Flashing a computer? What is that?
Postby a2l1 [OP] » April 15th 2011, 6:09am
Ok this is from another post here in another forum.
"I've got a tested and working computer from a 1993 Chevy Astro that will also fit a 1993 GMC Safari, originally equipped with a 4.3 V6, 4L60E transmission. Can be reprogrammed (flashed) for better fuel economy, faster shifts, and better performance. "
How does one "flash" the computer to gain better fuel economy - performance - etc? Is it something one can do in an afternoon? Does it involve and "special" equipment? What does it really involve and what does one gain from doing this? I would just like to know.Would it work on the 95? Can anyone enlighten me please?
Thanks,
A J
1995 Regency conversion really a work in progress !!
Hernando County - West Central Florida
a2l1
Years of Membership: a2l1 has been a member for 6 full yearsa2l1 has been a member for 6 full yearsa2l1 has been a member for 6 full yearsa2l1 has been a member for 6 full yearsa2l1 has been a member for 6 full yearsa2l1 has been a member for 6 full years
Topics: 73
Alias (AKA): A J
Extra Info: 4.3-auto-RWD
  • 2001 Safari 114,000 miles SES light flashing
    by kennysmoke » January 20th 2017, 10:27pm in Engines
    Last post by kennysmoke View the latest post
    February 26th 2017, 6:43pm
    9
    72
    March 30th 2017, 3:40pm
Re: Flashing a computer? What is that?
Postby chevymaherchevymaher is online! » April 15th 2011, 7:33am
a2l1 wrote:Ok this is from another post here in another forum.
Thanks,
A J
stand in front of it in just a raincoat with Jethro Tulls auqulung playing and when nobody looking open the raincoat. :rofl: no really some scanners can change the programming and that is called flashing.It can change the timing fuel map shift points.it just runs better.Example I cranked the timing manually and this tells the computer to crank it without changing distributer position.
Topics: 82
Year: 1994
Postby fast68 » April 15th 2011, 8:12am
theres a program for lap top computers to do this stuff and i have no idea what it is or how ,,, but theres a map and there are values that can be edited or deleted or etc.,
and these are values in relation to things that the engine is allowed to do, and their limit values, etc.
is this ECM for a CPI or for a TBI?
both existed in 1993... FYI
also in 1992 and 1994 and 1995
different computers for either system
if the ECm is for a CPI then it should work in a 95 if it is also CPI engine powered
but the 4L60E trans may be electronically different from the 95 so i cant guarantee the 93 ECM will properly run/control the 95 trans,
or if its actually a seperate PCM on these vans that runs the trans
why do ppl double post stuff in separate forums?
wow..
fast68
Years of Membership: fast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full years
Topics: 12
Alias (AKA): fast
Extra Info: 4.3L Z EXT RWD
Postby Phantom » April 15th 2011, 7:56pm
Flashing is a term used for re-writing the firmware instructions on a solid state chip , called firmware because it is software like code that is permanently burned into the chip , some chips are EEPROM Electrically Erasable Programmable Read Only Memory , just like the BIOS in a computer . It requires a device like a Tech2 Tool , or a software program like EFI Live , or
HP Tuner , Tuner Cat , etc. These programs access the chip inside the PCM/ECM through a connection at the OBD1 or OBD2 diagnostic port and communicates directly with the chip firmware , when you Flash , you are changing the firmware instruction set on that Chip so that it operates in the way the software program has programmed it to do . For instance you can change the fuel mixture trim levels , timing settings , etc, etc .to a custom setting for a given vehicle .
Phantom
Firing on 7 Cylinders (L4)
Postby paintdrying » April 15th 2011, 10:16pm
The computer on my 1988 silverado had a removable chip. If you wanted to change the settings I believe you just bought a new chip. Let us know what you figure out because I need my van flashed to run without the cats.
paintdrying
Topics: 94
Extra Info: 108 000
Postby chevymaherchevymaher is online! » April 15th 2011, 11:04pm
What she just saidImage
Topics: 82
Year: 1994
Postby scott936 » April 16th 2011, 2:45am
Thanks,
A J
:rofl: My wife and I thought that was too funny
2002 Astro Van Cargo
Air Bags
Yokohama 225/60 17
Overhead console from 92 S 10
Custom Rear Bumper
Custom front seats
scott936
Years of Membership: scott936 has been a member for 6 full yearsscott936 has been a member for 6 full yearsscott936 has been a member for 6 full yearsscott936 has been a member for 6 full yearsscott936 has been a member for 6 full yearsscott936 has been a member for 6 full years
Topics: 37
Images: 20
Year: 2002
Extra Info: 2 WD Cargo
Postby a2l1 [OP] » April 16th 2011, 5:14am
Randy --- self portrait??? :goodpost:
It is funny. I think I will pass on having the computer flashed because I could never look at the van the same way anymore !!
a2l1
Topics: 73
Alias (AKA): A J
Return to Uncategorized
It is currently March 30th 2017, 3:40pm
Uncategorized Forum
UncategorizedAn all-purpose area for Astro/Safari van related discussion. These forums typically contain van-related but ill-assorted topics unfit for any other category. General questions and information relating to Astro & Safari Vans only.
ThatVanGuy
in Uncategorized
Comments: 13341
Date: Today
Time: 7:20am
smokinjoe
in Uncategorized
Date: Today
Time: 4:19am
Toskavat
in Uncategorized
Comments: 13341
Time: 4:01pm
ironhead79ironhead79 is online!
in Uncategorized
Comments: 13341
Time: 3:41am
ThatVanGuy
in Uncategorized
Comments: 13341
Time: 3:30am
