Selling my 1995 Astro RWD conversion van with 137,000 miles. Maroon with a pink/red cloth interior. I have owned it for the past 3 years and 7000 miles and have done my best to care for it, but unfortunately, it has recently developed a connecting rod knock and has low oil pressure, so it will need an engine. I just pulled the oil pan an verified this. This has been a great van up until now and I have driven it out of state multiple times. This is a perfect candidate for a 350 swap or a mechanic special for someone with a lift. I was thinking about digging into it myself, but I have multiple other vehicles and an engine swap on these is impractical without a lift. Located in Grove City (Columbus), Ohio. Must pick up and trailer. Will not ship. $1000. You can easily get this back out of the parts and the wheels/tires, so I'm holding fairly firm.
Good: Nearly new General Grabber all-terrain tires. Completely overhauled brake system in late 2020 with new pads, rotors, shoes, calipers, hardware, lines and fresh fluid. Class III towing hitch installed. Very minimal rust. Frame is in great shape. New cat-back exhaust system. 4L60E transmission shifts flawlessly. New hydraulic brake booster. New driver side window motor. Clean title. All seats still present. Conversion interior is in decent shape. Carpet and seats recently cleaned with a wet vac.
Bad: Aforementioned connecting rod knock. Paint is faded down to primer on the hood. The previous owner worked with some kind of tar, so there is hardened tar on parts of the front two seats. A/C was repaired, but is now not working (bad compressor, probably). Rear door handle recently broke. Stole the alternator bracket for my G20, so accessory drive is currently not hooked up.
Other: ABS was broken and has been completely deleted at time of brake overhaul (module and pump removed). Pictured aftermarket stereo removed, but I will include the still-working OEM Delco receiver.
