yellow spark from coil
Postby paintdrying [OP] » November 11th 2010, 6:04pm
Just bought a 2000 astro and it seems to have trouble starting, after the morning start everything is fine, pullled the coil wire and the spark was strong but yellow, would not start with ether. Going to buy a plug right now to check spark at the wire. Probably should replace the coil? Any links to check the resistance.
paintdrying
Topics: 94
Extra Info: 108 000
  • Accessing my AC Evap Coil?
    by Lumpy » January 19th 2017, 3:47pm in Climate Control
    January 20th 2017, 2:45pm
  • 2002 coil sparks constantly when key turned to run
    by ekmissal » November 21st 2016, 12:32am in Electrical
    January 18th 2017, 11:59pm
    100
    March 24th 2017, 6:47pm
Re: yellow spark from coil
Postby Big_kid » November 11th 2010, 6:27pm
I'd check supply voltage going into the coil (and on the battery too) before spending the money on a new coil. Even the best coil can only work with what it's given. If supply is low, output will be weak.
I'm sure someone will have the ohms per foot for you before too long. I'd post it if I had it.
Welcome aboard!
:chevy:
Firing on 6 Cylinders (L5)
Topics: 138
Images: 67
Extra Info: 2WD conversion
Postby paintdrying [OP] » November 11th 2010, 9:04pm
wow parts are NOT cheap like they once were. A coil is 40 dollars. The ac delco plugs were 6.50 each. So I went outside, it is close to 60 degrees today and after not starting this morning it fired right up. First try. It was maybe 40 degrees this morning.
I Got my hand in under the hood and went to unplugging different sensors when it would not start, trying to put it into limp mode, but still would not start. I also checked coil spark again when it was running and it is still yellow(golden). I always remember coil spark being deep blue. Maybe that has changed as well.
Would anyone think the coolant temperature sensor could be doing this? Or that air temp sensor. What if I go out tomorrow morning with a heat gun and go to heating up the computer and what not, see if it helps?
Does anyone know where these sensors are, that sensor by the thermostat looked pretty big, is that the collant temp sensor?
paintdrying
Topics: 94
Extra Info: 108 000
Postby Mr_Bowtie » November 11th 2010, 10:05pm
Coil spark should be blue. I would start with replacing the coil and then see what you got. You might be able to get away without needing new plugs. I buy the AC Delco basic plugs & I thought they were like $2.50? :confused:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Year: 1985
Extra Info: 350 with 700r4
Postby RECox286 » November 11th 2010, 11:18pm
The sensor in question by the T-stat is the one that provides information to the PCM. The gage gets info from the sensor located between spark plugs #3 and #5.
Bob
RECox286
Topics: 38
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [325K mi]
Postby Phantom » November 11th 2010, 11:57pm
There are several things that can cause a no start situation, sounds like you have a weak coil , but it should at least idle . You say that it fired up on first try , did you drive it then? how soon after this first try did it not start? Some things that get overlooked that can cause this condition is a weak/bad crankshaft sensor and ignition module , you may need to get a diagnostic scan to find the source of problem , you may have more than one component needing replaced.
Phantom
Firing on 7 Cylinders (L4)
Postby paintdrying [OP] » November 12th 2010, 12:51am
Thanks guys,
Great response, I been on silverado forums in the past and could never really find good info.
Phanthom : The no start is basically first thing in the morning, although the other morning it was cold and it fired right up. So today around 9 am I tried it, no start, tried ether, no start. So then around one in the after noon I touch the key and it fired right up, so like 4 hours later after the first no start. I then drove it for about 20 minutes, it ran flawlessly. It is now sitting in my drive, I have a feeling it may start but won't try again till morning. When you say a scan, you mean at a mechanic, or pull codes at autozone? Crankshaft sensor, Iwas wondering about that as well.
paintdrying
Topics: 94
Extra Info: 108 000
Postby Lumpy » November 12th 2010, 1:22am
Always test the cup holder first. If that's within specs,
here's how to check the coil -
1.Using an ohmmeter (on the high scale), connect the probes between the primary (low voltage) terminal and coil ground; the reading should be very high or infinity, if not, replace the coil.
2.Using an ohmmeter (on the low scale), connect the probes between both primary (low voltage) terminals; the reading should be very low or zero, if not, replace the coil.
3.Using an ohmmeter (on the high scale), connect the probes between a primary (low voltage) terminal and the secondary (high voltage) terminal; the reading should be high (not infinite), if not, replace the coil.
Year: 1989
Postby RECox286 » November 12th 2010, 2:33am
Don't forget to check out the Cupholder first though.
Do a battery stress test to see if it is healthy enough to do a cold start. May be you have a good voltage reading, but not enough amps. Coils like voltage, but need amps to go blue.
Bob
RECox286
Topics: 38
Year: 1993
Postby paintdrying [OP] » November 12th 2010, 3:21am
the cup holders are filled with screws, old lottery tickets and some sort of strange wire connectors, all of which came with the truck. I will get to cleaning those in the morning. I have a near new battery I can put in there. I will try and check the coil tomorrow. I will post back
paintdrying
Topics: 94
Extra Info: 108 000
Postby RECox286 » November 12th 2010, 3:51am
In that case I would check the lottery tickets, and forget about the spark. You may be able to get a newer truck.
Bob
RECox286
Topics: 38
Year: 1993
Postby Phantom » November 12th 2010, 5:35am
paintdrying wrote:Thanks guys,
Preferably using a scan tool that reads voltages and sensors , it will be better at pinpointing where the problem is, Code reader is good for free at Autozone. Crankshaft sensors go bad and they can act up in a like condition as yours , sometimes you get a code and sometimes they fail without a code . Basically they are a magnet that reads the turns of the crankshaft , usually held in place by one bolt at the front of engine by the crank pulley.
Phantom
Postby paintdrying [OP] » November 15th 2010, 12:39am
small update, went out this morning and no start, checked spark, still yellow, it was a little dark out so I hooked the coil wire back up and and saw yellow sparks shooting out of the coil close to where the plug wire connects. That was good enough for me, went and bought a new borg weiner coil at advanced. Got home remounted the new coil back on the old bracket hooked all the wires back up, now no spark. No spark from the coil.
Ah, so I grab the old coil and plug the wire back in, now I have spark from the old coil. So I know I am getting power to the coil. My first thought is, ignition coil. Called up the parts store and the ignition module is 80 dollars and they claim not to be able to test the old one.
I will get in there tomorrow and check for power with a test light at coil and module. Also checking the ohms on the new coil.
1. Did I possibly get a bad coil?
2 can the crankposition sensor be checked with a ohm meter?
3. does a coil or ignition module require a body ground to work or avoid damage.
almost forgot but I put a new battery in and cleaned the cables real good. The battery was from my silverado that someone totalled, but it is still good
paintdrying
Topics: 94
Extra Info: 108 000
Postby astroturf » November 15th 2010, 12:53am
I would say you got a new defective coil.
Others will chime in.
Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby paintdrying [OP] » November 15th 2010, 9:28pm
new coil was bad, So I put a different new one in. It started right up. Lets hope that was the problem. i would like to get the plugs out and at least see what they look like.
paintdrying
Topics: 94
Extra Info: 108 000
Postby astroturf » November 15th 2010, 9:38pm
Well that is good to hear.
I would be curious of the spark color change... From yellow to?
Thanks, Jim
astroturf
Topics: 112
Postby paintdrying [OP] » November 16th 2010, 4:31am
no the spark is still yellow, but stronger than with the old coil. Not really sure what to think about that.
paintdrying
Topics: 94
Extra Info: 108 000
Postby paintdrying [OP] » November 16th 2010, 11:46pm
started right up this morning then seemed to run better. When the motor was cold it would hesitate now, with the new coil the hesitate is gone when cold.
paintdrying
Topics: 94
Extra Info: 108 000
Postby astroturf » November 17th 2010, 12:32am
That is Good News PD.
Congrats, Jim
astroturf
Topics: 112
Return to Uncategorized
It is currently March 24th 2017, 6:47pm
Uncategorized Forum
UncategorizedAn all-purpose area for Astro/Safari van related discussion. These forums typically contain van-related but ill-assorted topics unfit for any other category. General questions and information relating to Astro & Safari Vans only.
99SLEG80AWD
in Uncategorized
Comments: 981
Date: Today
Time: 4:50pm
99SLEG80AWD
in Uncategorized
Comments: 981
Date: Today
Time: 4:42pm
99SLEG80AWD
in Uncategorized
Comments: 981
Date: Today
Time: 4:37pm
ORYGUN ASSTRO
in Uncategorized
Comments: 981
Date: Today
Time: 3:14am
99SLEG80AWD
in Uncategorized
Comments: 981
Date: Today
Time: 12:49am
Users browsing this forum: Majestic-12 [Bot] and 4 guests
