by scott936 [OP] » July 22nd 2011, 6:55pm
by Phantom » July 22nd 2011, 7:13pm
by scott936 [OP] » July 22nd 2011, 7:19pm
Phantom wrote:A partially clogged fuel injector , low fuel pressure , failing fuel regulator , improper gapped plugs , intake manifold vacuum leak are a few possibilities , sometimes the easiest way to find the problem is to have a OBD2 diagnostic live scan that shows the live current activity of all the components in the circuit that indicates what is actually happening .
by scott936 [OP] » July 22nd 2011, 7:30pm
by Phantom » July 22nd 2011, 7:51pm
scott936 wrote:I have found one of my tool salesmen has a live scanner I can use but I need to find the specs on a 2002 so I can see what is not with in spec, any ideas where I can find those?
by scott936 [OP] » July 25th 2011, 12:53am
by Big_kid » July 25th 2011, 1:48am
by Phantom » July 25th 2011, 1:55am
by Matrixx » July 25th 2011, 9:17am
by speedy57 » July 25th 2011, 1:38pm
by scott936 [OP] » July 25th 2011, 2:31pm
speedy57 wrote:Do the (X) engines not have a EGR system at all
by scott936 [OP] » July 25th 2011, 2:32pm
Big_kid wrote:Does the distributor still use that "star" on the shaft for the pickup? If so, is one of the points broken/damaged?
by scott936 [OP] » July 25th 2011, 2:47pm
Phantom wrote:When you say dist module , you mean the camshaft sensor? does your engine have any of the other components of a egr system?
it could be that the plug wire is not securely connected just loose , make sure you have the firing order correct as well
other possible causes
broken or burnt exaust valve spring
Poor compression
Defective computer
Faulty spark plug or wire
Faulty oxygen sensor(s)
Faulty fuel injector
Vacuum leak(s)
Low or weak fuel pressure
Defective Mass Air Flow Sensor
Defective Crankshaft and/or Camshaft Sensor
Defective Throttle Position Sensor
Here is some info you may find useful
http://www.engine-light-help.com/check- ... sting.html
by Matrixx » July 25th 2011, 6:06pm
by scott936 [OP] » July 25th 2011, 6:46pm
Matrixx wrote:They do have an emissions system, but it's designed differently than the typical egr setup. It was computer controlled with the Xs (to my understanding).
by scott936 [OP] » July 25th 2011, 7:52pm
by Phantom » July 25th 2011, 9:58pm
by scott936 [OP] » July 26th 2011, 12:15am
Phantom wrote:LTFT Long Term Fuel Trim
STFT Short Term Fuel Trim, is a program in the vehicle's computer designed to add or subtract fuel from the vehicle to compensate for operating conditions that vary from the ideal A/F ratio. The vehicle uses this program to make minor fuel adjustments (fine tune) on a short-term basis
STFT B1 --> B1 = Bank1
LTFT B1
STFT B2 --> B2 = Bank2
LTFT B2
The numbers reflect how much adjusting the PCM had to do to get the Air fuel ratio back to its intended range , closer to zero the better , but there are factors that can cause things to be way off since the PCM can only adjust to limited parameters , when components go bad they can be outside the limits of adjustment of the PCM .
Your numbers look like they are within reasonable spec , but without the exact spec they are supposed to be it is hard to say .
You would need to run all the diagnostics to find where the miss is , finding out if the coil is putting out the right voltage , if every cylinder is firing right on time getting measurements of every cylinder and comparing , kinda like comparing cylinder compression , typically the one that reads out of range from the others is the problem cylinder, but sometimes several cylinders are missing the right compression mark , finding if the crank sensor is firing consistently with in spec there is a lot of detailed stuff a scanner can do , and depending on what the scanner is capable of. Which is why you need a table chart that shows what the proper measurements should be and then compare your readings to what they are supposed to be
I prefer the laptop type because they can do more than the hand held type . GM has actually abandoned the hand held Tech2 type for a couple years now , its all computer based now , the only reason they may still have or use the Tech2 style is for the older vehicles
by Phantom » July 26th 2011, 12:50am
by scott936 [OP] » July 26th 2011, 2:40am
Phantom wrote:With OBD2 you need a hardware interface to plug into the OBD2 diag port , with OBD1 just a cable with the proper end on it would work , but with OBD2 the interface is required to use the proper protocol to make the communication between the car and the laptop.
Most companies prefer to make their stuff proprietary just so it doesn't work with other companies stuff ,
EFI Live
HP Tuner
Tuner Cat
Digimoto
Snap-On Shop Stream
Just a few choices
There are many software you can use , here is an interface that I have found to be good quality , there are some products similar to it for about 40 bucks cheaper but the quality of the circuit and case are not as durable and are inferior to this product and they have free tech support if you need help . with their product many different software can be used , they have a few more choices on their website.
http://obd2allinone.com/sc/details.asp?item=obd2usb
http://obd2allinone.com/sc/details.asp?item=12combo
The Tuner programs can actually flash the ECM/PCM to new custom settings , but before you attempt that make sure you learn how to use the program and what it does , just so you don't change something that you don't need or want changed , the process is like flashing the BIOS on a desktop computer , make sure there is no power interruption when flashing , that is critical
It is currently May 20th 2013, 5:40pm
| Engines Forum |
| Engine Repairs, Modifications, Diagnostics, Tuning, Upgrading, Questions. |
| Moderator: chevy57bert |
| Previous topic Next topic |
| Recent Image Attachments | |||
| Sponsors |
