Scraping sound
Scraping sound
Postby daytonboi [OP] » September 30th 2009, 5:53pm
I'm not sure if this is the right place for this but here it goes. For about the past two or three months my van has been making a very loud and startling scraping sound. It's coming from the front end on the passenger side and its pretty hit or miss when it does it. When it does happen its normally when I'm backing up and turning. There has been one occasion when it happened I was going forward getting ready to turn into my driveway. I sounds like something digging into the concrete. I've stopped the van dead in its tracks and got out and looked but there is never anything hanging from anywhere on the van that can give me a clue as to what it is. I had the van in the shop for some very badly squealing brakes, that's another question for the other section though, and when the gentleman backed it up to put it in the stall he heard it and they looked and could not find anything wrong. I was wondering if anyone has an idea because i would like to catch before it gets out of hand and becomes too expensive to fix.
BTW the van is a 1998 Chevy Astro AWD.
daytonboi
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: daytonboi has been a member for 4 full yearsdaytonboi has been a member for 4 full yearsdaytonboi has been a member for 4 full yearsdaytonboi has been a member for 4 full years
Topics: 33
Alias (AKA): El
Year: 1998
  • Sound system is up!
    by aztec1987 » March 24th 2013, 5:32am in Electrical
    Last post by aztec1987 View the latest post
    March 26th 2013, 3:24am
  • Whining sound
    by Rod » March 16th 2013, 3:11am in Uncategorized
    Last post by zeusdog View the latest post
    March 20th 2013, 5:53pm
    7
    63
    May 26th 2013, 8:23am
Re: Scraping sound
Postby mattsrevenge » September 30th 2009, 7:24pm
quick q, when backing up, are the wheels turned? (ie, steer wheel turned to lock)
there are metal stoppers on the lower control arms (i believe- or the frame) that the hub stops into, if you have the wheels turned and go over any uneven surface, this can make a very loud grinding sound. my 98 crown vic does the same. paint the stopper with axle grease (i use anti-sez) and it will quiet it up.
you can test this by turning the wheels to lock on either side, drive over anything (fwd or reverse) uneven and see what noise it makes.
96 astro conversion
98 crown vic p71
mattsrevenge
Years of Membership: mattsrevenge has been a member for 4 full yearsmattsrevenge has been a member for 4 full yearsmattsrevenge has been a member for 4 full yearsmattsrevenge has been a member for 4 full years
Extra Info: 2wd conversion
Re: Scraping sound
Postby Jasen » October 1st 2009, 1:14am
Another thing, mine did something like this. It was a lose dust skirt in the wheel well. Was an easy fix.
http://the-99percent.blogspot.com/
I'm a Journeyman woodworker,
Every projects a journey man.
Firing on 4 Cylinders (L7)
Years of Membership: Jasen has been a member for 3 full yearsJasen has been a member for 3 full yearsJasen has been a member for 3 full years
Topics: 249
Images: 68
Year: 1997
Re: Scraping sound
Postby fede » October 1st 2009, 4:45am
also since your down there check your sway bar and linkage to see if there cracked.
91 Astro LT
fede
Years of Membership: fede has been a member for 5 full yearsfede has been a member for 5 full yearsfede has been a member for 5 full yearsfede has been a member for 5 full yearsfede has been a member for 5 full years
Topics: 60
Re: Scraping sound
Postby astro355 » October 2nd 2009, 5:18am
Jasen wrote:Another thing, mine did something like this. It was a lose dust skirt in the wheel well. Was an easy fix.
Yeah, I hate that one. Its makes a very unexpected noise.
astro355
Firing on 4 Cylinders (L6)
Years of Membership: astro355 has been a member for 5 full yearsastro355 has been a member for 5 full yearsastro355 has been a member for 5 full yearsastro355 has been a member for 5 full yearsastro355 has been a member for 5 full years
Year: 1989
Extra Info: 355 V8 700R4
Return to Uncategorized
It is currently May 26th 2013, 8:23am
Uncategorized Forum
UncategorizedAn all-purpose area for Astro/Safari van related discussion. These forums typically contain van-related but ill-assorted topics unfit for any other category. General questions and information relating to Astro & Safari Vans only.
Moderators: icebrrg3rd, Leeann_93
Attached by: chevymaher
in Uncategorized
Comments: 266
Time: 2:24pm
akkidakkid is online!
in Uncategorized
Comments: 300
Date: May 24 '13
Time: 7:26pm
Attached by: icebrrg3rd
icebrrg3rd
in Uncategorized
Comments: 8435
Date: May 20 '13
Time: 3:29pm
Attached by: tedanderson
tedanderson
in Uncategorized
Comments: 266
Date: May 20 '13
Time: 12:54am
Attached by: TaxiVan
TaxiVan
in Uncategorized
Comments: 8435
Date: May 19 '13
Time: 2:08pm
