safari wont start sometimes, security light flash?
Postby rodtremblay85 [OP] » August 18th 2010, 5:02pm
Hi, my 98 slt will refuse to start for about 10 or 12 minutes at a time, only once a week or so. always starts instantly and runs perfect any other time, no sputter etc. it always starts 10-20 minutes later but a big pain when you have to get to work. it will crank the engine but seems like it is immobilizing the fuel pump? anyone know whats going on? thanks rod
rodtremblay85
Years of Membership: rodtremblay85 has been a member for 2 full yearsrodtremblay85 has been a member for 2 full years
Alias (AKA): rodtremblay85
Extra Info: awd slt
Re: safari wont start sometimes, security light flash?
Postby LEVE » August 18th 2010, 7:25pm
When does the security light come on?
Does the hard start condition occur ALWAYS with the security light coming on?
Are any OBDII codes being set?
First thing to do is to see what pressure the fuel pump is supplying.
How many miles on the van?
When it's hard starting you can lift the hood, spray a little starting fluid into the air intake. Then try to start the engine. If it takes right of and runs on the starting fluid, it's likely a fuel pump problem.
That's where I'd start.. but then, I'm just sayin'.....
LEVE
Years of Membership: LEVE has been a member for 3 full yearsLEVE has been a member for 3 full yearsLEVE has been a member for 3 full years
Topics: 18
Extra Info: AWD 4.3L-W
Postby alexalexanders » August 19th 2010, 1:13am
Does it start for like a second and die? Cause if so it the vans pass lock system preventing it to start.I had the same problem on my 98 malibu. I was on a malibu forum and they told me that you have to reset it to start the car by turning the key to the on setting for 10-12 min and the when the light stops flashing turn the key off for 5 seconds and the car will start. Its caused by a pass lock sensor goin bad. Problem is they either go forever and go out or they go out right then. The pass lock sensor was like $80 for the car, but that forum knew a way to disable it, so i just did that. But i dont know if the diable process is the same on the van. Also this may NOT be your problem but it sounds like what the car did.
2000 GMC Safari SLE
alexalexanders
Firing on 8 Cylinders (L1)
Years of Membership: alexalexanders has been a member for 3 full yearsalexalexanders has been a member for 3 full yearsalexalexanders has been a member for 3 full years
Topics: 79
Extra Info: SLE 4.3 Vortec
Postby fast68 » August 31st 2010, 6:25pm
ive been through this before, its the passlock
it resets if you leave key in run position for up to 15 minute but usually around 10 or 12
some of them have a yellow wire out of the key sensor around the igniton tumbler and if you snip it the ligt will be always on but it will disable the system and it will always start then.
i had to do this on one a couple years ago because we tried everything even having the controller rebuilt twice for 200 a pop and was all to no avail.
we still have it and it still runs starts perfect always
do some google searching on passlock for your year make model and how to correct or disable it
thats how i found out how to do ours
this was a huge problem in the 90s
very common
1992 Astro EXT parting out! many new parts! new regulators, heater core, ECM, etc. text me 217 671 7792 parting: '91 S-10 2wd pickup , '70's chevy trucks, '54 ford truck dually, '69 fairlane, '80s toyota trucks,
fast68
Years of Membership: fast68 has been a member for 4 full yearsfast68 has been a member for 4 full yearsfast68 has been a member for 4 full yearsfast68 has been a member for 4 full years
Topics: 12
Alias (AKA): fast
Extra Info: 4.3L Z EXT RWD
Postby Phantom » August 31st 2010, 7:03pm
I also had this problem on a Buick and it was the Passkey passlock security , there is a wire that comes down the steering column that comes from the key sensor , you can snip it and insert a resistor into it series wired and it will start and the security light will not stay on, look up a how-to on remote start setups they will have diagrams and pics
Phantom
Firing on 7 Cylinders (L4)
Years of Membership: Phantom has been a member for 2 full yearsPhantom has been a member for 2 full years
Postby rodtremblay85 [OP] » October 21st 2010, 7:23pm
Awesome, is this the same system known as "theftlock" on the 98 safaris? because I have instructions in the haynesmanual to disable this. Just did a 20000 km road trip and it only did it once, but it barely started after cranking until the battery almost died! thanks for all the info again!
rodtremblay85
Extra Info: awd slt
Postby LEVE » October 21st 2010, 10:29pm
Just know the resistor you need... when the key's inserted into the ignition the passcode reader will read the resistance and disable the security. The resister is on the key.... Go ---------> HERE <-----
LEVE
Topics: 18
Postby Phantom » October 21st 2010, 10:59pm
You can take your key to a locksmith or dealer and they can tell you which key number you have , and the resistor ohm rating , if you cannot get a good reading with a meter, then you'll know which resistor to use, sorry I forgot to say that before
Phantom
Postby astroturf » October 21st 2010, 11:47pm
Thanks for the Link Leve
Jim
astroturf
Years of Membership: astroturf has been a member for 3 full yearsastroturf has been a member for 3 full yearsastroturf has been a member for 3 full years
Topics: 112
Extra Info: 2wd Passenger
Return to Uncategorized
It is currently May 23rd 2013, 1:50pm
Uncategorized Forum
UncategorizedAn all-purpose area for Astro/Safari van related discussion. These forums typically contain van-related but ill-assorted topics unfit for any other category. General questions and information relating to Astro & Safari Vans only.
Moderators: icebrrg3rd, Leeann_93
Attached by: icebrrg3rd
icebrrg3rd
in Uncategorized
Comments: 8431
Date: May 20 '13
Time: 3:29pm
Attached by: tedanderson
tedanderson
in Uncategorized
Comments: 253
Date: May 20 '13
Time: 12:54am
Attached by: TaxiVan
TaxiVan
in Uncategorized
Comments: 8431
Date: May 19 '13
Time: 2:08pm
Tegnus
in Uncategorized
Comments: 8431
Date: May 18 '13
Time: 9:43am
Tegnus
in Uncategorized
Comments: 8431
Date: May 17 '13
Time: 10:34pm
