Does anyone use a Fumoto oil valve for oil changes?
Postby Meterpig [OP] » January 27th 2015, 4:08am
I have seen these around for quite some time and almost bought a few. After changing the oil today, I think it could be useful. I searched out this site today and didn't find a reference and didn't see anything on the mighty google. So, thoughts?
http://www.fumotousa.com/
Meterpig
Blue Status (L2)
Blue Status (L2)
Years of Membership: Meterpig has been a member for 2 full yearsMeterpig has been a member for 2 full years
Topics: 48
Alias (AKA): meterpig
Year: 2002
Extra Info: Not a minivan
Re: Does anyone use a Fumoto oil valve for oil changes?
Postby smokinjoe » January 27th 2015, 4:16am
That is a really cool idea. I have never seen those. Post up if you find any that fit.
smokinjoe
Firing on 1 Cylinder (L2)
Years of Membership: smokinjoe has been a member for 8 full yearssmokinjoe has been a member for 8 full yearssmokinjoe has been a member for 8 full yearssmokinjoe has been a member for 8 full yearssmokinjoe has been a member for 8 full yearssmokinjoe has been a member for 8 full yearssmokinjoe has been a member for 8 full yearssmokinjoe has been a member for 8 full years
Topics: 185
Alias (AKA): smokinjoe
Year: 2002
Extra Info: RWD
Postby RECox286 » January 27th 2015, 5:53am
It is similar to the Quick Oil Change system that was marketed by Fram for a while
several years ago. Actually, I still have them on 2 of my trucks, and I think they are
the best thing that happened since sliced bread sticks ! Don't have any idea why
Fram gave up on them, but they did. I saw some of the metric thread kits @ HF
but of course, they won't fit an Astro oil pan. So, what else is new ?
Uncle Bob
RECox286
Topics: 39
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [325K mi]
Postby Meterpig [OP] » January 27th 2015, 6:41am
Here is the listing for fit options. Sky is the limit as for what you you want to fit given the open nature of the drain plug.
http://www.fumotousa.com/results.php?ma ... ++4.3L++V6
Meterpig
Blue Status (L2)
Blue Status (L2)
Topics: 48
Year: 2002
Postby pauldeere » January 27th 2015, 10:33am
Don't think I would trust my engines life on that small valve. There is a similar engine oil drain valve on a tractor I have. It takes forever to drain the two quarts of oil.
pauldeere
Years of Membership: pauldeere has been a member for 2 full yearspauldeere has been a member for 2 full years
Topics: 18
Alias (AKA): Tall Paul
Postby 1998kingbong » January 27th 2015, 4:54pm
i remember the first time I installed one of those. As I filled the oil I could not help but notice a puddle of clean oil coming towards my feet. Was open when I thought it was closed.
Off it came, now I have to fight to try and find a wrench to fit the drain plug Then I have tto turn the drain plug bolt. It is hell, not sure how i lived without this piece of junk drain valve.
1998kingbong
Years of Membership: 1998kingbong has been a member for 3 full years1998kingbong has been a member for 3 full years1998kingbong has been a member for 3 full years
Topics: 19
Year: 1998
Extra Info: awd 165000
Postby Leeann_93 » January 28th 2015, 12:08am
Lots of the Jeep Liberty CRD (diesel) guys install them - something about their pan threads being fragile and the Fumoto is easier. I think they just don't know how to properly tighten an oil drain plug, personally.
I'd never install one on my vehicles. Too easy to not tighten - or get wrong, as above - and too easy to mess with you by twisting it open when you weren't looking. And, especially, too easy for it to fail.
No, thanks.
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 27
Year: 2002
Extra Info: LS 4.3L AWD
Postby Lumpy » January 28th 2015, 12:19am
I used Fugawi oil in my compass.
Years of Membership: Lumpy has been a member for 7 full yearsLumpy has been a member for 7 full yearsLumpy has been a member for 7 full yearsLumpy has been a member for 7 full yearsLumpy has been a member for 7 full yearsLumpy has been a member for 7 full yearsLumpy has been a member for 7 full years
Year: 1989
Postby FrugalAstro » January 28th 2015, 12:22am
Leeann_93 wrote:I'd never install one on my vehicles. Too easy to not tighten - or get wrong, as above - and too easy to mess with you by twisting it open when you weren't looking. And, especially, too easy for it to fail.
No, thanks.
Absolutely agree with this. In all my years of changing oil on a myriad of vehicles, I've never stripped an oil drain plug.
I always use a torque wrench to tighten oil drain plugs.
I also NEVER trust rubber oil lines (like many models of Astros have) used for oil coolers.
My son had a 1996 S10 with a 4.3 - the factory oil cooler (with its already leaking lines) was the first thing to be removed when he purchased it. There are just too many horror stories about these oil cooler lines failing.
FrugalAstro
Years of Membership: FrugalAstro has been a member for 3 full yearsFrugalAstro has been a member for 3 full yearsFrugalAstro has been a member for 3 full years
Year: 1987
Postby RECox286 » January 28th 2015, 12:30am
Well, Leeann, one could always cap the valve with a piece of hose and a bolt. No ?
The ones I use are like a check valve that has a cap, for normal use, that must be
removed and then a fitting that opens the check valve screws onto the fitting for
oil changes. I also use a small ball valve on one of the small gas engines that,
due to position on the base makes it difficult to do oil changes w/o it being messy
(I mean swamp-ugly). Also rigged up one for the air comressor for oil changes.
They all work very well. But I do see where you are comng from with this particular
gizmo. However, you would have the option to safety wire the valve closed too.
When we did oil drains on the T-56 Turboprops (P-3 Orion sub hunter aircraft) first thing
was to safety wire a hose to the bottom of the ball valve, then cut the safety wire holding
the valve shut allowing the valve to be opened. Worked as advertised and we never lost an
airplane to low oil level, either.
Uncle Bob
RECox286
Topics: 39
Year: 1993
Postby 97cargocrawler » January 28th 2015, 1:39am
This thread reminded me that I really wanted one of those. After looking around for availability I ended up ordering an EZ branded unit because I'm not a fan of how the brass Fumoto valve looks. The EZ brand has good reviews as well but who knows about internals. Yeah I think a lot could go wrong but having this installed will keep me doing regular oil changes because it will be easy cleanup. I always do an engine flush with each change and the resultant crud shoots out like a 195* firehose into the pan and always gets all over me and the driveway no matter what I rig up to catch it. I always do my own changes (don't trust lube shops) and I always dread the mess, which usually puts off my change past the due date/mileage. So this might be just the thing to keep me regular. I keep a close eye on my gauges so any sudden drop in oil pressure wouldn't go unnoticed for long. For me I think the risk of component failure of the valve is less likely than damage to my engine due to cruddy oil.
97cargocrawler
Firing on 2 Cylinders (L5)
Years of Membership: 97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years
Topics: 42
Alias (AKA): CC, CARGO, CRAWLER, ASSHOLE
Year: 1997
Postby paulo57509 » January 28th 2015, 4:00am
People either hate or love the Fumoto.
I have a couple of the old Fram Sure-Drains. One is on the FUBAR'ed pan threads on Legend. The other is on the Lumina. I have a couple of new-in-the-package ones for who knows what they fit on. I like the Sure-Drains.
Dorman makes a similar drain valve called the EZ Drain. I've never seen one except in pictures.
paulo57509
Years of Membership: paulo57509 has been a member for 7 full yearspaulo57509 has been a member for 7 full yearspaulo57509 has been a member for 7 full yearspaulo57509 has been a member for 7 full yearspaulo57509 has been a member for 7 full yearspaulo57509 has been a member for 7 full yearspaulo57509 has been a member for 7 full years
Topics: 23
Year: 2003
Extra Info: RWD
Postby Astrofarian » January 28th 2015, 4:40am
Lumpy wrote:I used Fugawi oil in my compass.
....And he pulls out his compass and says, "Where THE FUGAWI ?" :shrug: :shrug: :rofl:
Cheer up....things could be worse! Look at me...I cheered up & SURE ENOUGH...things got worse! Bwahahahaha......ahem...sorry.....snicker
Astrofarian
Firing on 8 Cylinders (L2)
Years of Membership: Astrofarian has been a member for 3 full yearsAstrofarian has been a member for 3 full yearsAstrofarian has been a member for 3 full years
Topics: 13
Alias (AKA): M!ke
Year: 1991
Extra Info: 700000 km plus
Postby nsfkid » December 11th 2016, 11:26pm
I have used these on many of my VW's they are great and have a spring loaded lock indent. I generally use them when the oil pan threads are weak. (alloy oil pans that previous owners have over torqued. These are a well made piece.
nsfkid
Years of Membership: nsfkid has been a member for 6 full yearsnsfkid has been a member for 6 full yearsnsfkid has been a member for 6 full yearsnsfkid has been a member for 6 full yearsnsfkid has been a member for 6 full yearsnsfkid has been a member for 6 full years
Extra Info: various
Postby AstroWill » February 16th 2017, 8:46am
With the number of scrapes on the bottom of vehicles I look at, there is no way I would put something like that at the bottom of my pan.
Firing on 4 Cylinders (L6)
Topics: 66
Images: 135
Extra Info: 90TigerGTv8 03AWD
Postby MI_GhostMI_Ghost is online! » February 16th 2017, 11:26am
Since you dug it back up Will.
I have used drain valves like these in the past on over the road trucks. They worked great and made changing 10 gallons of oil easy but there are some issues with them.
If you ever go anywhere to get the oil changed and the person in the pit removes it. It is almost guaranteed to leak afterwards because they over tighten them and distort the valve, And like Will mentioned the first trip over a curb or through the back forty could be your last.
I do not do my own oil changes any more. The $30 or so on the van not to deal with the mess is well worth it to me to take it to a quick oil change.
~Ghost
Ast' Cargo: 2001 Astro Cargo
Firing on 7 Cylinders (L1)
Years of Membership: MI_Ghost has been a member for 1 full year
Images: 74
Alias (AKA): Ghost
Year: 2001
Extra Info: Big White RWD Box
Postby Mmusicman » February 16th 2017, 2:11pm
No, thanks.
COMPLETELY AGREE!!!
How hard is it to change oil? I mean seriously!!!
This is a perfect example of how people often "create their own troubles".
AND what are you going to do about the oil filter??? :shock:
2000 Chevy Astro LS AWD | 31" LT265/70R17 Tires | 8" LIFT | 10" TOTAL
92 Chevy Astro Shorty | V8-350
Years of Membership: Mmusicman has been a member for 3 full yearsMmusicman has been a member for 3 full yearsMmusicman has been a member for 3 full years
Topics: 35
Year: 2000
Extra Info: 2000 AWD 92 V8-350
Postby zach914v8 » February 16th 2017, 2:46pm
I see why one of these things could look tempting to someone that does their own oil changes. A no tools needed oil change in the driveway does have it's perks. I think with something like this you need to weight the risk vs reward.
Having seen plenty of banged up and scraped oil pans here at work because of Houston's third world roads, I personally wouldn't use one. I think it would be to easy to scrape or break or leak in the conditions here.
My Rides:
1974 Porsche 914 powered by a 305 Chevy v8.
1994 GMC Safari TBI 4.3, Lifted 4"
zach914v8
Years of Membership: zach914v8 has been a member for 7 full yearszach914v8 has been a member for 7 full yearszach914v8 has been a member for 7 full yearszach914v8 has been a member for 7 full yearszach914v8 has been a member for 7 full yearszach914v8 has been a member for 7 full yearszach914v8 has been a member for 7 full years
Topics: 12
Alias (AKA): ballzach
Extra Info: 4 inch lift
Postby Lumpy » February 16th 2017, 3:11pm
I don't think those valves eliminate any hassle/problem. The part about oil change that some want to consider a hassle is the - climb under the van, get the draining oil stream to land in the bucket, disposing of the drained oil. It's not about having or not having a tool. A simple crescent wrench would do the plug. With or without this add on valve thing, you'll still get greasy and have to crawl under your car.
- BUT -
I've got two tools that I think are great that help reduce the greasy forearms...
First tool -
https://www.amazon.com/No-Mess-Flexible-Bellows-Capture-Tools/dp/B00K5ON6FW
Above tool may not be the right SIZE for our filters, I just found the first link. There are two sizes. It's essentially a big, rubber bellows-cup that surrounds the oil filter and some kind of gripping fingers to grab the filter. You spin it off with a 3/8 drive from the outside bottom. Any spilling oil from the filter falls into the rubber bellows-cup so you can just pour it out later. Doesn't help on horizontal mount filters like our Honda.
2nd tool -
https://www.amazon.com/gp/product/B0054WI7CW
Magnet with a couple of spanner like fingers on the end of a flexible wand. You break the drain plug bolt free with a regular wrench then attach this thing and remove the plug entirely. No oil on YOU. No drain plug dropped into the drain pan.
Year: 1989
Postby Mmusicman » February 16th 2017, 3:47pm
I STILL want to know, despite a dangerous oil change gimmick, what is done about the oil filter?
Topics: 35
Year: 2000
Return to Uncategorized
It is currently May 28th 2017, 3:56pm
Uncategorized Forum
UncategorizedAn all-purpose area for Astro/Safari van related discussion. These forums typically contain van-related but ill-assorted topics unfit for any other category. General questions and information relating to Astro & Safari Vans only.
in Uncategorized
Comments: 13511
Time: 5:31pm
in Uncategorized
Comments: 1964
Date: May 21 '17
Time: 11:06pm
in Uncategorized
Comments: 1964
Date: May 21 '17
Time: 1:34am
Attached by: Jasekcco
Jasekcco
in Uncategorized
Comments: 13511
Date: May 17 '17
Time: 2:16am
Attached by: 1lowcab
1lowcab
in Uncategorized
Comments: 532
Date: May 15 '17
Time: 4:37am
