Well some one thinks that the stock unit will hold you. At 210 you ain't some small dude. Look for youself (give a good shake) and think - Do I care if I dent the roof?webcat said:your stock roof mount would do the job
Yea that 2 inch square tubing might be a good idea , you might be alright without it but the roof rack has some slight flex under psi that could eventually over time cause your rack to break !toddb said:I'm pretty sure the roof will take your weight ( don't have anyone else up there with you thou). The factory roof racks - good luck with that. You better nut and bolt or screw something more substainstal up there ( perhaps 2 inch square tubing).
I've got a couple different thoughts on this.Lazyjay said:I believe the stock roof rails are rated at < 200lbs. However, the BajaRack rates their rack at 400 lbs. I think most roof racks are rated at 300 lbs.
