What to use when cleaning the throttle plate
Postby 94 Van Guy [OP] » September 24th 2010, 11:45pm
I am going to install a new Coolant Temperature Sensor in the morning. I want to clean the throttle plate at the same time. What would be the best product to use, I have read some types of cleaners are better than others, but can't find them when I search.
All input will be appreciated, Keith
'91 Chevy G30 Bus 37.9K Miles
Retired
94 Safari
87 Safari, 91 Astro
86 Astro, 85 Astro
88 Astro, 92 Astro
89 Astro, 88 Astro
94 Van Guy
Firing on 2 Cylinders (L3)
Years of Membership: 94 Van Guy has been a member for 3 full years94 Van Guy has been a member for 3 full years94 Van Guy has been a member for 3 full years
Topics: 64
Images: 46
Alias (AKA): Keith
Year: 1991
Extra Info: Not an Astro G30 Bus
  • Where Can I Get A Michigan Licence Plate
    by Ben_R » May 13th 2013, 6:27pm in Exterior
    May 14th 2013, 11:48pm
  • Where is the Throttle valve cable ?
    by zhillsastro » April 2nd 2013, 4:32pm in Automatic
    Last post by paulo57509 View the latest post
    April 7th 2013, 9:39pm
    59
    May 25th 2013, 11:43pm
Re: What to use when cleaning the throttle plate
Postby Phantom » September 24th 2010, 11:46pm
Gumout carb /fuel injection cleaner or similiar product
Phantom
Firing on 7 Cylinders (L4)
Years of Membership: Phantom has been a member for 2 full yearsPhantom has been a member for 2 full years
Postby astroturf » September 24th 2010, 11:50pm
Here you go Keith,
Just did mine about a week ago.
http://www.seafoamsales.com/how-to-use- ... spray.html
Hope it helps, Jim
astroturf
Years of Membership: astroturf has been a member for 3 full yearsastroturf has been a member for 3 full yearsastroturf has been a member for 3 full years
Topics: 112
Extra Info: 2wd Passenger
Postby Phantom » September 25th 2010, 12:06am
Seafoam is also a good product , however depending on how dirty your system is Seafoam cost like 8-9 dollars a can and Gumout jet spay is about 2-3 dollars a can , If it really looks bad go with the Seafoam otherwise Gumout will do just fine and save you money it literally washes off deposits if they are not caked and hard
Phantom
Postby 94 Van Guy [OP] » September 25th 2010, 12:19am
This is the part I was thinking of cleaning, but after reading the How-To from Sea Foam, I wonder if more needs to be cleaned. 184K, maybe it needs more than just a little spray? I just have never had much experience with this kind of thing.
I have only owned the van about 1000 miles, 7 months, and know nothing about the history of the van. I will say, I believe the van has been well cared for. The engine oil is clean 1000 miles after I changed the oil when I first got the van.
What do you think now that you see the pic?
Keith
Retired
94 Safari
87 Safari, 91 Astro
86 Astro, 85 Astro
88 Astro, 92 Astro
89 Astro, 88 Astro
94 Van Guy
Topics: 64
Images: 46
Alias (AKA): Keith
Year: 1991
Postby Leeann_93 » September 25th 2010, 12:21am
I'd clean the throttle plate and run Seafoam through a vac line. It really works....the Bravada smoked like an SOB after I did that and ran so much smoother it was amazing.
In fact, it's time to to it again...
'02 Astro SL AWD vin X
Years of Membership: Leeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full years
Topics: 17
Images: 3
Year: 2002
Extra Info: SL 4.3L AWD
Postby Phantom » September 25th 2010, 12:35am
I think I would agree with Leeann , and it has a build up , maybe if your wallet can part with the money buy both and try the Gumout on the blades and see if it can clean it and use the Seafoam as Leeann suggests , through a vacuum line , I have not tried that , but it would go through passages that spraying outside would not reach as well , I may have to try that :)
Phantom
Postby rev_les » September 25th 2010, 12:42am
I like to wait until some neighbors are having a "running too late" outdoor party, to do my seafoaming.....hook it up to a vacuum line, and drive around the block until the can's gone! :twisted:
NRA Lifetime Member
2'nd amendment supporter
'99 Astro, 296K 4.3 "W" 3.73's RIP
91 Sable wgn, 43K
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Years of Membership: rev_les has been a member for 4 full yearsrev_les has been a member for 4 full yearsrev_les has been a member for 4 full yearsrev_les has been a member for 4 full years
Topics: 37
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby 94 Van Guy [OP] » September 25th 2010, 12:42am
astroturf wrote:Here you go Keith,
Hope it helps, Jim
Thanks Jim for the link. When you did yours, did you use the 30" tube and spray for the 30 Seconds as their site would have you do?
If I do use the 30" tube, I don't see how the plate would get clean. So maybe both products would be needed.
Keith
Retired
94 Safari
87 Safari, 91 Astro
86 Astro, 85 Astro
88 Astro, 92 Astro
89 Astro, 88 Astro
94 Van Guy
Topics: 64
Images: 46
Alias (AKA): Keith
Year: 1991
Postby astroturf » September 25th 2010, 12:49am
Hope it helps, Jim
Keith
Keith,
First time for the spray. I did not use their tube. I pulled the airbox and sprayed directly on the throttle plate while the engine was running an increased idle. The can lasted a good 15 to 20 minutes. It will smoke...
You could use an acid brush such as Lumpy has just recently done.
Good Luck, Jim
astroturf
Topics: 112
Postby 94 Van Guy [OP] » September 25th 2010, 12:57am
Phantom wrote:Seafoam is also a good product , however depending on how dirty your system is Seafoam cost like 8-9 dollars a can and Gumout jet spay is about 2-3 dollars a can , If it really looks bad go with the Seafoam otherwise Gumout will do just fine and save you money it literally washes off deposits if they are not caked and hard
Thanks Phantom,
the spot on the throttle plate is where I lightly touched it to check if it was hard or not, it was soft. Maybe I should use the Gumout to clean the plate and Sea Foam for the internal build-up that must be there.
Retired
94 Safari
87 Safari, 91 Astro
86 Astro, 85 Astro
88 Astro, 92 Astro
89 Astro, 88 Astro
94 Van Guy
Topics: 64
Images: 46
Alias (AKA): Keith
Year: 1991
Postby rev_les » September 25th 2010, 1:01am
Thanks Phantom,
Not a bad plan at all , doing it that way Keith. :)
NRA Lifetime Member
91 Sable wgn, 43K
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Topics: 37
Alias (AKA): Les
Postby Phantom » September 25th 2010, 1:07am
You are welcome , I would try that , it is hard to know what build up is inside passages , I add Lucas fuel treatment at almost every tank full to try to prevent build up from occurring , tail pipe inside is clean , no deposits there hoping to keep it that way .
Good Luck ,, maybe try rev_les idea . driving around the block at party ROFLOL
Phantom
Postby 94 Van Guy [OP] » September 25th 2010, 1:11am
Leeann_93 wrote:I'd clean the throttle plate and run Seafoam through a vac line. It really works....the Bravada smoked like an SOB after I did that and ran so much smoother it was amazing.
Thanks Leeann for the tip,
The Sea Foam ad says to use the spray for 30 seconds while pulling the tube out. Then to drive the auto aggressive for 5 miles or until the exhaust clears up. If I spray the can into a vacuum hose instead of using the tube they supply, will I hook up a hose and spray while driving?
As I am typing these responses, seems I remember my dad did something similar when I was a kid. Just down the ole carb. I remember the smoke, maybe I should go some where that won't disturb the neighbors. We, the wife and I are considered the kids on the block.
PS Oh, almost forgot, how often should one do this type of treatment?
Retired
94 Safari
87 Safari, 91 Astro
86 Astro, 85 Astro
88 Astro, 92 Astro
89 Astro, 88 Astro
94 Van Guy
Topics: 64
Images: 46
Alias (AKA): Keith
Year: 1991
Postby 94 Van Guy [OP] » September 25th 2010, 1:25am
rev_les wrote:I like to wait until some neighbors are having a "running too late" outdoor party, to do my seafoaming.....hook it up to a vacuum line, and drive around the block until the can's gone! :twisted:
That's two for the vacuum line. Is there one vacuum line better than the other? The Sea Foam ad makes reference to some vacuum lines in the Vortec Engine, don't go into all areas so the liquid would not make it into all of the cylinders. Is this something I need to concern myself with or just go for it?
Keith
Retired
94 Safari
87 Safari, 91 Astro
86 Astro, 85 Astro
88 Astro, 92 Astro
89 Astro, 88 Astro
94 Van Guy
Topics: 64
Images: 46
Alias (AKA): Keith
Year: 1991
Postby rev_les » September 25th 2010, 1:27am
Definitely take it somewhere else! I have some butt-head neighbors, so I don't care, but if your neighbors are all respectful....don't be the horses rear! :)
You can leave it parked, and just rev it like you're driving it, we always took them to the back of the parking lot to de-carbonize them when I worked for GM.
NRA Lifetime Member
91 Sable wgn, 43K
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Topics: 37
Alias (AKA): Les
Postby Leeann_93 » September 25th 2010, 1:27am
I've never used their spray can, only the liquid, which has different directions (no driving). So I'm not sure on the spray stuff...
I last did it 2 years ago when I was getting the Bravada registered. I guess it really depends on how the van is running, to be honest.
Topics: 17
Images: 3
Year: 2002
Postby Lumpy » September 25th 2010, 1:32am
Seafoam...
I couldn't find the aerosol spray. So I just poured a bit on top of the TBI. The
throttle plates held it like a soup bowl. Then with my little stiff brush, I swished
it around and scrubbed a bit anywhere there was dirt/carbon. The gunk came
right off. Smoked a lot, as all the YouTubes show. Ran GREAT afterwords.
I figure the can in the tank gets to things like the injectors that the aerosol,
or my hand pour method, can't get to. The can in the tank made my 89 run
smooth. Then the pour/brush around the top made it run like a well
oiled sewing machine on rubber cushions.
Firing on 2 Cylinders (L4)
Topics: 116
Year: 1989
Extra Info: 9 in. lift Camo
Postby rev_les » September 25th 2010, 1:40am
Lumpy wrote:Seafoam...
Nothing like a well oiled sewing machine :mrgreen:
I love the smoke part, I'm gonna seafoam the safari this weekend
NRA Lifetime Member
91 Sable wgn, 43K
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Topics: 37
Alias (AKA): Les
Postby 94 Van Guy [OP] » September 25th 2010, 1:57am
Thanks for the info Lumpy,
with my engine, the TB is laying flat so I can't use it for a container to hold the good stuff. With a combination of different styles, I will get the job done.
There has been a lot of good information given so I'm sure I can succeed. It's off to the parts store now for some goood stuff.
Thanks to all that have contributed, Keith
Retired
94 Safari
87 Safari, 91 Astro
86 Astro, 85 Astro
88 Astro, 92 Astro
89 Astro, 88 Astro
94 Van Guy
Topics: 64
Images: 46
Alias (AKA): Keith
Year: 1991
  • Cleaning the EGR valve.
    by todd08 » August 13th 2008, 11:52pm in Uncategorized
    Last post by Gary View the latest post
    August 14th 2008, 2:50am
    9Replies
    66Replies
  • remove cover off throttle body
    by paintdrying » December 8th 2010, 5:27pm in Uncategorized
    Last post by paintdrying View the latest post
    December 8th 2010, 6:55pm
Return to Uncategorized
It is currently May 25th 2013, 11:43pm
Uncategorized Forum
UncategorizedAn all-purpose area for Astro/Safari van related discussion. These forums typically contain van-related but ill-assorted topics unfit for any other category. General questions and information relating to Astro & Safari Vans only.
Moderators: icebrrg3rd, Leeann_93
Attached by: chevymaher
in Uncategorized
Comments: 266
Date: Today
Time: 2:24pm
akkidakkid is online!
in Uncategorized
Comments: 300
Time: 7:26pm
Attached by: icebrrg3rd
icebrrg3rd
in Uncategorized
Comments: 8434
Date: May 20 '13
Time: 3:29pm
Attached by: tedanderson
tedanderson
in Uncategorized
Comments: 266
Date: May 20 '13
Time: 12:54am
Attached by: TaxiVan
TaxiVan
in Uncategorized
Comments: 8434
Date: May 19 '13
Time: 2:08pm
