1 - 14 of 14 Posts
I had a breakdown issue in the Walmart parking lot. 04 Chevy Astro 2WD. Put $40 worth of gas in it and had about 1/2 a tank. Drove just fine and parked in the parking lot. Went in and did my shopping and came back out and gas gauge dropped to E, Miles left to E screen went to dashes, and fuel pump wouldn’t prime. Relay clicks when you turn the key on. Went and purchased a new fuel pump, dropped the tank, installed it, and swapped out the fuel filter. ECM-B fuse is good. Cleaned fuel pump ground above tank. Still not showing gas in the tank and still won’t prime. Also have a P0452 code, (Fuel tank pressure sensor circuit low voltage.) Another note, the day before it did the same thing on a slight incline. I put it in neutral and let it roll back and slammed on the brakes and it went back to normal. Didn’t work this time around. I’m completely stumped on what it might be.
You bought a new pump and replaced the old pump without knowing for sure if the old pump was actually bad? What if it was just a bad connection or ground? The issue with the gauges might have been a clue, since they are usually not affected by the pump itself.
The fact that you jerked the vehicle which got it going tells me something may be loose, or possibly corroded. The fuel pump AND fuel gauge sender share the same common connection. That's probably where I might start looking.. assuming there is 12v coming out of the relay
Discussion Starter · #3 ·
I replaced the fuel pump because I assumed that was the issue because the last one I put in was a cheaper aftermarket pump. And I figured that the fuel level sensor on the pump wasn’t sending a reading to the gauge. I’m sorry I've just been trying the easiest and fastest things to start out with because I need the vehicle back on the road. Where exactly should I test first?
I would definitely keep that jumper wire handy! I think you just got lucky ( coincidence?) this time around.
You have not found the problem yet!
Have you examined the ground connection at the frame, near the fuel tank? I have no idea if taht would affect the guages, but it is related to that wiring, so maybe. Others have way more experience with that system. I have not had the need to investigate that system .... so far.;)
Rod J
Discussion Starter · #7 ·
Update# 2, Issue came back. Put new fuel pump relay, cleaned all contacts in fuse block with electrical parts cleaner and a toothbrush, and it just happened again. Ground by tank is clean, ground on firewall is clean, I don’t know where to start looking.
Simple diagnosis..
When it's NOT working, do you still have voltage coming out of relay?
When it's NOT working, do you have voltage at fuel pump?
This will tell you at what point to start looking.
Get a test light
Assuming connections are good:
You might have an intermittent break in a wire
If so, easiest would be to run a new one
Same could apply to ground if 12v is good
Did you replace the pump and sending unit or just the pump?
Personally I would suspect the connector that plugs into the sending unit since both pump and gauge are affected.
Discussion Starter · #12 · (Edited)
Simple diagnosis..
Get a test light
Getting voltage into relay on pin 30, but with vehicle on there is no voltage at pin 87. Used a test light. With relay out and vehicle key on or off, I’m getting constant voltage at pin 30 and 85
· Administrator
Glad you got it figured out and thanks for posting your solution. Have a link to JA where it was solved?
Also, it helps if you put your year/make/model/engine/AWD/conversion/etc in your profile or signature line so we know what we are working with in the future. https://www.astrosafari.com/account/signature
1 - 14 of 14 Posts
