my astro van stall
my astro van stall
Postby artlara70 [OP] » February 12th 2012, 4:44pm
Hi i have a 97 astro van that stalls it just turned to 180 k miles. It starts up perfectly sounds pretty good but when i press the accelerator hard it stalls i have to press it real soft so it can accelerate. I recently did a tune up, changed the rotor cap,air flow sensor,and throttle sensor, i think its the fuel injectors because i added a liquid to clean them and it worked better for a while now its back to being slow. can someone plz help me
artlara70
Years of Membership: artlara70 has been a member for 1 full year
Alias (AKA): oso
Year: 1997
Extra Info: white astro van
  • 1998 Astro van
    by luckybodog » December 5th 2012, 3:22am in Engines
    Last post by redfury View the latest post
    December 28th 2012, 8:49pm
  • Astro Van Tumblr Sites
    by Corsemoto » November 24th 2012, 8:54pm in Uncategorized
    Last post by Corsemoto View the latest post
    74
    May 21st 2013, 4:39pm
Re: my astro van stall
Postby Lumpy » February 12th 2012, 7:21pm
Vacuum leak?
Double check your new MAF/MAP sensors. My MAP electrical connector was wonky till I took it apart and cleaned the contacts.
Doesn't really seem likely that your injectors are a problem based on what you describe. But in any case, if it's a TBI, visually look in there while you activate the throttle. Watch to see if both injectors seem to be doing the same thing. Check THOSE elec connectors on the injectors. Check the wires as they pass through the edge of the throttle body.
More dramatic, spray injector cleaner around the intake manifold gasket and see if you hear/see a change in engine speed, suggesting a blown gasket.
Spray cleaner around vacuum hoses to watch for the same results to check for vacuum leak. Vacuum hoses are a PITA to me. I just replace them every couple of years or at least snip off an inch of the end of each one.
Firing on 2 Cylinders (L4)
Topics: 116
Year: 1989
Extra Info: 9 in. lift Camo
Postby RECox286 » February 12th 2012, 8:08pm
Hey Lumpy,
I tried the old cut an inch off the hose trick, until the hose was too short to fit, then I tried cutting the hose again, but it still wouldn't
fit. Any ideas ?
boB
RECox286
Green Status (L4)
Green Status (L4)
Years of Membership: RECox286 has been a member for 2 full yearsRECox286 has been a member for 2 full years
Topics: 28
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [323K mi]
Postby Lumpy » February 12th 2012, 10:09pm
RECox286 wrote:Hey Lumpy,
fit. Any ideas ?
Yes. You either have to take your van to Australia or Peru or some other place where you're in the Southern Hemisphere, or just order scissors and hose from Australia. Then when you cut, it will get longer instead of shorter. It's all because of the magnetic pull of the earth. CargoCrawler could explain it better than me.
Topics: 116
Year: 1989
Postby RECox286 » February 12th 2012, 10:57pm
"Wink, wink, nudge, nudge" He said knowingly
boB
RECox286
Green Status (L4)
Green Status (L4)
Topics: 28
Year: 1993
Return to Uncategorized
It is currently May 21st 2013, 4:39pm
Uncategorized Forum
UncategorizedAn all-purpose area for Astro/Safari van related discussion. These forums typically contain van-related but ill-assorted topics unfit for any other category. General questions and information relating to Astro & Safari Vans only.
Moderators: icebrrg3rd, Leeann_93
Attached by: icebrrg3rd
icebrrg3rd
in Uncategorized
Comments: 8431
Time: 3:29pm
Attached by: tedanderson
tedanderson
in Uncategorized
Comments: 253
Time: 12:54am
Attached by: TaxiVan
TaxiVan
in Uncategorized
Comments: 8431
Date: May 19 '13
Time: 2:08pm
Tegnus
in Uncategorized
Comments: 8431
Date: May 18 '13
Time: 9:43am
Tegnus
in Uncategorized
Comments: 8431
Date: May 17 '13
Time: 10:34pm
