Hi,
New member here, hello everyone! I'm from Syracuse NY and recently purchased a 1995 Chevy Astro for $500. It was for many purposes-hauling the dogs around, hauling non working motorcycles around, hauling other assorted crap, etc. My mechanical background is limited and is based off of older Japanese motorcycles.
Anyway, here is my laundry list of issues and I'm not sure what is what-I do not have a manual as of yet and haven't been lucky enough to find a PDF copy anywhere.
The van will not currently start. Battery seems like it's ok but I just put my booster pack on it to see if it might have been too weak to turn the starter. Didn't make any difference at all. Nothing. I turn the key, hear the fuel pump turn on and build pressure, and then when I try to start it, I hear one single click from below the front area and that's it. It does not turn over at all. I just tried it again after writing this and now I hear multiple clicks and a strange sound from inside the car...a high pitched sound that almost "speeds up" as I hold the key in the start position longer. I assume this is a bad starter.
Before this occurred, the steering wheel was nearly impossible to turn and I heard a loud whirring sound when I attempted to. Checked the power steering fluid reservoir and it was almost empty and smoking (didn't drive it anywhere, just tried backing up in the driveway). I filled it to the appropriate level, same deal and then the fluid leaks out underneath the van. Haven't been able to pinpoint the source of leaking. I assume this is a bad power steering pump.
As if this wasn't enough, when the power steering thing happened the brakes started to go too. I know there was a bad brake line going to the rear brakes upon purchase. Now, before the van stopped starting completely, the brake makes this horrible moaning sound when applied and vibrates once you apply any pressure to it.
The only other problem that I've noticed is the gas pedal. Suddenly the gas pedal is almost on the floor. The cable seems to be out much farther than it should be. There is still some ability to press the gas pedal and have the cable respond, but not as much as there was when it was driveable.
I know this is quite a bit to ask for help on for a new member. If anyone here has the time and inclination to help me figure this out and some possible suggestions on how to get inexpensive parts I would be very appreciative. If anyone here would be willing to barter for parts I would also be very appreciative.
Thanks for any and all help and I, of course, am willing to take this one step at a time starting with getting the van running again.
-Nate
-Nate
