1995 Astro cranks but won't start
Postby zumacarl [OP] » September 8th 2009, 3:37am
I have a 1995 Chevy Astro van that was running fine when I parked it and 3 days later all it will do is crank but will not start. Here is what I have tried already.
tune up, moved the ground wire from the t-stat to grounding block, -checked the fuel pressure which is 50 psi when i turn the key, replaced the fuel filter and tried a good coil and module and nothing has changed still cranks but does not even try to start, but I did spray a shot of starting fluid in and it did fire. Am i missing something obvious? If you have any suggestions please let me know thanks in advance.
zumacarl
Years of Membership: zumacarl has been a member for 7 full yearszumacarl has been a member for 7 full yearszumacarl has been a member for 7 full yearszumacarl has been a member for 7 full yearszumacarl has been a member for 7 full yearszumacarl has been a member for 7 full yearszumacarl has been a member for 7 full years
Extra Info: slt rwd
  • 98 Astro Won't Start
    by BillyJoBob » April 11th 2017, 7:54pm in Engines
    April 11th 2017, 8:54pm
  • 98 Astro Won't Start , Confused!
    by justjanets » April 19th 2017, 12:30am in Engines
    Last post by dramey View the latest post
    April 19th 2017, 4:28am
    29
    June 22nd 2017, 12:54pm
Re: 1995 Astro cranks but won't start
Postby 'cudapaul » September 8th 2009, 5:15am
Yes, you are missing something obvious.
If the engine will start and briefly run when you injected ether, then you don't have enough fuel to run the engine.
You will need to open the plenum to see if the FPR or high pressure fuel line is leaking and then repair/replace the defective parts. '95's (CPI) are notorius for the exact symptom you are describing. Leave the fuel pressure gauge on the Schrader valve for about 1/2 hour. If it leaks down to less than 30 psi by then, replace the FPR, high presure line, or injection spider. You can buy any of the fuel parts from the dealer ($$$) or rockauto.com ($$1/$).
BTW, 50 PSI of fuel pressure is not enough to start and run your engine, you need 54-58 PSI minimum.
And I love CPI engines. They produce the most stock horsepower and get the best fuel economy when they are working correctly.
'cudapaul
Years of Membership: 'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years
Alias (AKA): 'cudapaul
Extra Info: LT AWD
Postby chemist » September 14th 2009, 1:04am
Have you tried banging on the fuel tank with a hammer. Do this, then have someone turn the key after you've banged a couple times. Continue and it may start--no, wait you said you had fuel pressure. But someone else here is saying not enough, so maybe. Can you hear the pump engage?
Also of note: I had an occurence similar to what you described on a 95 Buick LeSabre that I had owned. After 2 days of trouble shooting I had it towed to a dealer garage. It was a failed crank sensor... But that doesn't make sense in your case either because you have enough spark to start with ether, you said, right?
2003 Chevy Astro, AWD, 124,000 mi
a must read
chemist
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: chemist has been a member for 9 full yearschemist has been a member for 9 full yearschemist has been a member for 9 full yearschemist has been a member for 9 full yearschemist has been a member for 9 full yearschemist has been a member for 9 full yearschemist has been a member for 9 full yearschemist has been a member for 9 full yearschemist has been a member for 9 full years
Topics: 26
Postby Big_kid » September 14th 2009, 2:18am
Definite fuel problem- enrich it with ether, it runs. I thought 95's required 60+ psi, but I'm probably mistaken.
X2 what 'CudaPaul said too.
Years of Membership: Big_kid has been a member for 9 full yearsBig_kid has been a member for 9 full yearsBig_kid has been a member for 9 full yearsBig_kid has been a member for 9 full yearsBig_kid has been a member for 9 full yearsBig_kid has been a member for 9 full yearsBig_kid has been a member for 9 full yearsBig_kid has been a member for 9 full yearsBig_kid has been a member for 9 full years
Topics: 141
Images: 83
Year: 1995
Extra Info: 2WD conversion
Postby $uperJoe » September 14th 2009, 5:05am
i would check the ignition control module in the distributor. it tells the ecm when to pulse the injectors. the spark will work reguardless. this is what was wrong with my van last week. replaced it and it started right away. this would be alot easier to check than removing the plenum. good luck on a easy fix.
Check out my Van build
$uperJoe
Firing on 4 Cylinders (L2)
Years of Membership: $uperJoe has been a member for 7 full years$uperJoe has been a member for 7 full years$uperJoe has been a member for 7 full years$uperJoe has been a member for 7 full years$uperJoe has been a member for 7 full years$uperJoe has been a member for 7 full years$uperJoe has been a member for 7 full years
Topics: 59
Postby astro355 » September 14th 2009, 9:05am
Big_kid wrote:Definite fuel problem- enrich it with ether, it runs. I thought 95's required 60+ psi, but I'm probably mistaken.
x3, no need to spend money on other parts here. Adding more fuel (starting fluid) to the engine and it fires means its not getting enough fluid. Cudapaul for the win.
astro355
Firing on 4 Cylinders (L6)
Years of Membership: astro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full years
Year: 1989
Extra Info: 355 V8 700R4
Postby Mr_Bowtie » September 14th 2009, 11:44am
What if you hold the gas pedal down will it start then? Thats the only way my Astro would start when the fuel pressure lines and regulator inside the plenum were leaking. I assume it was getting more air from the throttle blade being opened then it would start and spit black crap(raw fuel) everywhere. :lol:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Years of Membership: Mr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full years
Topics: 74
Images: 29
Year: 1985
Extra Info: 350 with 700r4
Return to Uncategorized
It is currently June 22nd 2017, 12:54pm
Uncategorized Forum
UncategorizedAn all-purpose area for Astro/Safari van related discussion. These forums typically contain van-related but ill-assorted topics unfit for any other category. General questions and information relating to Astro & Safari Vans only.
Moderators: Leeann_93Leeann_93 is online!, icebrrg3rd
ORYGUN ASSTRO
in Uncategorized
Comments: 13608
Time: 5:25am
Toskavat
in Uncategorized
Comments: 13608
Date: Jun 19 '17
Time: 10:38pm
in Uncategorized
Comments: 13608
Date: Jun 19 '17
Time: 1:57am
in Uncategorized
Date: Jun 17 '17
Time: 4:51am
timothy47130
in Uncategorized
Comments: 1144
Date: Jun 15 '17
Time: 4:47pm
