017, 5:57pm
the front axle assembly s gone everything else is there from what I have seen so far. the rear axle would be a problem since its sitting on kind of a hill and the jackstands are sinking. I will add a few more stands till I am done though, I like living. lol Yes I can measure but not sure how to.
Topics: 430
Images: 5
Alias (AKA): Mitch
Year: 1989
Postby markmitch [OP] » February 15th 2017, 3:28am
Well it took me over 2 hours to get the truck back up on the jack stands using a few jacks and jack stands and a huge section of wood beam that is 8 inches thick by 18 inches wide and 2 feet long. I have two of these chunks of beam just for such occasions. Anyway the bolts that hold the Y pipe in place are rusted and since I do not wish to break them I gave up till next trip there in which I will brings some PB blaster. The steering column I totally forgot to put the tools for that in the tool bag so I started unbolting the brackets and TBI and such since I plan on yanking the engine for a rebuilder. I will leave the heads and intake behind since I will be going vortec.I will post a few more pictures later this week. Thanks for reading, Mark
Topics: 430
Images: 5
Alias (AKA): Mitch
Year: 1989
Postby MI_Ghost » February 15th 2017, 3:35am
Just stretch a tape measure from top to bottom. Absolute accuracy is not required.
~Ghost
MI_Ghost
Images: 46
Alias (AKA): Ghost
Year: 2001
Postby markmitch [OP] » February 15th 2017, 7:40am
The steering knuckle? is that the placed where the steering column connects to the rest of the steering? like if I were to want to remove the steering column there is a bolt that holds the upper shaft to the lower assembly? I won't be going back for a few days we are getting more rain Thursday and tomorrow I have a doctors appointment.
Topics: 430
Images: 5
Alias (AKA): Mitch
Year: 1989
Postby MI_Ghost » February 15th 2017, 10:13am
No. The part that the front brake rotor is hanging off of. It is the same as the spindle between the upper and lower control arms. You can see it in the front wheel well in the first pic.
The term steering knuckle might be confusing you. When the spindle which the brake rotor and bearings are mounted on is removable as in the 4WD. It is commonly called a knuckle.
~Ghost
MI_Ghost
Images: 46
Alias (AKA): Ghost
Year: 2001
Return to Uncategorized
It is currently February 28th 2017, 6:47am
Uncategorized Forum
UncategorizedAn all-purpose area for Astro/Safari van related discussion. These forums typically contain van-related but ill-assorted topics unfit for any other category. General questions and information relating to Astro & Safari Vans only.
gastropod
in Uncategorized
Comments: 928
Date: Feb 26 '17
Time: 7:58pm
Attached by: Ironsides
Ironsides
in Uncategorized
Comments: 13230
Date: Feb 26 '17
Time: 2:07am
Attached by: zach914v8
zach914v8zach914v8 is online!
in Uncategorized
Comments: 1832
Date: Feb 25 '17
Time: 8:22pm
sadglad
in Uncategorized
Comments: 928
Date: Feb 25 '17
Time: 1:18pm
in Uncategorized
Comments: 23
Date: Feb 23 '17
Time: 10:48pm
