Radiator Flush Kit
Radiator Flush Kit
Postby bombeam2004 [OP] » August 17th 2010, 3:03am
The two metal nipples that come from the heater core on the passenger side of my 2004 Safari have hoses that route to the engine. Can anyone tell me which one to cut into for placing the "T" for that radiator flush kit? The upper hose is smaller, and appears to be coming from a fitting on the top of the water pump. The lower and larger hose goes back on the passenger side of the engine. The instructions say to cut the one that goes into the block. But I can't see exactly where it goes. It appears that I am supposed to cut the larger one, and not the one that goes to the water pump.
bombeam2004
Years of Membership: bombeam2004 has been a member for 6 full yearsbombeam2004 has been a member for 6 full yearsbombeam2004 has been a member for 6 full yearsbombeam2004 has been a member for 6 full yearsbombeam2004 has been a member for 6 full yearsbombeam2004 has been a member for 6 full years
Alias (AKA): bombeam
Re: Radiator Flush Kit
Postby rev_les » August 17th 2010, 7:20am
cut whichever one is the size of the "T"..... either way, you're either including or missing the heater core. ( truthfully, the last time I flushed mine, it apparently UN-clogged debris plugging a leak in my heater core and made a leak, necessitating a new heater core). I don't recall which hose is the feed and which one is the return.
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby TheRealDaddy » August 17th 2010, 11:53am
The hose that leads to the water pump is the returning water from the heater core to the engine.and the one that leads down along the passenger side eventually loops back up and goes into the intake at the rear. If you removed your inner doghouse you would see it entering next to the distributor. Anyway The water flows back out of the engine from here and this is probably the one they want you to use according to what you have said your instructions relay.
Please just call me Carter
current modes of transport:
91 GMC Safari XT 5.7 350
89 GMC Safari 5.7 350
83 Honda Shadow VT750C
78 Chevy El Camino (still in progress)
99 Hyundai Accent
08 Roketa JM Star touring scooter
TheRealDaddy
Years of Membership: TheRealDaddy has been a member for 6 full yearsTheRealDaddy has been a member for 6 full yearsTheRealDaddy has been a member for 6 full yearsTheRealDaddy has been a member for 6 full yearsTheRealDaddy has been a member for 6 full yearsTheRealDaddy has been a member for 6 full years
Topics: 7
Alias (AKA): Carter
Extra Info: XT 5.7 V8 2WD
Postby rick-va3rzs » September 20th 2010, 4:05pm
What do you do when you DONT have the drain cock ... I need/want to change the anti-freeze before it gets to cold out .. I cant reach the bottom hose clamp .. go go figure ..
Thanks
Rick
rick-va3rzs
Years of Membership: rick-va3rzs has been a member for 6 full yearsrick-va3rzs has been a member for 6 full yearsrick-va3rzs has been a member for 6 full yearsrick-va3rzs has been a member for 6 full yearsrick-va3rzs has been a member for 6 full yearsrick-va3rzs has been a member for 6 full years
Postby astroturf » September 20th 2010, 8:34pm
rick-va3rzs wrote:What do you do when you DONT have the drain cock ... I need/want to change the anti-freeze before it gets to cold out .. I cant reach the bottom hose clamp .. go go figure ..
Thanks
Rick
Same here an 05 with no petcock valve.
I pulled the fan schroud, and lower radiator hose, access everything from the top to drain the radiator.
I also used a radiator flush kit.
Good Luck, Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby Lumpy » September 21st 2010, 3:44pm
I just flushed the bad brown out of mine and replaced it with good green.
I just disconnected all the hoses at radiator, block/thermostat, heater core,
lines to the rear heater core. Drained out what would fall out via gravity,
then stuck my garden hose into each opening and ran clean water till
it came out clear on the other end.
It was no more work than installing one of those kits, except for
the part about removing and replacing the thermostat. That was
a little cramped.
Topics: 258
Year: 1989
Postby astroturf » September 21st 2010, 4:40pm
Lumpy wrote:I just flushed the bad brown out of mine and replaced it with good green.
a little cramped.
Ya had me until you said it was no more trouble than installing a flush kit...
Sorry installing a flush kit and attaching a garden hose is much much easier than what you described.
What do you mean by Good Green?
Thanks, Jim
astroturf
Topics: 112
Postby Lumpy » September 21st 2010, 9:14pm
Thanks, Jim
Good Green = Prestone.
I got the idea of the garden hose to coolant hose from one of your posts.
I had to remove a half dozen hose clamps and pull the hoses away from
their nipples. To do the flush kit I guess I'd have to remove two hose
clamps, cut a hose, install the widget, then add two new clamps.
Maybe simpler, maybe not. Certainly not very complex or time consuming.
I liked the idea of flushing it out both directions at every point. That way
I was sure to get the old DexCrud out.
It actually seems like my heater hose is not long enough to add the
flush kit thingie. The length of rubber hose between the heater
box and the metal supply line is only about 2 1/2 inches.
Topics: 258
Year: 1989
Postby astroturf » September 21st 2010, 9:30pm
Thanks, Jim
If you flushed in both directions you did very good.
About the Green though...
It's not really green.
As far as I know, Your mileage may vary.
What should the change interval on hoses be? Does anyone know?
Thanks, Jim
PS DexCrud out is a good thing... No matter what you replace it with.
astroturf
Topics: 112
Postby Lumpy » September 21st 2010, 9:43pm
I meant "green" the color. Not Green in the political-ecological sense.
Bumper pics going up in a couple minutes.. :banana:
Topics: 258
Year: 1989
Postby astroturf » September 21st 2010, 9:56pm
No not eco...
Just green in formulation, its all but gone. You can still get it from John Deere CoolGuard II. But you cannot really by the Green we new as younger men anymore.
It's all gone now. Dex was the first and all the eco weiners caused everyone else to follow suit.
Ah Well... Bring on the PIX. w00t
Jim
astroturf
Topics: 112
Return to Climate Control
It is currently February 26th 2017, 1:55am
Climate Control Forum
Rookie162
in Climate Control
Comments: 34
Date: Feb 22 '17
Time: 2:07am
Rinny
in Climate Control
Comments: 28
Date: Jan 23 '17
Time: 2:40pm
Comments: 29
Date: Dec 22 '16
Time: 2:51am
Colorado Tim
in Climate Control
Date: Dec 15 '16
Time: 5:21am
Colorado Tim
in Climate Control
Date: Dec 15 '16
Time: 5:18am
Users browsing this forum: Bing [Bot] and 2 guests
